Official Samsung UNxxF8000 Owners Thread - Page 226 - AVS Forum | Home Theater Discussions And Reviews
 118Likes
Old 04-22-2014, 04:51 PM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
Originally Posted by grhopper View Post
I figured out how to change the labels:
1. Press Source
2. Move the cursor to the source you change
3. Slide up on the remote pad to be able to select the tools menu.
4. Select Edit Name
I know this is an old post....
But I just got around to trying to rename Inputs today. But is there any way to type-in whatever name you want? This dropdown list of names doesn't include some obvious choices.. like "DVR" eek.gifconfused.gif
To anyone interested in a Google Chromebox or Chromebook..
Be aware that these boxes run a variant of Linux and DO NOT support HDCP!!!
This means no support for HD on most streaming services. I wish I would have known this beforehand....
Blu-rays & DVD's
WS65711 is offline
Old 04-22-2014, 05:01 PM
bellest's Avatar
Liked: 30
Originally Posted by Joseph Kerr View Post
lol... I know right? But for what's out there right now I still think this is the picture to get. I'm not jumping on 4k yet. I see no reason. Yet. I'll check out those settings though. Thanks. You understood what I meant by "flickering objects" then?
Yep, I've seen the same thing with striped ties as you mentioned and vertical blinds, etc. I don't recall for sure what setting resolved it, but I think it was AMP.
bellest is offline
Old 04-22-2014, 05:23 PM
Joseph Kerr's Avatar
That's in the service menu stuff right? I'm way too afraid of bricking or making things worse. I do plan on having it cal. once I break it in. But I'm happy to hear it is a solvable problem.
Joseph Kerr is offline
Old 04-22-2014, 05:30 PM
bellest's Avatar
Liked: 30
Nope, it's in the regular menu, under picture options.
bellest is offline
Old 04-22-2014, 05:37 PM
doyoid's Avatar
My question is, why do certain objects "flicker"? Not the whole screen mind you, just certian objects. eg. A striped tie. Digital Clean View is on auto. Any other setting distorts the image clarity. Any help here would be great.
You may be describing a moire pattern that's caused by the interaction between a pattern in the source material and the pixels in the display. If that's what it is, it's a normal issue.
bellest likes this.
doyoid is offline
Old 04-22-2014, 05:39 PM
bellest's Avatar
Liked: 30
That's what I meant to say lol!!
bellest is offline
Old 04-22-2014, 05:42 PM
konigsberg7's Avatar
Quoted: 90 Post(s)
From where are you getting your TVs from?
konigsberg7 is offline
Old 04-22-2014, 05:45 PM
Best Buy. This one seems fine no dead pixels... They figured it was a bad batch.
Old 04-22-2014, 05:48 PM
****. :-\ was hoping it was something I could fix. Is this more common in edge lit? Cuz my full array didn't seem to suffer from this.
Of course you did! lol
Old 04-22-2014, 05:50 PM
Oh... And there isn't any "AMP" setting in my menues... :-\
Old 04-22-2014, 05:54 PM
Quoted: 90 Post(s)
I cant find this calibration disc someone mentioned earlier. I ordered a UN65F8000 off Amazon which directly gets it from Samsung just like Best Buy, I suppose.
So is there some sort of software to calibrate it?
Old 04-22-2014, 06:23 PM
doyoid's Avatar
The kind of backlighting shouldn't make a difference regarding the production of moire patterns. However, a sharper image may make the moire pattern more noticeable. It's possible that you're seeing more detail in the image produced by the F8000 compared to your previous TV. If you've increased the sharpness setting on the F8000, try lowering it to zero. It's also possible that moire becomes more noticeable by going to a larger display with the same number of pixels, but I'm sure that TV manufacturers have addressed this to some extent since TVs have become so large. The opposite is true also. For example, in a digital camera, increasing the number of pixels on a sensor, but keeping the same sensor size, reduces the moire effect. Most digital cameras also have anti-aliasing filters that soften the moire effect, at the cost of losing some detail in the image. it's always a trade-off.
doyoid is offline
Old 04-22-2014, 06:29 PM
Ok, thanks. The sharpness is only at 10 but I'll zero it. For reference sake the previous set was a XBR-HX950
Old 04-22-2014, 06:56 PM
Thread Ender
WS65711's Avatar
Quoted: 487 Post(s)
Liked: 326
Look here
Blu-rays & DVD's
WS65711 is offline
Old 04-23-2014, 10:53 AM
bellest's Avatar
Liked: 30
Sorry, Auto Motion Plus.
bellest is offline
Old 04-23-2014, 11:01 AM
Yep... Now I feel stupid. lol I've played with it and CLEAR isn't to bad. No real noticeable soap opera effect. But I only use that for 3D. The rest of the time its off. Messing around I found that turning the MPEG Noise Filter to auto help a bit with "flickering objects" Sharpness is back to 10 as zeroing that made faces too soft, for me anyway.
Old 04-23-2014, 02:43 PM
sumik's Avatar
Hey guys, I have a 60'' F8500 Plasma that is really annoying me with the buzzing, even the new replaced panel does the same thing.
Do F8000 LCD's have this issue also ?
I'm staring to consider going LCD route (never had one) because of the annoying sound.
sumik is offline
Old 04-23-2014, 02:56 PM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
Buzzing is part of the "feature" you get with plasma. It is not a "feature" with LED displays. smile.gif
Samsung UN75F8000 LED TV, NAD T-777 (7.2 Receiver), Oppo 103, Sony PS4, Panamax MR-5100, 7 Paradigm Reference series 8" in ceiling speakers (AMS-150R) - 30 degree tilting speakers, 2 Paradigm SE Sub, universal remote MX-450, universal advanced RF base station MRF-3501. Pics here.
HPQ is offline
Old 04-23-2014, 03:15 PM
Scott Rosenberg's Avatar
i went through a few plasmas - two panasonic and finally the F8500... LOVED the image quality, especially on the 8500 (my room is pretty bright) but couldn't tolerate the buzzing. just last week i picked up an F8000 - fantastic set. buzzing is not an issue with LED's and the picture, while perhaps not the equal of the 8500 off axis or for fast motion, is REALLY good. i'm extremely pleased with the move the to F8000.
Scott Rosenberg is offline
Old 04-23-2014, 04:31 PM
jpsoutlook's Avatar
I have zero buzzing...Pan 65VT50
jpsoutlook is offline
Old 04-23-2014, 04:34 PM
jpsoutlook's Avatar
Is the buzzing not from the power supply or transformer rather than the panel it self? I had an old Vizo 52" that buzzed and they replaced the main board and some other board maybe power related and the buzzing stopped.
Old 04-23-2014, 04:39 PM
FltTester's Avatar
Liked: 24
Good point. A buzz or hum is more likely from a transformer's windings and not a characteristic of plasma panels in general. My older TC-P50S1 Panasonic plasma had a faint fan noise that was noticeable with volume turned down, but no other sound.
FltTester is offline
Old 04-23-2014, 05:22 PM
bellest's Avatar
Liked: 30
I'm a former electrician and controls engineer and "think" I know a bit about transformers and power supply's: just a theory, but could the buzz be more related to the 600 hz refresh rate rather than the components?
bellest is offline
Old 04-23-2014, 05:45 PM
FltTester's Avatar
Liked: 24
And that 600Hz refresh rate causes what to make the buzz sound?
Old 04-23-2014, 06:37 PM
sumik's Avatar
Well I might think about moving from F8500 to F8000 then.
Are there any issues with this LCD, like F8500 has with buzzing ?
sumik is offline
Old 04-23-2014, 07:16 PM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
No buzzing for the F8000 but off angle isn't best when compared to a plasma set.
HPQ is offline
Old 04-23-2014, 09:23 PM
Quoted: 90 Post(s)
Originally Posted by jim98tj View Post
Both my sets came from Indiana by truck, now I see all the flaws in my original set that i never played attention to before. Calling Amazon tomorrow, probably try again with them
What do you mean? I just ordered a 65 inch from Amazon and I live in Chicago so it seems to be coming from IN. Whats wrong with them?
Old 04-23-2014, 09:42 PM
bulgolgiman's Avatar
So far my new replacement (TH02) has no dead pixels, no banding, no noticeable flashlighting/clouding). Still need to adjust settings but so far it's performing well.
Gojhawks likes this.
bulgolgiman is offline
Old 04-23-2014, 09:44 PM
jim98tj's Avatar
I had serious flashlighting issues, pics of the second set are posted under my name. I had never heard of it until got the first set. No quality control, Samsung had a local shop contact me for a repair. .. They said it could be better, whorse, or the same. When they saw it they said it was definitely bad.
jim98tj is offline
Old 04-24-2014, 12:47 AM
no buzzing whatsoever - the set is completely silent. i previously had two VT50's, one ST60 and an F8500... all buzzed to some degree, though the 8500 was the most offensive. like others have reported, it didn't seem to come from any particular point on the back panel, but rather from the center / front of the screen. regarding the F8000, i've been playing with various settings i've found in this thread and have now tweaked the set to the point i am extremely impressed with the picture. off angle viewing may be the only weakness, but it's not an issue from any of the seating positions in my room - YMMV. otherwise, i'm very impressed with the 8000.
sumik likes this.
Samsung , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv , Samsung Un55es8000 55 Inch 1080p 240 Hz 3d Slim Led Hdtv , Westinghouse Ld 3235 32 Inch Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv , Lg 47lm8600 Led Lcd Hdtv , Samsung 55 Inch 3d Ultra Slim Smart Led Hdtv Un55f8000
