Official 2013 LG xxLA7400 Owner's Thread. - Page 44 - AVS | Home Theater Discussions And Reviews
post #1291 of 1298 Old 01-25-2015, 10:20 AM
guyver2077's Avatar
Originally Posted by E55 KEV View Post
I have a 55LA7400 also but none of the problems you have. I just want to note that I also have a same year 55GA7900 and the Wi-Fi always seem to need to be reconnected quite frequently. I had an Ethernet cable plugged in back and after I removed the cable from back of TV the performance was better. TV was prolly defaulting to the Ethernet cable.
Additionally, one night my 7900 was completely unresponsive to remote and the buttons on the side. I could not access Smart features, menu, inputs or settings. I was ready to call for service until I unplugged it from the wall for a few minutes it started performing normally. Perhaps the set had a power surge. I recently moved TV to another room and now realize I did not have TV on a surge protector.
Hope your issues can be fixed.
Consider yourself lucky. It happened sometime last year and I guess I just figured that a future update would of fixed it. I would always update normally whenever the tv detected an update via wifi. One day after I took one of the updates, the tv was just never the same. Wifi is totally broken for me right now. I have to plug in ethernet to get it to 'somewhat' connect. Even then with ethernet, the apps are mostly broken. It's to the point that I just kinda want to get rid of it or sell it but I don't want to sell it as a 'broken' smart TV.
The TV itself does function however perfectly, just all the smart features are essentially useless and navigating menus can be painfully slow at times. I can't use the features I used to like best about the TV like the LG smart remote app that allowed to take screenshots, etc. Luckily I have other sources for netflix, etc.
guyver2077 is offline
post #1292 of 1298 Old 01-25-2015, 05:10 PM
dark41's Avatar
I don't have anything new to offer. If the suggestions on the last page don't work, I'd try contacting LG support. Hope you get it sorted.
dark41 is offline
post #1293 of 1298 Old 01-26-2015, 07:56 PM
E55 KEV's Avatar
Quoted: 12 Post(s)
Originally Posted by guyver2077 View Post
hey guys,
well this thread is my last hope. Many months ago my 55LA7400-UD (US) model to a firmware update and ever since the performance totally went to hell. Wifi stopped working and the menus are painfully slow. Apps do not work.
Im currently on 05.08.14
Is there any way to either fix this issue or revert back to original firmware? I've run out of options.
Tonight my 55LA7400 is getting update 05.09.02. Previous update was 05.08.04. I never got 05.08.14.
dark41 likes this.
Click For My Website - www.E55AMG.com
E55 KEV is offline
post #1294 of 1298 Old 01-26-2015, 08:09 PM
guyver2077's Avatar
Thanks for heads up. I'll have to plug in my ethernet to see if I can see an update. Crossing my fingers but doubtful ill see improvements.
post #1295 of 1298 Old 01-27-2015, 04:35 PM
guyver2077's Avatar
Wow.. amazing. It only took half a year but it seems this latest update has resolved my issues. Wifi works again, menu UI seems responsive, and I even launched some netflix. I don't think ill risk taking another update again. TV is finally back to normal.
dark41 and dioptric like this.
post #1296 of 1298 Old 01-27-2015, 05:13 PM
dark41's Avatar
Glad it worked out for you.
dark41 is offline
post #1297 of 1298 Old 01-27-2015, 08:43 PM
dioptric's Avatar
Did this by any chance give the TV the 3dgo app? Lg and sensio has an agreement that went into effect on Jan 1st. I saw the update but didn't install it yet. Thanks for any info
dioptric is offline
post #1298 of 1298 Old Today, 05:38 AM
Sting5920's Avatar
Since this last update I see two changes in Netflix
first the welcome page is new
but second - it appears that the "swirly wheel" appears less often - but the picture can be quite "grainy" at times
but a page back I was whining about my ISP and that drama is still with us
HDTV: LG 47LA7400
Blu-Ray Player: BP530 3D Surround
Keyboard: Logitech K400R
OTA only - Antenna: Ebay junk - [works great]
AV Receiver: Denon AVR 1713 5.1 3D
Center Speaker: Cambridge Audio S50
Front Left Right: Cambridge Audio S70
Surround: Acoustimass® 5 Series II system
Sub-woofer:  Yamaha
Sting5920 is online now
Reply LCD Flat Panel Displays
Lg 47lm8600 Led Lcd Hdtv , Lg 55la7400 55 Inch Cinema 3d Led Smarttv , Lg Cinema Screen 55lm8600 55 Inch Cinema 3d Led Lcd Hdtv , Lg Cinema Screen 55lm7600 55 Inch Cinema 3d 1080p 240 Hz Led Lcd Hdtv
