Official Sharp 60LE650U/70LE650U/80 Owner's Thread - Page 24 - AVS Forum
post #691 of 700 Old 09-17-2014, 08:22 PM
Tim James's Avatar
Wow, you guys were right about turning down the backlight to lessen the clouding effect. I went from 0 to -6. I can still see the clouding if I look, but it's just dim enough that it no longer bothers me when switching channels in a dark room.
nathan_h likes this.
Tim James is offline
post #692 of 700 Old 09-18-2014, 02:36 PM
nathan_h's Avatar
Quoted: 89 Post(s)
Liked: 91
Originally Posted by James Young View Post
Are there any settings i can change in game mode to reduce input lag?
Once you are in game mode, I think all those options are switched off (ie, you have the lowest lag, least processing available).
Just to be sure, make sure you turn off Motion Enhancement.
____________________
Build Thread:
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
nathan_h is offline
post #693 of 700 Old 09-22-2014, 10:22 AM
VegasFlyby's Avatar
Finally received the 70EQ series tv today. It was brand new, again, so that made me very happy. Screen looks great and I have to say I'm pretty happy. Sharp might have taken their time with my case but in the end they made it right in my eyes.
Still want to say the 70LE650U was a great tv. I would've been happy with it for years if the white dot issue didn't happen. Hopefully (knocking on wood) this new tv will be problem free.
Long Hair likes this.
VegasFlyby is offline
post #694 of 700 Old 09-22-2014, 06:57 PM
Liked: 0
Should I turn off digital noise reduction too?
What about monochrome and active contrast?
James Young is offline
post #695 of 700 Old 09-23-2014, 08:44 AM
nathan_h's Avatar
Quoted: 89 Post(s)
Liked: 91
I would turn them all off, but I cannot say I know for sure which impact response time.
Build Thread:
nathan_h is offline
post #696 of 700 Old 09-26-2014, 09:16 AM
Z-Mad's Avatar
Quoted: 138 Post(s)
Liked: 162
You should turn off all of those too - not necessarily because they effect input lag (which they don't), but simply for better image consistency without brightness fluctuation, etc...
Z-Mad is offline
post #697 of 700 Old 09-27-2014, 07:13 PM
impalanut's Avatar
Read all the posts and I still can't figure out if there is a way to really surf the net. I am trying to be able to get watch espn directly on the tv since I watch this frequently. I can get to their page but I am unable to get it to run. The button to push for logging in never activates. Can I use any other browser other than what is on the tv from the factory? Thanks
impalanut is offline
post #698 of 700 Old 09-28-2014, 09:42 AM
nathan_h's Avatar
Quoted: 89 Post(s)
Liked: 91
web browsing is VERY limited, and most (all?) streaming is not supported that way.
i recommend getting a third party solution (check what works before buying, i don't watch espn) like appleTV, roku, or chromecast. Will cost you $30 to $99 and give you much more reliable results.
Build Thread:
nathan_h is offline
post #699 of 700 Old Yesterday, 01:09 PM
Liked: 0
I would recommend Amazon fire tv. Its alot better than smart central and has the watch espn app. You can also configure xbmc for live tv.
Reply LCD Flat Panel Displays
Sharp , Panasonic Viera Tc L55dt50 , New Lc60le847u 60in Led Lcd 1080p 3d Tv 240hz Lc60le847u , Sharp Lc 60le650u 60 Inch Aquos Led Tv
Gear in this thread - 60le650u by PriceGrabber.com
