Official Samsung UNxxF8000 Owners Thread - Page 208 - AVS Forum | Home Theater Discussions And Reviews
 119Likes
post #6211 of 8564 Old 03-24-2014, 09:20 AM
bellest's Avatar
Liked: 30
Originally Posted by s_mack View Post
Man, I can't seem to get a replacement power supply board for my dead UN55F8000!!!!
Part # BN44-00649A
Samsung is out of stock, but they charge almost $300 anyway. I see them online for $80-ish, but NONE of the companies seem to actually be in business! Either their phone numbers don't work or they work but nobody answers. I got up at 6am (opening time for one of them) to get on this ASAP and its been 2 hours and I haven't gotten through to anyone.
There are a few on ebay but they're higher priced AND no guarantees.
This sucks ass.
Since it seems you're running out of options, it may be worth taking the PS to an electronics repair shop and see if they can fix it.
bellest is offline
post #6212 of 8564 Old 03-24-2014, 09:22 AM
s_mack's Avatar
Ahhh... but I'm *#$(ed on that front too! The component that blew is completely unidentifiable! I don't know if Samsung has a habit of using custom labelled parts or what, but no electronics supply searches come up with anything for the markings on the bad component.
s_mack is offline
post #6213 of 8564 Old 03-24-2014, 10:03 AM
bellest's Avatar
Liked: 30
I "think" this is a pic of your PS:
https://www.shopjimmy.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/s/h/shopjimmy-bn44-00649a-top.jpg
If so, you may be able to pull the entire board and take it to a repair shop. It sounds like you have nothing to lose at this point...
bellest is offline
post #6214 of 8564 Old 03-24-2014, 10:14 AM
s_mack's Avatar
Sure, but to repair what? If the part is unidentifiable, then a repair shop is going to be just as lost as I am. Unless you mean an authorized Samsung repair shop.... already tried that. 1) They told me they can't get the part because its for a US model; 2) They don't "fix" boards, they replace them. 3) "it would be cheaper to buy a new TV" ($3000 TV vs $80 part... thanks buddy).
You are correct about that being the right board.
s_mack is offline
post #6215 of 8564 Old 03-24-2014, 10:23 AM
bellest's Avatar
Liked: 30
A reputable repair shop will have the the equipment needed to identfy the failed component(s). I was a controls engineer and maintenance manager at a large automotive manufacturing facility. I cant tell you how many times I sent obsolete, complex electronic components out for repair and these guys would save the day, without diagrams or documentation!
It's definitely worth a few phone calls if you have anyone in the area, to see if they're up for the task!
bellest is offline
post #6216 of 8564 Old 03-24-2014, 12:30 PM
aizen79's Avatar
hi guys how can I remove the "flash" effect which happens when a bright object(eg mouse cursor) is introduced in a completely dark screen....i understand its when the LED turn on.Its noted when the tv is watched in complete darkness. But is there a way to minimize it? By increasing the brightness to 48(from 45...in Natural mode) appears to get rid of it but the picture looses its black level
aizen79 is offline
post #6217 of 8564 Old 03-24-2014, 03:48 PM
imdigitalman's Avatar
Hello I normally dont reply(lurker of sorts),but I am a retired certified electronic technician .TV's was my speciality.Repaired too many to count..What you need to do is find a Samsung authorized repair shop .They will have a service manual with pictures and identifable part .Hope this helps.Good luck
imdigitalman is offline
post #6218 of 8564 Old 03-24-2014, 04:40 PM
I see ebays has the board you aare looking for.The seller has 100% feedback and 14 day return policy.http://www.ebay.com/itm/SAMSUNG-POWER-BOARD-BN44-00649A-UN55F8000BFXZA-UN55F8000BF-UN55F8000-/171269582384
bellest likes this.
post #6219 of 8564 Old 03-24-2014, 07:09 PM
FltTester's Avatar
Liked: 24
Originally Posted by sammiesamson View Post
WoW, looks like you really know alot about how the picture should really look like. I will have to listen to your comments, and try to get used on the settings that you wrote. Maybe we at home don't have setted the TV's correctly, we usually set them just by the eye and and some preferences... But if you're saying that the settings you wrote are close to the optimal settings of what the picture should really look like, I will try to get used to that settings.
I would say either you have a faulty TV, or you are being too critical of the picture. A good picture doesn't take prolonged "getting used to". One of the different groups of settings given in this thread should provide a very good picture for almost anyone. Have you compared this set to another high quality TV?
sammiesamson likes this.
FltTester is offline
post #6220 of 8564 Old 03-24-2014, 08:19 PM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
I tried the various settings mentioned here under movie, natural, and standard. All different settings. Now, I am more confused.. smile.gif
Samsung UN75F8000 LED TV, NAD T-777 (7.2 Receiver), Oppo 103, Sony PS4, Panamax MR-5100, 7 Paradigm Reference series 8" in ceiling speakers (AMS-150R) - 30 degree tilting speakers, 2 Paradigm SE Sub, universal remote MX-450, universal advanced RF base station MRF-3501. Pics here.
HPQ is offline
post #6221 of 8564 Old 03-24-2014, 11:42 PM
s_mack's Avatar
That's who I WAS talking to... the authorized Samsung repair shop.
I'll just buy that over-priced one off ebay.
s_mack is offline
post #6222 of 8564 Old 03-24-2014, 11:53 PM
sammiesamson's Avatar
I hope it's just me... Well my uncle has an LG, I think it's some 6000 series, but the picture looked nice. I didn't see any stuttering. And it's more than a half cheaper than mine. But it's 40 or 42".
Then I visited a neighbour which has a Sony W9 and the picture was even worst than on mine. But I think he doesn't have a clue either how he should set it... Basically I can say that I didn't see much of the new high tec. TVs. Only in the store but I mainly watched just an F7000 there.
sammiesamson is offline
post #6223 of 8564 Old 03-24-2014, 11:57 PM
romito442's Avatar
what is the best calibration to get rid of flashlighting from the corners?
romito442 is offline
post #6224 of 8564 Old 03-25-2014, 12:07 AM
DRN94's Avatar
Quoted: 68 Post(s)
Liked: 92
You'll want to try the contrast ratio boosting trick. I recommend using these Standard Mode settings during the day and the Movie Mode settings at night. Push the backlight as high as you can before noticing any flashlighting.
Picture preset: Standard
Backlight 8
Contrast 100
Brightness: 46
Sharpness: 0 (20 max)
Color: 50
Tint: G50/G50
Picture size: Screen Fit
Dynamic Contrast Off
Black Tone Off
Flesh Tone 0
Color space Native
Gamma 0
Color tone Warm2
Digital Clean View Off
MPEG noise filter Off
HDMI Black level Low
Film Mode Auto1
Auto Motion Plus On (LED Clear: On, Anti-Blur 10, Anti-Judder 0)
Smart LED High
Cinema Black On
White Balance:
R-Offset 23
G-Offset 24
B-Offset 24
R-Gain 0
G-Gain 15
B-Gain 50
Picture preset: Movie
Backlight 5
Contrast 95
Brightness: 46
Color: 50
Tint: G50/G50
Black Tone Off
Flesh Tone 0
Color space Native
Gamma 0
Color tone Warm2
Film Mode Auto1
Smart LED High
Cinema Black On
White Balance:
R-Offset 25
G-Offset 25
B-Offset 25
R-Gain 32
G-Gain 42
B-Gain 50
DRN94 is offline
post #6225 of 8564 Old 03-25-2014, 01:08 AM
ftimster's Avatar
I agree warm 2 is just a little to much my skin tones look amazing on warm 1 or standard just my pref.... I'm just glad it only took one replacement to get my TV US02 , question is the calman 5 enthusiast calibration equipment (1000 dollars) set up worth it would like to learn how and help some of my friends here in alaska cal there sets looks like fun and interesting I'm a geek anyway....
ftimster is offline
post #6226 of 8564 Old 03-25-2014, 01:57 AM
aizen79's Avatar
hey guys wanted to share some pics of 720p movie played using tweaked potplayer from laptop. Highly recommend this software for quality video
since our tvs like "the croods" dont like the darkness, I have positioned the light behind the tele to improve the perceived black levels
aizen79 is offline
post #6227 of 8564 Old 03-25-2014, 03:36 AM
SJMAYE's Avatar
Will my F8000 connect to my Logitech Bluetooth speakers? If so, can I still control the volume from the Samsung remote?
SJMAYE is offline
post #6228 of 8564 Old 03-25-2014, 06:36 AM
bestboy1's Avatar
I agree the skin tone may look a little off in Warm2, but the other colors pops lot more in Warm2 compared to Warm1 and Standard. Did u try watching in a dark room with Warm2, the skin tone is not as bad in a dark room with Warm2.
bestboy1 is offline
post #6229 of 8564 Old 03-25-2014, 07:01 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2052 Post(s)
Liked: 2216
Been reading your story. We sell on e-bay as well, as long as you get a receipt from a valid company your warranty is in effect. We always e-mail invoices to our clients, even if an item is bought thru us on e-bay. See and e-bay invoice or a paypal invoice is a receipt of money transfer it is not an invoice, as the manufacturers know e-bay and pay pal "technically" sell NOTHING ! Big loop hole. We do not put Samsung's on e-bay as Samsung does not like it, otherwise we would.
Did you take your TV in the repair shop yet ? Did this private individual give you a receipt from where he bought it from ? Can you contact him to get this receipt ? Did you pay with Pay Pal or a credit card ? If you would just drive the unit over the border and get it fixed for free, Samsung Canada does not honor Samsung USA warranties, and vise versa.
Originally Posted by bslep View Post
I'm thinking about getting the UN75F8000. I currently have a Sharp LC-80LE632U. I'm wondering if anyone on this thread has made a similar move and what your thoughts are between the two. Any other advice is welcome. Thanks. Bob
Saw there was all ready some good comments on this topic, however in all fairness this is the low end Sharp compared to the High end Samsung. To compare a Samsung 8000 to the high end sharp you would find the picture quality is much closer, the Sharp still has a semi gloss screen compared to a glossy Samsung screen. The 75" has fallen in price last week but is still pricy compared to the Sharp. The semi gloss screen on the sharp helps with reflection big time, however the trade off is the picture not being as good, ever wonder why the manufacturers about 3-4 years ago switched to a glossy screen ? You guess it, throw a glossy screen on an older semi gloss screen and watch how much better the picture looks, but now you have glare. How do I know this you may ask, I used to do picture framing. They make non-glare glass and boy does it work, but the picture is muffled behind the glass ...........
Cleveland Plasma is online now
post #6230 of 8564 Old 03-25-2014, 07:35 AM
bellest's Avatar
Liked: 30
I believe the only bluetooth speaker support is with Samsung soundbars via "SoundShare". The only way to find out for sure is enable soundshare and see if it discovers your speakers...
bellest is offline
post #6231 of 8564 Old 03-25-2014, 08:53 AM
s_mack's Avatar
Simple as that smile.gif Its a 6 hour round-trip drive and explaining why I have a big TV in the back to two border guards... no thanks. Not unless it was absolutely necessary or saved a ton of money (like the $700 I saved on the TV in the first place vs. buying it here)
I've ordered the power board off eBay for $120. I found it for as little as $75 on one site but after two days there's been no return to my phone call, their "online chat is available" never gets answered and they haven't responded to my email.
If swapping the power board doesn't resolve it, then I'll probably try the main board. If that also doesn't fix it, then I'll discuss things with Samsung USA.
WHO, by the way, I should mention, also have been less than stellar at returning calls. On Friday I contacted them via chat and they opened a case for me and said someone would get back to me by phone or email on Monday (yesterday). As of now (Tuesday morning) I haven't heard from them either.
s_mack is offline
post #6232 of 8564 Old 03-25-2014, 09:46 AM
bslep's Avatar
Quoted: 94 Post(s)
Liked: 77
.[/quote]
Thanks for your reply. I know the F8000 has a better picture, but $5k better? Anyway, I think I'm going to wait until the Samsung U8550 comes out before I make any purchasing decisions. Bob
bslep is offline
post #6233 of 8564 Old 03-25-2014, 10:45 AM
Industry Insider
Liked: 2216
The point is, you could have a valid warranty from a reliable dealer for about the same price. We ship to the border all the time, then people pick up in the US, then load up and take back to Canada. Not to mention you could have bought a warranty from Mack for about $200 and have in home warranty in your country for a total of 3 years.
Contact us if you go the Samsung USA route...........
post #6234 of 8564 Old 03-25-2014, 10:55 AM
s_mack's Avatar
I'm unclear. Are you telling me you can help me?
I don't know who "Mack" is.
s_mack is offline
post #6235 of 8564 Old 03-25-2014, 11:58 AM
turboman123's Avatar
Quoted: 31 Post(s)
Liked: 25
hello
DRN94 already showed some settings with contrast boosting.
I did the same , but pushed it a bit harder. But I used a meter to calibrate , so my settings are still OK for me.
Here is a link to the posts where I reported that.
http://www.avsforum.com/t/1463286/official-samsung-unxxf8000-owners-thread/4830#post_24328419
http://www.avsforum.com/t/1463286/official-samsung-unxxf8000-owners-thread/4890#post_24332331
turboman123 is offline
post #6236 of 8564 Old 03-25-2014, 05:26 PM
FltTester's Avatar
Liked: 24
You too?!? eek.gif No, I know better. But, fact is, the eyes do have a short memory, and since you can't switch all settings instantaneously, it can take awhile to decide which is truly better.
post #6237 of 8564 Old 03-25-2014, 05:36 PM
romito442's Avatar
What is the best panel on this model? just had to exchange my 55f800 to best buy seemed like there was a hot spot in the lower left corner. was like a white line always showing even showing up on the letter box during movies unless i turned on cinema black i think the panel i had was a tso1 was built in november 2013
post #6238 of 8564 Old 03-25-2014, 06:21 PM
gatti-man's Avatar
Quoted: 12 Post(s)
Liked: 50
I just ordered a un75 anything I should be looking for in the 30 day return period? Thanks!
gatti-man is offline
post #6239 of 8564 Old 03-26-2014, 03:09 AM
seme1's Avatar
How to view the total number of running hours on Samsung F8000 ? I may need to know this before purchasing a used/refurbished unit.
seme1 is offline
post #6240 of 8564 Old 03-26-2014, 08:45 AM
Industry Insider
Liked: 2216
Just letting you know you had more options, yes I am willing to help, answered your PM's........
Reply LCD Flat Panel Displays
Samsung , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv , Samsung Un55es8000 55 Inch 1080p 240 Hz 3d Slim Led Hdtv , Westinghouse Ld 3235 32 Inch Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv , Lg 47lm8600 Led Lcd Hdtv , Samsung 55 Inch 3d Ultra Slim Smart Led Hdtv Un55f8000
