Down to 4 tvs...I don't know which to get. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-04-2013, 08:48 PM - Thread Starter
srd5335's Avatar
Hey guys. I have 4 tv's in mind around my 1500+/- budget. Now, I can't figure out which one to get.
Samsung UN55ES7500
LG Cinema Screen 55LM8600
LG Cinema Screen 55LM7600
Sony BRAVIA KDL55HX750
Any advice? Thanks!
srd5335 is offline
post #2 of 9 Old 03-04-2013, 09:23 PM
hoozthatat's Avatar
Liked: 38
Samsung UN55ES7500
Any advice? Thanks!
LG LM7600. Done and done.
The HX750 is subpar, the ES7500 is overpriced, the LM8600 is nonsense.
60F8000; RX-V367; TSi300 x2; YST-SW102; Harmony 650; Apple TV; Microsoft Xbox One Console; RF-HTS120;
xRite i1 Display Pro (OEM); CalMAN 5 Basic; ColorHCFR
hoozthatat is offline
post #3 of 9 Old 03-05-2013, 02:31 PM
dbe425's Avatar
I assume you are calling the LM8600 nonsense because the dual core CPU in no way justifies the price difference between it and the LM7600.
dbe425 is offline
post #4 of 9 Old 03-05-2013, 03:04 PM
hoozthatat's Avatar
Liked: 38
Absolutely.
post #5 of 9 Old 03-05-2013, 03:10 PM
dad0118's Avatar
Liked: 32
Samsung UN55ES7500
Any advice? Thanks!
I would pass on LG, inferior PQ IMO.
dad0118 is offline
post #6 of 9 Old 03-05-2013, 03:24 PM
hoozthatat's Avatar
Liked: 38
Of the models in question you believe the LM7600 is inferior to the ES7500 and HX750?
I'd agree with that assessment on the LM8600, but not the LM7600.
post #7 of 9 Old 03-05-2013, 03:35 PM
dad0118's Avatar
Liked: 32
I have not seen an LG TV i liked, nor read a review about an LG tv that is better than all other TVs in its certain class. The ES7500 is a solid TV at that price, that would be what I would pick.
dad0118 is offline
post #8 of 9 Old 03-05-2013, 03:43 PM
hoozthatat's Avatar
Liked: 38
I can respect your assessment of preferring the Samsung's performance. I call the ES7500 over-priced because, well it is.
If going the Samsung route is your/his choice, then go for the ES7100. The only extras the ES7500 gives you is the always useful integrated cam and a higher "CMR."
post #9 of 9 Old 03-05-2013, 09:24 PM - Thread Starter
srd5335's Avatar
Thanks for your replies. Still debating. If I debate long enough maybe the prices will drop.
srd5335 is offline
Reply LCD Flat Panel Displays
Samsung Un55es7500 55 Inch 1080p 240 Hz 3d Slim Led Hdtv , Lg Cinema Screen 55lm8600 55 Inch Cinema 3d Led Lcd Hdtv , Lg Cinema Screen 55lm7600 55 Inch Cinema 3d 1080p 240 Hz Led Lcd Hdtv , Sony Bravia 40inch Led Tv 3d Support Bravia Hx750 Kdl 40hx750 , Samsung Un46es7500 46 Inch 1080p 240 Hz 3d Slim Led Hdtv
