Samsung UN55ES6820 grainy from closeup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-08-2013, 04:10 PM - Thread Starter
rnazer's Avatar
Hi,
I recently purchased the Samsung 6820 and i noticed if i stand closer to the TV, (2-3 feet away) the screen looks grainy.
I previously had the Sony 46inch LED (HX750) and it did not look grainy from closeup.
Does anyone have any experience with this and how to resolve it? Is it the settings that i need to change? I read that if you turn the sharpness down from 40 to 20 it helps, but i did not notice a difference.
I am using HDMI cable from my cable box (same as i did with the sony tv)
Thank.
rnazer is offline
post #2 of 3 Old 03-09-2013, 10:58 AM
Steve S's Avatar
Liked: 46
Bigger tv=pixels bigger and further apart=grainier look when up close and magnification of any digital compression artifacts. Do you normally watch tv from 2-3 feet away?
Steve S.
Steve S is offline
post #3 of 3 Old 03-10-2013, 02:52 PM - Thread Starter
rnazer's Avatar
Sometimes I like to stand close up but not always
Does anyone have the optimal settings for a 6820? Would they be the same as the 6500?
rnazer is offline
Reply LCD Flat Panel Displays
