Official Samsung UNxxF8000 Owners Thread - Page 241 - AVS Forum | Home Theater Discussions And Reviews
 119Likes
post #7201 of 8564 Old 06-10-2014, 01:33 PM
Lacit1707's Avatar
Originally Posted by DRN94 View Post
If you don't like the warmer color temperature of Movie Mode then try these Standard Mode settings:
Picture preset: Standard
Backlight 14 (I use 20 here, I like the bright peak whites)
Contrast 100
Brightness: 45
Sharpness: 0 (20 max)
Color: 50
Tint: G50/G50
Picture size: Screen Fit
Dynamic Contrast Off
Black Tone Off
Flesh Tone 0
Color space Native
Gamma 0
Color tone Warm2
Digital Clean View Off
MPEG noise filter Off
HDMI Black level Low
Film Mode Auto1
Auto Motion Plus On (LED Clear: On, Anti-Blur 10, Anti-Judder 0)
Smart LED High
Cinema Black On
White Balance:
R-Offset 23
G-Offset 24
B-Offset 24
R-Gain 0
G-Gain 15
B-Gain 50
This should look exactly like the Movie Mode settings except without the "yellowish" tint of the warmer color temperature. Technically Movie Mode is the closest to calibrated but sometimes a cooler temperature can look more realistic and is why I prefer these Standard Mode settings over Movie Mode.
As far as the lagging is concerned that could be the Auto Motion Plus settings. If you still see lagging/stuttering try turning Auto Motion Plus to Clear or Off. Fortunately I am not sensitive to stuttering and haven't noticed any jarring issues with having it on the Custom settings. The motion resolution really helps with sports in general. The only sports I watch consistently are tennis and on occasion hockey. Makes a big difference in both.
how come these settings are slightly different from what you posted on page 182?
Lacit1707 is offline
post #7202 of 8564 Old 06-10-2014, 04:56 PM
dave42's Avatar
Originally Posted by mruschetti View Post
I have the same issue. I have the 46F8000 model, it`s also random and my Tv also go black for 2 secs and then the HDM1 banner shows up. Anyone know how to fix this ????
I have it too. Have Comcast Pace DVR hooked to TV via HDMI. Happens once a night. So far I have switched output on box to 1080i. I have latest Samsung and Comcadt firmware. I switched HDMI cables and inputs and still does it.
The consensus I read on another site is Comcast issue with hdmi handshake.
dave42 is offline
post #7203 of 8564 Old 06-10-2014, 05:00 PM
dvdmd1's Avatar
Quoted: 30 Post(s)
Liked: 40
I have a 60F8000 Optimun and it happens to mine too
dvdmd1 is offline
post #7204 of 8564 Old 06-10-2014, 05:15 PM
dave42's Avatar
Samsung person wants me to play DVD via HDMI to check it out. Do people think it is a Samsung issue? I have had my tv for about 1.5 wks.
dave42 is offline
post #7205 of 8564 Old 06-10-2014, 05:37 PM
Lacit1707's Avatar
When I use the smart hub for Netflix, the sound from the cable still comes through. How do I fix that?
post #7206 of 8564 Old 06-10-2014, 06:23 PM
DRN94's Avatar
Quoted: 68 Post(s)
Liked: 92
I will tweak settings if I feel they look better. I haven't touched my settings in several months, I'm entirely satisfied with the picture I'm getting. Cinema black dims your top and bottom black bars on widescreen movies which makes the contrast pop more. Smart LED dims the blacks inside of the picture while keeping brighter areas bright, this also makes the contrast pop more and give a more satisfying black level. Why you would want those two features turned off is beyond me. To my eyes a deeper black level is a better viewing experience so I will utilize all the features that only this high end LED has to make the black levels deeper.
I use Standard Mode with Game Mode for gaming and for everything else I use my Movie Mode settings.
DRN94 is offline
post #7207 of 8564 Old 06-10-2014, 06:42 PM
Lacit1707's Avatar
Thanks for the reply. I actually saw later that u recommended the different setting for someone who asked a specific question. I am using you movie settings with a few minor tweaks and it looks great so far. However, I noticed that my tv won't let me change the hdmi black level. Is greyed out on normal. Also, what do you recommend for film mode? I saw you wrote auto2 and auto1.
For amp...I see your specs vs buzz... What is the difference in picture?
You . Custom, blur 10, judder 0 , led clear on
Buzz . Custom, blur 10, judder 5, led clear off
post #7208 of 8564 Old 06-10-2014, 07:29 PM
DRN94's Avatar
Quoted: 68 Post(s)
Liked: 92
HDMI black level is dictated by your source. If it's greyed out then you're fine, if it lets you choose it then you want to choose which ever option gives you the deepest black level.
Film Mode is for interlaced feeds such as cable boxes. If you are on a cable box or input that is 1080i, then you want to choose Auto1 to apply the deinterlacing enhancements to the whole screen. Auto2 is meant for widescreen feeds.
Auto Motion Plus settings are totally to your preference. Mine would appear like any other TV plus a better motion resolution. If you like the smooth, fluid, 120hz like picture, then you'll want to turn Judder up to your liking.
DRN94 is offline
post #7209 of 8564 Old 06-10-2014, 07:42 PM
dave42's Avatar
So tonight, we were watching live tv. Did the black screen with hdmi label at top for a second. Then we started watching a show we had recorded on dvr. I believe when the dvr started recording another show, the tv shut itself off. I noticed later that dvr was recording. Will have to see if that is reproducible. Anyone else with this issue when dvr starts a recording and you are watching another show that was recorded? I have Xfinity X1.
dave42 is offline
post #7210 of 8564 Old 06-10-2014, 07:42 PM
Lacit1707's Avatar
On the amp, I just don't like the soap opera effect. Which I don't have right with your settings. However, watching the nba game right now and noticed ghosting and slight jitteriness on replays. Any idea what might cuause that?
post #7211 of 8564 Old 06-10-2014, 07:43 PM
dave42's Avatar
Originally Posted by HPQ View Post
Ensure you have updates turned off.
Some folks have reported seeing this problem. Contact Samsung and see if they can assist.
Updates (auto) were off.
dave42 is offline
post #7212 of 8564 Old 06-10-2014, 09:45 PM
jedi29's Avatar
Quoted: 83 Post(s)
Liked: 59
It`s Comcast , not your F8000.
When Comcast`s S/N ratio drops below <34 db , there boxes are prone to muck up.
When the signal drops , the box senses an update signal from the host ( Comcast severs ) and for a split second turns off , no even long enough to reboot.
It is that drop that messes with the F8000 and other Samsung tv`s.
Of course Comcast denies any of this and they want to send a tech to check my tv.
Yah right , and while he or she is here , am I supposed to educate them too !!
Me 
jedi29 is offline
post #7213 of 8564 Old 06-11-2014, 04:35 AM
dave42's Avatar
I just want to be positive it is not my new Samsung processing things wrong. Last night, it flashed once. Saw 1080 60i on top of black screen. When we were watching recorded program, and dvr started to record another, tv actually completely shut off.
dave42 is offline
post #7214 of 8564 Old 06-12-2014, 05:11 AM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
Later
Me 
I agree with this.. I have antenna and do not see any power issues.
Samsung UN75F8000 LED TV, NAD T-777 (7.2 Receiver), Oppo 103, Sony PS4, Panamax MR-5100, 7 Paradigm Reference series 8" in ceiling speakers (AMS-150R) - 30 degree tilting speakers, 2 Paradigm SE Sub, universal remote MX-450, universal advanced RF base station MRF-3501. Pics here.
HPQ is offline
post #7215 of 8564 Old 06-12-2014, 06:25 AM
dave42's Avatar
I guess my question is whether the tv needs repair/replacement. Or if this is truly Comcast problem. We have 2 other Samsung tv's that are hooked up to SD DTA's via HDMI that do not do this flashing at all. Is it an HD problem?
dave42 is offline
post #7216 of 8564 Old 06-12-2014, 09:04 AM
Lacit1707's Avatar
Any idea why my cable sound is still coming through when i play netflix through smart hub???
post #7217 of 8564 Old 06-12-2014, 09:50 AM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
The easiest way is to test it. since the other two tv's you have are hooked up to SD DTA's via hdmi and no issues are seen, can you hook up the tv that is having the problem to SD DTA's via HDMI? See if you see the problem or not. If not, then for sure it is the comcast or you can do the test on the other two by hooking it up to comcast and see if those units have issues.
HPQ is offline
post #7218 of 8564 Old 06-12-2014, 01:37 PM
bellest's Avatar
Liked: 30
How is your system set up? Are you using the tv audio optical out to a receiver, ARC, ect. We need this info to help you out.
bellest is offline
post #7219 of 8564 Old 06-12-2014, 04:18 PM
dave42's Avatar
Originally Posted by effadj View Post
Quote:Originally Posted by bellest
Just a thought: are you owners that are experiencing this utilizing ARC with these connection issues? I've seen quite a few complaints regarding handshaking issues with ARC connections.
Nope. Don't even have have a receiver connected at the moment. It has happen on both HDMI inputs I am using (1&2) that are connected to a DirecTV HD receiver and to a Samsung BluRay player.
Did you solve the problem with the losing video and flashing to black screen? I have the same issue.
dave42 is offline
post #7220 of 8564 Old 06-12-2014, 04:20 PM
dave42's Avatar
Unfortunately, those TVs are not in this house. I will hook up the DTA to the tv via hdmi and let you know what happens.
dave42 is offline
post #7221 of 8564 Old 06-12-2014, 04:38 PM
survivor's Avatar
75 inch screen is really appealing to me. The main question I have while deciding on my TV purchase this week is whether I should get the 2013 75F8000 or 2014 75H7150. I hate curve so H7150 is the best I can get from Samsung on 2014 non-4K flat screen. F8000 would cost $800 more. Any advice?
survivor is offline
post #7222 of 8564 Old 06-12-2014, 04:39 PM
effadj's Avatar
Quoted: 20 Post(s)
Nope. Still happens from time to time (avg. once a day). I'm running the last released software version. It's like the TV is briefly turned off and when the screen reappears, it shows the banner header with the input device name and video resolution of that input. Just as it would if you selected another input to view. And, still happens on the two HDMI ports I use (non-ARC).
effadj is offline
post #7223 of 8564 Old 06-12-2014, 06:12 PM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
I don't know anything about the 2014 model but I do have the 2013 75 inch F8000 and it is awesome! I have no complaints. See my sig for pics.
HPQ is offline
post #7224 of 8564 Old 06-12-2014, 06:32 PM
starchild's Avatar
5.1 via hdmi
I have been digging and cant seem to figure this out. New soundbar on the way, but only has one hdmi input. My plan was to go hdmi from my sources (xbox, tivo) to f8000. Then f8000 hdmi 3 arc out to the soundbar. Will the tv pass the dolby 5.1 from external sources out via hdmi? I know it will not via optical.
Or am I going to need to add a hdmi switch and go to the soundbar first then out sounbar via hdmi to HDMI 3 on F8000.
starchild is offline
post #7225 of 8564 Old 06-12-2014, 07:23 PM
dave42's Avatar
Weird. It has not happened yet tonight with watching live HDTV. We also streamed Netflix via wireless and not one hiccup. I'm thinking it has to be a Comcadt signal problem btwn STB and TV. What do you think?
dave42 is offline
post #7226 of 8564 Old 06-12-2014, 08:40 PM
HPQ
HPQ's Avatar
Quoted: 34 Post(s)
Liked: 73
Quick easy test -- connect the comcast and see what happens when the tv gets the comcast signal.
HPQ is offline
post #7227 of 8564 Old 06-13-2014, 04:54 AM
dave42's Avatar
We did watch Comcast last night, for about an hour and a half, hooked up via HDMI and there were no blips at all. It seems very intermittent.
I'm still at a loss as to whether this is a Samsung issue or Comcast issue.
Of note, before we got this TV, i had an old Panasonic hooked up to same Comcast box via a different cable (HDMI to DVI), maybe 3-4 ft long. When our Comcast signal was sketchy, we got pixelation of picture and audio breakup but NEVER did it go to black. We now are using in-wall HDMI cable that was already in place and is maybe 25 ft long.
dave42 is offline
post #7228 of 8564 Old 06-13-2014, 05:42 AM
dave42's Avatar
One very positive thing......watched the first episode of second season of Orange is the New Black (streamed thru Netflix). About 20 min into it, they enter a different prison and somehow changed the way they were filming. It was like we were watching it through a window. Incredible picture.
dave42 is offline
post #7229 of 8564 Old 06-13-2014, 06:56 AM
adcustom's Avatar
Quoted: 46 Post(s)
Just wanted to quickly share that I installed the SEK-2000 into my F8000 yesterday. After a few hours of playing Watch_ Dogs (Xbox One) and streaming 24 via Hulu, I actually think that the picture quality and motion (I don't use AMP) are better. Could be due to the faster processor. Could totally be the placebo effect. Either way, just figured I'd share. The installation process was a breeze and the new remote is very cool.
Samsung UN48JS8500 • Onkyo TX-NR747 • MartinLogan Motion 20 Towers, Motion 8 Center, Motion 4 Surrounds, Onkyo Atmos SKH-410 • Xbox One
adcustom is offline
post #7230 of 8564 Old 06-13-2014, 09:33 AM
effadj's Avatar
Quoted: 20 Post(s)
For me the source does not matter. It happens with HD DTV DVR and BluRay DVD player on different inputs.
effadj is offline
Reply LCD Flat Panel Displays
Samsung , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv , Samsung Un55es8000 55 Inch 1080p 240 Hz 3d Slim Led Hdtv , Westinghouse Ld 3235 32 Inch Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv , Lg 47lm8600 Led Lcd Hdtv , Samsung 55 Inch 3d Ultra Slim Smart Led Hdtv Un55f8000
