Refurb TVs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-28-2013, 10:14 PM - Thread Starter
Dahlyn's Avatar
Is buying one a bad idea. After guidance for the community I bought my parents a refurbed reciever and save a lot. What about for TVs. If its ok what sites have them. Thanks.
Dahlyn is offline
post #2 of 5 Old 02-28-2013, 11:42 PM
redshift1's Avatar
Depends on price, vendor and warranty. I buy most of my Apple electronics refurbished but Apple has great CS. Of course a TV is more fragile and packing is problematic unless done professionally.
redshift1 is offline
post #3 of 5 Old 03-01-2013, 04:00 AM
EMG518's Avatar
I was looking for a tv early 2009, so 4 years ago. A new LED tv was expensive at the time regardless what model as that was the first year they came out with the edge lit designs. I couldnt find anything within my price range that was the type of quality I wanted. I found a Samsung 4681f, probably a little over a year old model. Still one of the best tvs you could buy at the time and way better than what I could get new with the money I wanted to spend. Im still using the tv today and it is great. Getting a refurb imo could be the safer choice. When you get a new one it may have a problem or develop a problem. The refurb probably already went through w.e problem or problems it was going to have and now is fixed and probably less likely to have a problem compared to a new one. There is also no discernable difference from a new tv.
EMG518 is offline
post #4 of 5 Old 03-01-2013, 08:28 AM
Otto Pylot's Avatar
Quoted: 1410 Post(s)
Liked: 880
I think it depends on a large part who the mfr is. Sony, LG, Panasonic, Samsung etc. would probably be ok if bought from a reputable dealer and you carefully read the warranty. Vizio, never.
Otto Pylot is offline
post #5 of 5 Old 03-01-2013, 09:07 AM
mengqi68's Avatar
I always buy from Amazon Warehouse Deals. Sometimes the price of a "Like New" or "Very Good" TV is 30-50% off a new one. If there is a problem it is very easy to return.
Occasionally you can even find products that are never opened but the package is damaged. Last week I bought a Samsung Galaxy Tab. The box was damaged but the tablet was 100% new. Sadly it is going back because the resolution rate is too low.
mengqi68 is offline
Reply LCD Flat Panel Displays
Samsung
