Vizio screen shot.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-10-2013, 09:15 PM - Thread Starter
mrcaptainbob's Avatar
The dog bone 'accidentally' flew into the Vizio screen and now it looks like it has a bullet hole in it. I doubt JB Weld will do any good. Is it possible for me to replace the screen? The old tv's with the picture tube were no problem, but I have yet to delve into the 'new' stuff.
mrcaptainbob is offline
post #2 of 9 Old 03-10-2013, 09:26 PM
indept's Avatar
Quoted: 84 Post(s)
Liked: 92
indept is offline
post #3 of 9 Old 03-12-2013, 11:53 AM - Thread Starter
Yeah, ouch is as fine a descriptor as anything I've come up with so far!!biggrin.gif Are new panels available for these kinds of tv's?
post #4 of 9 Old 03-13-2013, 08:31 AM
sitlet's Avatar
It' absolutely possible, however it's normally not worth it. Since you didn't post a model number, we can't tell you exactly. However you are not going to have an easy time finding a brand new screen, and if you do, it will likely cost 300-400 dollars.
sitlet is offline
post #5 of 9 Old 03-16-2013, 08:19 PM - Thread Starter
Hi, Sitlet. The info is:
Model: Vizio VL470M
Part: 102 400 800 22
Serial: LUKEHBK3800286
Thanks for the help.
post #6 of 9 Old 03-18-2013, 08:26 PM - Thread Starter
Where can I scare up a new screen?
post #7 of 9 Old 03-19-2013, 09:56 AM
sitlet's Avatar
Ebay.
sitlet is offline
post #8 of 9 Old 03-20-2013, 09:21 PM - Thread Starter
Thanks, Sitlet. I followed your suggestion and found quite a few 470's there. But there always seems to be different characters before or after the 470. Do I need to match the exact model number? That is, VL470M ? Or is 470 M close enough?
post #9 of 9 Old 03-21-2013, 12:19 PM
sitlet's Avatar
I'm not too familiar with those models. However, I would assume 470 M is the same as VL470M.
sitlet is offline
Reply LCD Flat Panel Displays
Vizio , Lcd Hdtv
