Will Universal Remote Fully Control LG TV's Equipped With Magic Remote - Seems Only Volume, Mute ON/OFF etcd Work - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-08-2013, 12:23 PM - Thread Starter
esoxlee's Avatar
Quoted: 17 Post(s)
I just tried using 3 different Universal Remotes to control a LM6200, but seems only the most basic operations will work. Like volume, On/off and mute. Anyone else also have this happen? Really don't like the magic remote and want to replace it with a universal remote.
esoxlee is offline
post #2 of 4 Old 03-08-2013, 10:52 PM
ethanj's Avatar
Use Harmony. It will give you full functionality.
ethanj is offline
post #3 of 4 Old 03-09-2013, 02:01 PM - Thread Starter
esoxlee's Avatar
Quoted: 17 Post(s)
I have 2 Harmony remotes, and 3 other universal. Each was programmed for an LG television but not one could do everything because each one controlled something different on the TV. Combined, they control everything. I ended up using one to learn from the other 4 to eventually control all the features. I'm really beginning to despise the magic remote.
esoxlee is offline
post #4 of 4 Old 05-31-2013, 06:13 PM
twindad2k1's Avatar
esoxlee - can you successfully use the OK/Enter/Select button on your universal remote with the LG TV? If so, how did you solve the issue with the OK/Enter button function, where the TV tries registering the remote? (have you experienced that?)
I've got my universal remote working with my LG TV (LM6700) to the point I can turn on/off the TV, access the menus, and navigate through the HOME screen...HOWEVER, I cannot press "OK" (or Enter) on the universal remote without the TV thinking I'm trying to pair/register a magic remote (since that is the button that is used to initially pair the magic remote to the TV).
So, in essence, I can navigate all the way to, say, the Netflix or Hulu apps on the Home screen, but I cannot open them! Instead, the TV tries registering the remote...that of course fails, and subsequently, so does the OK/Enter command. Very frustrating! mad.gif
Anyone have a solution to this?
kf
twindad2k1 is offline
Reply LCD Flat Panel Displays
