Official Sharp 60LE650U/70LE650U/80 Owner's Thread - Page 25 - AVS Forum
post #721 of 745 Old 12-10-2014, 09:38 AM
s2mikey's Avatar
Quoted: 225 Post(s)
Liked: 107
It is fairly common for larger LCD sets to have some uniformity issues. But, yours looks excessive to me. Sharps factory warranty probably has some in-house options, You'd have to call to find out.
For the record, I recently returned a 660U(newer version of your set in 70") due to poor performance and some bad clouding/backlighting issues. Went with another brand.
s2mikey is online now
post #722 of 745 Old 12-10-2014, 12:59 PM
johnfull's Avatar
Quoted: 334 Post(s)
Liked: 96
[QUOTE=mieszkoj;29783169]Hi,
Yes it does. OPC is off.
Using the OPC reduces the problem...
johnfull is offline
post #723 of 745 Old 12-10-2014, 02:32 PM
Liked: 0
Resolved
Thank you! OPC resolved the issue. I can live with that
mieszkoj is offline
post #724 of 745 Old 12-10-2014, 02:40 PM
johnfull's Avatar
Quoted: 334 Post(s)
Liked: 96
You can tinker with the Minimum and the Maximum range, along with the Contrast control
to get the look you want in all lighting situations. Sharp should make the OPC always on by default...
johnfull is offline
post #725 of 745 Old 12-10-2014, 03:40 PM
Liked: 0
Just an update. Now its very dark in the room. OPC did help a bit but still noticeable. I set the opc setting to adjust to the minimum as well. Only way the cloud effect goes away if i turn the brightness all the way up. Ill try to get in touch with Sharp again see if a tek can check this out. Will let you know.
mieszkoj is offline
post #726 of 745 Old 12-10-2014, 03:41 PM
Pianist718's Avatar
Quoted: 75 Post(s)
Ok, it's been 3 weeks ... I am liking the TV,. Set it to GAME and all is good with some minor adjustments.
I do however sometimes enjoy the Soap Opera effect for TV shows, concerts and discovery programs ...BUT ... as I switch to USER with my own settings, I still can't get the perfect color. Seems like I have too much blue. So, overall picture is a bit more saturated and colorful than GAME mode that I use for movie watching, but it's that crazy blue tone that I need to town down.
anyone have good settings they use for any preset other than GAME?
thank you
Sharp LC-80LE650U 80-inch, Denon AVR 4311ci, Ascend Sierra-1 NrT, Ascend HTM-200 (surrounds), Rythmik F12, Samsung BD ES6000, Denon DVD-2910 SACD/DVDa, Monster HTS 5100 MKI, Monster Z2 Biwire, Logitech Harmony One, Sennheiser HD600, Schiit Modi/Vali
Pianist718 is offline
post #727 of 745 Old 12-11-2014, 03:41 PM
theride66's Avatar
[QUOTE=wadalove;29748665]That's a great deal, and the new 660U is a very good looking TV. And you also have another year of factory warranty with the new 660U. Let us know how it goes. There are a number of people who are looking to see how it performs.
So i received it today and picture quality looks great. So far no white dots or any noticeable clouding. However, there is no GAME mode on this model and on Movie Mode there is no 10 point Greyscale. However, there does not appear to be any soap opera effect at all on Movie Mode or any other mode as there was on the 650u. It appears turning off the motion enhancement and film mode settings works better here than on 650u.
Also there are only 3 HDMI inputs compared to 4 on my 650u. Sucks but at least i don't have ugly white dots.
Also, Sharp told me that even with the replacement TV, my warranty expires at the same time as the old one. In other words, i have two weeks left. When i asked why? They said they don't extend warranties on replacement sets. Is this true?
theride66 is offline
post #728 of 745 Old 12-14-2014, 05:15 PM
Badbenz94's Avatar
[quote=theride66;29833018]
I am looking at this tv and there doesn't seem to be any reviews as of yet. So it sounds as though the picture looks better but only 3 HDMI ports? That is disappointing. Is the 4th port HDMI 2( both HDMI and MHDL compatible)?
Any other words of praise or frustration?
Chris
Badbenz94 is offline
post #729 of 745 Old 12-15-2014, 12:18 PM
Quoted: 35 Post(s)
Liked: 5
[quote=Badbenz94;29917609]
Chris
There's only a handful of owners at the moment. I'm satisfied with the TV's performance especially for about $500 to a grand less from the bigger competitors, but technically I'm still evaluating it until January 15th.
I may need to add this to the OP, but when configuring your mobile app to control the TV, the instructions on the app state to do the setup during 'Initial Setup' of the TV. If you do this after initial setup, you must power the TV off and remove the power from the TV completely (turn off power strip or unplug), then plug and turn it back on for the mobile app to control the TV.
There's also a bit of clouding present during a completely black screen. I did use the gentle massage technique to get out of most of the clouding...
I use all 4 HDMI ports just fine (Port 1: 4K AV Receiver with ARC Enabled to output audio from all of the rest of the HDMI ports and to automatically select surround sound mode based on content playback, Port 2: Apple TV, Port 3: 4K PC Gaming, Port 4: Chrome Cast). I praise the Picture quality and THX certification AV mode, and I also praise gaming at 4K resolution (the picture looks phenomenal like you are totally immersed in the game - a comment from a coworker who tried my 4K gaming setup out).
The only gripe I have is not about the TV, but about the performance of 4K video cards at the moment as they aren't powerful enough to play settings maxed out smoothly (disabling certain video settings helps with performance and 4K gaming is still extremely enjoyable).
wadalove is offline
post #730 of 745 Old 12-19-2014, 11:32 AM
tnord's Avatar
Quoted: 26 Post(s)
who needs 4 hdmi inputs on the tv? if you have that much gear you should probably have an AVR with like 11ty bajillion more inputs anyway.
i have the LE660, and I'm going to assume for now that any advice/settings/troubleshooting from the 650 would carry over?
so far i'm happy. i've only watched just a little bit on it, but i didn't notice any uniformity issues when viewing a blank screen and off angle. waiting for my monoprice order to show up so i can wall mount, then put the center channel on top of the TV stand, then run audyssey, etc etc.
this thing seemed like a pretty good deal at $800 for a 60'' and was reviewed favorably over on cnet.
DefTech BP2006TL/CLR2002/BP2X__Energy C50/CC50/ESW8__Yamaha A836__SVS PB1000
Denon X4000/1908__Pioneer Elite VSX-04__Mitsubishi PF5350 PreAmp & A4370 Amp
PS3 / Pioneer DV-400V / Samsung BD-P3600
Sharp 46D64 / 60LE660__Samsung 32B360
A gaggle of unknown ceiling speakers
tnord is offline
post #731 of 745 Old 12-23-2014, 05:26 PM
theride66's Avatar
What settings are you using? By the way, mine had a problem where the power on button would't work sometime after a whole day's use or it would power on in the night on its on. Make sure wallpaper mode is disabled and you may have to call Sharp to do a factory reset, which i had to do today.
post #732 of 745 Old 12-27-2014, 06:45 AM
tnord's Avatar
Quoted: 26 Post(s)
i'm still on factory default settings, i tried some that were mentioned at the beginning of this thread (Z-Mad?), but they didn't work at all.
tnord is offline
post #733 of 745 Old 12-27-2014, 10:24 AM
Electone's Avatar
Netflix soap-opera effect
I just purchased the 660U and everything is fine except I cannot turn off the soap-opera effect when we watch Netflix. When I press the menu button, it does nothing. I am able to change settings for every other input. Can someone help? Thanks!
Electone is offline
post #734 of 745 Old 12-27-2014, 10:27 AM
Liked: 0
I need 5 hdmi inputs...xbox one, ps3, nexus player, htpc, cable box and dvr... But I'm a bit weird lmao...
And where can I get one of those bajillion things??? Thinking I might need some more inputs... Haaha
GoodB0Y is offline
post #735 of 745 Old 12-28-2014, 05:01 PM
theride66's Avatar
Make sure "film mode" is set to off or standard if you want a little bit of soap opera. You should be able to change settings for each input
post #736 of 745 Old 12-28-2014, 08:08 PM
Electone's Avatar
I was able to find it. You have to select the Home Network input and then adjust the settings there. The manual doesn't really cover this.
Electone is offline
post #737 of 745 Old 01-07-2015, 07:13 PM
Liked: 0
Trouble playing HTPC video in XBMC through Denon 1613 to the 60LE650U (both HD formats labeled by XBMC - 1080p and 720p). The picture flickers now and then with minor noise and distortion, and a horizontal line will appear near the bottom and travel quickly up the screen (now and then meaning a few times per minute so it can't continue as-is). This seems to happen during faster moving scenes or when camera angle/scene changes. Tried searching forum threads and I got back too much stuff that didn't sound like this at all. Discouraged, I posted in this thread because this TV is the only newly introduced variable... Here's what I mean...
I just got this TV. It's working good for everything except playing my HTPC through my Denon to the TV. Setup is HTPC laptop to Denon 1613 DVD port via HDMI to Sharp TV HDMIport1 via solo HDMI cord). I had this same exact setup for years to run XBMC movies with my old 7-yr old Sony and it worked just fine - real clean HD video and little to no visual distortion ever. Simply swapping out TVs and taking the HDMI cord out of the Sony port and plugging it into the Sharp port, and the fluttering and traveling horizontal lines showed up. (Note: XBMC videos play very clear on the HTPC laptop screen and on my bedroom Samsung via HDMI). But here's what gives me hope - If I plug the HTPC directly into another HDMI port on the Sharp and play XBMC videos, all issues practically disappear and video runs almost perfect. So, it seems to be something with how the Denon and Sharp are interacting?
I'm not at all smart with this stuff, so if anybody here has a few simple solutions to try, I'm game. I know just enough to be dangerous, so please err on the side of insultingly simple explanations! Also, my TV is above my fireplace across the room from my receiver and HTPC so simply running another direct HDMI cord from receiver to TV means buying another 50' cord and climbing through the attic dragging more cord. Would hope to avoid that if you all have other suggestions where I can keep the single HDMI cord setup to the TV.
Please help this noob!
PS - Big thumbs up to those of you who suggested the Disney WoW disk - Worked great!
bernieholliday is offline
post #738 of 745 Old 01-09-2015, 09:05 AM
ctiq21's Avatar
What RGB Output ranges are people using with this TV? I have mine set to standard on my Xbox and Blu Ray and it seems correct. Anyone using Enhanced black levels?
ctiq21 is offline
post #739 of 745 Old 01-13-2015, 05:40 PM
schizbomb's Avatar
Hey. Just bought a 660U (i know this is a 650U thread) but they are close enough.
Anyone have an issue where the backlight setting won't work correctly?
Let me explain further. I have backlight set to 7.
When I fire up my 70" 660U the backlight is dim. I go to the settings menu and see it is showing +7. I scroll to the menu and then set it to +8 and THEN the backlight turns up to +8.
Any ideas?
schizbomb is offline
post #740 of 745 Old 01-13-2015, 06:46 PM
nathan_h's Avatar
Quoted: 153 Post(s)
Liked: 103
Sounds a bit like OPC in on.
____________________
Build Thread: "Nathan's Theater in Search of....".
nathan_h is online now
post #741 of 745 Old 01-13-2015, 07:01 PM
schizbomb's Avatar
I looked for OPC in the menus and I do not see such a setting.
Maybe these models are more different than I thought
post #742 of 745 Old 01-14-2015, 02:07 PM
nathan_h's Avatar
Quoted: 153 Post(s)
Liked: 103
I don't know. I would try:
Turn off auto backlight, power saving, etc and see if that helps.
post #743 of 745 Old 01-14-2015, 04:31 PM
nathan_h's Avatar
Quoted: 153 Post(s)
Liked: 103
For those of you that have had a set replaced by Sharp under warranty, it sounds like everyone got a re-furb?
Were you able to check it out before accepting it?
Now that it has been a while, have you had the same issues?
Anyone get one replaced by Costco using their warranty (which extends for the year after the Sharp warranty ends)?
post #744 of 745 Old Yesterday, 05:01 PM
nathan_h's Avatar
Quoted: 153 Post(s)
Liked: 103
Turns out, the Costco warranty tries to match the Sharp one 100%. I've got a "refurb" on the way.
I'm a little worried the white dots might return, but the replacement comes with a 90 day Sharp warranty and then another 8 months or so of Costco coverage, so I'll have eagle eyes during that time.
Reply LCD Flat Panel Displays
New Lc60le847u 60in Led Lcd 1080p 3d Tv 240hz Lc60le847u , Panasonic Viera Tc L55dt50 , Sharp , Sharp Lc 60le650u 60 Inch Aquos Led Tv
