Official Samsung UNxxF8000 Owners Thread - Page 178 - AVS Forum | Home Theater Discussions And Reviews
 118Likes
post #5311 of 8570 Old 02-19-2014, 07:00 PM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
I do like the black levels on the tv. I am good now with my tv settings. Just enjoying the tv now. Tired of changing various settings to get the perfect pic. Lol smile.gif
Samsung UN75F8000 LED TV, NAD T-777 (7.2 Receiver), Oppo 103, Sony PS4, Panamax MR-5100, 7 Paradigm Reference series 8" in ceiling speakers (AMS-150R) - 30 degree tilting speakers, 2 Paradigm SE Sub, universal remote MX-450, universal advanced RF base station MRF-3501. Pics here.
HPQ is offline
post #5312 of 8570 Old 02-19-2014, 07:08 PM
sideout99's Avatar
Liked: 36
LOL  I hear Ya.  How long you had yours ?  Got mine late November 2013.  ASIS, I enjoy my TV very much.  Just feel it could be a little better.
sideout99 is offline
post #5313 of 8570 Old 02-19-2014, 07:25 PM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
I got mine Dec 13th. smile.gif I suspect it is a Nov build. US02 panel.
HPQ is offline
post #5314 of 8570 Old 02-19-2014, 09:36 PM
sriggins's Avatar
HI!
Edit: I moved the TV down 2 holes ( I could not go all three as the bridge between the lower slots lined up right over the lower hole) and I moved the trans spacers on the outside of the bracket. I feel a lot better about that. The weight on the bolt is now closer to the TV.
I bought a transdec TV stand for my 65F8000. I love everything about it but the bolts it came with were too long.
http://transdecointl.com/td550hb.htm
The stand came with spacers and suggested using them if the bolts are too long. I used the M8x32mm bolts. They stuck out about the size of the 14mm plastic spacers
So following the directions, I put the thin rubber washer, then the plastic spacer, then the mount, then the metal washer and bolt through it all. It was able to cinch down pretty well.
Is this the right way to mount a 65" TV? It sure looks like the mount is a good distance (14mm) from the TV, so the pressure point is a bit away from the TV.
Also the TV is slanted to the left a little. There was a little slop in the holes (the bottom bolt goes through a slot) so I guess I will take it down and see if I can move the bracket up as much as the hole slop will allow me. The rest of the stand seems perfectly level.
Should I get shorter bolts and remove the spacers? Or is this appropriate for 22.5 lbs on each bolt?
Steve
sriggins is offline
post #5315 of 8570 Old 02-19-2014, 10:06 PM
leftyguitar1963's Avatar
Quoted: 127 Post(s)
Liked: 172
I have a dilemma.
Recently having purchased a 60F8500 pdp I am bummed at the directional buzzing from 13ft+ back.
I am within the return window & not wanting to play the panel lottery for next buzzer or not, I am now considering a F8000.
But, I am hesitant because of past Sammy lcd uniformity, clouding, vertical banding & flashlighting. I have read several reviews that say all of this had been vanquished with the F8000. If this is true I am going to be hard pressed not to go for the swap & acquire the 60F8000.
I've heard from a few users here that the 65 is a banding demon & can't see paying $500 more for 4.5 inches anyway.
Are there any former F8500 owners here that went with the F8000? And if so, which had the better 3D? 24p cadence issues and motion resolution are of some importance too.
Mainly using for HD(DirecTV/Fios), Blu-Ray & some SD programming. No gaming or HTPC usage.
Thanks for your time.
Sony XBR-55A1E
Sony XBR-65X850C
Sony UBP-X800
leftyguitar1963 is offline
post #5316 of 8570 Old 02-19-2014, 10:57 PM
sriggins's Avatar
My new 65F8000 has some banding and brighter areas on the sides. It could be calibration, or my panel. I have not decided yet. It's not terrible and I'm becoming less picky, but for $3000 it should be pretty damn close to perfect smile.gif
sriggins is offline
post #5317 of 8570 Old 02-20-2014, 02:35 AM
SJMAYE's Avatar
A simple setup question. During setup I could not set up my cable tv set top box because I don't use one. I use an HTPC for TV reception and DVR recording which Samsung does not support. As a result in the Smart Hub I have no TV icon at the top. I don't fully understand why it is missing. Does it automatically get rid of the icon and associate smart hub panel when you cannot set up the cable box?
What sold me on the TV when seeing it in the store was this TV panel showing live tv in the upper left. Now I don't see that smart hub panel at all.
SJMAYE is offline
post #5318 of 8570 Old 02-20-2014, 03:50 AM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
Congrats! Once you apply Buzz settings, you should see improvement. Take some pics! smile.gif
HPQ is offline
post #5319 of 8570 Old 02-20-2014, 03:52 AM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
I use antenna so can't say much in regards to this.. I suspect for the channel details, it is looking for scanned channels. Are you able to scan channels?
HPQ is offline
post #5320 of 8570 Old 02-20-2014, 03:58 AM
ftimster's Avatar
I was hoping this would not be an issue with Sammy's 65" flagship.....it should be much better than the screen issues I'm hearing about and currently experiencing with my 65" 6350 and 60" 7100 mild clouding and slight banding ( not horrible at all but noticeable) I really want to get the 65" 8000 as I was under the impression that for 3 grand and top of THERE line I would escape the flaws in their mid to lower end TVs 65" owners please chim in :-) as my finger is on the trigger. The only other concern for me is living in Alaska!!! I can only buy from Samsung online amazon and all other big box online stores won't ship to Alaska......soooooo two weeks shipping at worst try new set and if I need to try a new panel due to clouding or banding issues 2 weeks shipping back and I'm out of my 30 day no questions asked warranty is this correct. ( no TV repare guys where I live ) if anyone can talk on the quality of there 65 inch 8000 would be much appreciated I really want to pull the trigger on this Thanks AWSOME forum
ftimster is offline
post #5321 of 8570 Old 02-20-2014, 04:02 AM
ftimster's Avatar
Lol or just go for it and I'll be happy....
ftimster is offline
post #5322 of 8570 Old 02-20-2014, 04:59 AM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
Clouding and all other issues associated with edge Lit TV's will always be there -- it is part of the edge Lit technology!
They are more minimized for sure with the F8000 and with Buzz settings or by having it calibrated, you can further minimize those issues. You can't eliminate it but you can live with it.
HPQ is offline
post #5323 of 8570 Old 02-20-2014, 05:00 AM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
Originally Posted by Chris4205 View Post
Can someone link me to to the most recent setting?
Thank you
Most people are still using Buzz settings which are on the first page of this thread. smile.gif
HPQ is offline
post #5324 of 8570 Old 02-20-2014, 06:16 AM
aizen79's Avatar
hi guys any input on flashing a firmware from different area....my tele ia UA55F8000AR*** and software is 1113.1. Would like to flash firmware for UA55f8000AT*** now @ 1115....? Any input?
aizen79 is offline
post #5325 of 8570 Old 02-20-2014, 06:48 AM
sideout99's Avatar
Liked: 36
Seems to me that would not be a good idea but I can't say for sure.
post #5326 of 8570 Old 02-20-2014, 07:45 AM
ModernCowboy's Avatar
hey guys , i have a small problem with my tv and hope you guys can help me . when the tv is off i have to press the red power button on the remote controll several times to turn the tv on , it just simply doesnt turn on with the first push , but when the tv is on the remote works perfect without any delay , again when i want to turn it off it doesnt turn off with the first effort , i have to press the power button 6 or 7 time to turn it off . i tried getting closer to tv , changing battery and ... but nothing fixed it .
second problem is that i cant see real 3d on this tv ( actually it is my first exp with 3d ) . what i mean is that 3d movies doesnt have that huge depth for me , i mean its just like the 2d with small 3d effects that doesnt impress me at all , fast scenes also have a lot of blur ( or whataver it is called ) and it gives me some kind of headache too , my eays are not  comfortable with it and i rather watch movies in 2d , is it just me or the 3d is not that awesome effect and tech i was expected . ( also tried some calibrations and other settings but overall its the same , note that the 3d depth setting on my tv is gray and is set to 5 i guess ) .
(pardon my bad english )
ModernCowboy is offline
post #5327 of 8570 Old 02-20-2014, 07:55 AM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
That is very strange that you have to press the power button several times to turn on or off. I have no issues with the samsung remote. I do use a universal remote and for that one also, I have no issues.
Have you tried a universal remote?
For the 3d, are you seeing the 3d app on the smart hub or you put in a 3d blu ray movie into a 3d blu player and used a 3d AVR ?
What is the 3d movie you watched?
HPQ is offline
post #5328 of 8570 Old 02-20-2014, 07:55 AM
bellest's Avatar
Liked: 30
Assuming your set came with 2 remotes, are both behaving this way?
And, regarding the 3D, (may be a silly question), but are you enabling 3D via the remote control? This is my first experience with home 3D abd I was quite impressed!
bellest is offline
post #5329 of 8570 Old 02-20-2014, 07:56 AM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
I also had no issues with 3d but for me, I put in the 3d movie in the oppo and on the tv, it automatically changed to 3d. I didn't need to do anything on the remote. The TV just switched once the signal was received from the oppo. smile.gif
HPQ is offline
post #5330 of 8570 Old 02-20-2014, 08:00 AM
bellest's Avatar
Liked: 30
I don't own any 3D discs, I just grabbed something from OnDemand and had to enable it manually.
bellest is offline
post #5331 of 8570 Old 02-20-2014, 08:56 AM
sriggins's Avatar
I guess, it's just too bad. I think the clouding in the corners got worse once I hung it. I hand tightened the bolts, but I think it's doing something to the panel.
sriggins is offline
post #5332 of 8570 Old 02-20-2014, 09:23 AM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
What are your settings set to? Backlight? Take a picture and put it up here.
HPQ is offline
post #5333 of 8570 Old 02-20-2014, 09:24 AM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
On demand, I am not sure.. If you have a 3d blu ray that would be best to test. smile.gif
HPQ is offline
post #5334 of 8570 Old 02-20-2014, 09:29 AM
bellest's Avatar
Liked: 30
I concur, I think I'll grab Gravity and check it out!
bellest is offline
post #5335 of 8570 Old 02-20-2014, 10:31 AM
nosumer's Avatar
Just coming to say that I'm watching Canada vs. US women's gold hockey finals on my set, and it's seriously like being there. Trying out the AMP on Smooth, and it works really well for sport, I can see why it exists at all now.
nosumer is offline
post #5336 of 8570 Old 02-20-2014, 10:49 AM
sideout99's Avatar
Liked: 36
Yeah, hockey really shines on the F8000.
Big LA Kings fan, watch them all the time, though my AMP is on Clear.
I watch everything AMP on Clear.
post #5337 of 8570 Old 02-20-2014, 12:42 PM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
I have seen the below 3d movies on the F8000 so far.
How to train your dragon
Despicable Me 2
Cloudy with the chance of Meatballs
HPQ is offline
post #5338 of 8570 Old 02-20-2014, 12:57 PM
jedi29's Avatar
Quoted: 84 Post(s)
Liked: 60
So you think this is quality ?
Check out this remote ( see attachment ) , it`s the one I got in July because it did not come in the box.
Me 
PS:
I e-mailed Samsung the picture and they wanted to know what happened , and I said , the buttons came off while I was playing a game of chess. I also stated that prior to that I had noticed the arrow buttons discolored.
I should get a replacement , I hope. DefectiveRemote.jpg 859k .jpg file
jedi29 is offline
post #5339 of 8570 Old 02-20-2014, 12:58 PM
sideout99's Avatar
Liked: 36
Despicable Me 2
AH, good dad.  Watching movies with the kids  :p
I thought Avatar 3D was pretty good 3D
post #5340 of 8570 Old 02-20-2014, 01:02 PM
sideout99's Avatar
Liked: 36
Me 
PS:
I was lucky enough to get that cheapo remote with my TV, along with the one with the touch pad.  The free remote does not even have a 3D button.  I am not found either of the touch pad remote.  I ordered the silver one on Amazon and like it.  Still need to set up my Harmony One  *sigh*
Reply LCD Flat Panel Displays
Samsung , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv , Samsung Un55es8000 55 Inch 1080p 240 Hz 3d Slim Led Hdtv , Westinghouse Ld 3235 32 Inch Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv , Lg 47lm8600 Led Lcd Hdtv , Samsung 55 Inch 3d Ultra Slim Smart Led Hdtv Un55f8000
