Official Samsung UNxxF8000 Owners Thread - Page 244 - AVS Forum | Home Theater Discussions And Reviews
 118Likes
Old 06-22-2014, 04:57 AM
mruschetti's Avatar
Originally Posted by buzzard767 View Post
Here is some information from when I was experimenting with Smart LED 15 months ago. Upon rereading I've decided that the best chance of an accurate calibration with Smart LED enabled is probably using the LOW setting.
and
Buzzard, I am eager to see what values you come up with for movie mode
mruschetti is offline
Old 06-22-2014, 10:06 AM
jedi29's Avatar
Quoted: 83 Post(s)
Liked: 60
Originally Posted by sriggins View Post
Woke up this morning and my 4.5 month old UN65F8000 has no signal on any HDMI port. I have tried:
* Multiple sources
* All HDMI ports
* Multiple HDMI cables
Called support. They had me reset it (of course) to no avail so they are calling me back in a couple of hours.
Have any of you experienced this? I didn't find anything on a "signal" search of the forums. Is there an "easy" fix or is something dead in the processor?
It *does* recognize the cable being plugged in. It highlights the proper port when I use source, and as I unplug/plug devices in, it goes back into signal search, then fails.
Hi had a similar problem , turns out it was the main board that needed to be replaced.
Sounds like that is your problem , tell Samsung that you have changed all the HDMI cables and still nothing.
Main board is an easy fix , the guy that came out to do mine was done in about half an hour.
Warranty = free.
Cost for main board is about 347.00 , labor about 400.00
Later ,
G. 
jedi29 is offline
Old 06-22-2014, 10:26 AM
survivor's Avatar
Warranty = free.
Later ,
G. 
Looks like I better get the extended warranty for my F8000 purchase. With the problems you all are seeing with F8000, does the extended warranty worth it or these problems usually surfaced within first 12 months of warranty coverage period? Thanks!
survivor is offline
Old 06-22-2014, 10:39 AM
jedi29's Avatar
Quoted: 83 Post(s)
Liked: 60
My F8000 failed within about 6 months of purchase.
I registered my tv at Samsung.com so I got an extra 3 months.
Would I buy an extended warranty , I don`t know , Samsung offered me a 1 year plan for around 120.00.
My tv is fine , if I don`t get the ex... warranty , thats fine , I will just pick up the H8000.
There way there are not a lot of choices for tv`s that need to fit in a certain location.
Size wise I could go with either the 48" H8000 or the new Sony XBR "49
I have always had Sony , this is my first Samsung.
Good luck
Gary 
jedi29 is offline
Old 06-22-2014, 03:20 PM
tcfersure's Avatar
So I purchased a 65f8000 a few months ago and have loved it so far. However I have been watching the World Cup the past few days and when the camera pans across the field I notice a lot of dark vertical lines in the picture. Now I can't stop noticing it. Does anyone else have this problem with their f8000's?
tcfersure is offline
Old 06-22-2014, 07:18 PM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
vertical line is indicative of the source signal. I don't see it when I watch the world cup but I am using the antenna.
My dad on the other hand has comcast and depending on the channel, he would get that vertical line every now and then. Nothing to do on our end. It is 100% from the source.
Samsung UN75F8000 LED TV, NAD T-777 (7.2 Receiver), Oppo 103, Sony PS4, Panamax MR-5100, 7 Paradigm Reference series 8" in ceiling speakers (AMS-150R) - 30 degree tilting speakers, 2 Paradigm SE Sub, universal remote MX-450, universal advanced RF base station MRF-3501. Pics here.
HPQ is offline
Old 06-22-2014, 08:46 PM
survivor's Avatar
For owners of 75 inch F8000, can you do me a favor and help to measure the distance between the two stems of the TV stand please? Thanks!
My TV cabinet length is only 59 inch and I believe as long as the two stems of the TV stand are within that distance the TV should not topple. I saw a 65 inch F8000 at Best Buy with its TV stand two ends protruded from their TV stand and it still looks pretty stable.
survivor is offline
Old 06-23-2014, 09:07 AM
bellest's Avatar
Liked: 30
I'm pretty sure it's close to width of the panel itself, so ~67".
bellest is offline
Old 06-23-2014, 09:10 AM
survivor's Avatar
What I mean is not the extreme end of the TV stand, I know it is pretty close to the panel width itself. I am actually referring to the distance between the two stems that connects the TV stand to the TV.
survivor is offline
Old 06-23-2014, 12:58 PM
tcfersure's Avatar
Is there a way to test this? Because I don't see it on any of the other tv's in my home. And the dark areas are always in the same spot.
Old 06-23-2014, 05:48 PM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
put up the grayscale patterns in 5% increments. if these pass without the anomaly, play some blu-ray movies you are familiar with, with fast action and high contrast scenes. if you see a problem, rewind back and see if it repeats at the same point in time.
vega509 is offline
Old 06-23-2014, 06:44 PM
ozark's Avatar
Quoted: 26 Post(s)
Liked: 30
Sounds like you got some vertical banding, do a search to find out about it.
inuk_qallunaaq likes this.
ozark is offline
Old 06-23-2014, 07:10 PM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
The vertical line I was speaking of is below.
It comes and goes depending on the channel. Thanks Comcast!
HPQ is offline
Old 06-23-2014, 08:38 PM
tcfersure's Avatar
HPQ, thanks for responding but thats isn't the issue I'm seeing. Mine seems more like its due to uneven backlighting, its just slightly darker lines throughout the picture. Some seem like they are about an inch thick.
Old 06-24-2014, 04:56 AM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
I saw just that on 3net from directv. mine appears and disappears on the left side of the screen. Its annoying, and so far I've only noticed it on directv 3net, if it appears on any other source it may be a sign of a panel beginning to fail.
vega509 is offline
Old 06-24-2014, 06:40 AM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
For my dad's tv, we suspect it is the source. When we hook up blu ray, we never see the line..
HPQ is offline
Old 06-24-2014, 06:41 AM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
Can you take a picture and upload?
HPQ is offline
Old 06-24-2014, 08:44 AM
inuk_qallunaaq's Avatar
I purchased a 65" f8000 last week, with a 4yr extended warranty at BestBuy here in Canada. The tv will be coming up on our yearly sealift ship (as I live in the arctic, air freight is the only other option to ship it up, which costs alot of $$$$). So I'm interested in what wall mounts you all are using, I've searched and searched, but finding one post here and there is very time consuming . I currently have a Panasonic Viera Plasma 58" 800U which I've been pleased with, but the blacks don't seem as deep as when I purchased it in 2008. I can't wait to get my Samsung 65" LED, which will finally arrive in late August!
inuk_qallunaaq is offline
Old 06-24-2014, 10:01 AM
bellest's Avatar
Liked: 30
I'm guessing you'll have the nicest TV in your neighborhood!
bellest is offline
Old 06-24-2014, 10:07 AM
There are actually quite a few people up here with pretty nice sets. Not much to do in 24-hr darkness I guess . I'm looking for a tv wall mount that would span 2 wall studs. I'm not sure what type to get either, tilting, extendable, etc... Looking for any advice at this point.
Old 06-24-2014, 10:18 AM
Quoted: 18 Post(s)
Liked: 1
Does anybody know exactly where i can find the UN65F8000 model in stores...I live in NY and it seems nobody is carrying them anymore due to the updated version model H8000 which is curved.
johnnyboy1988 is offline
Old 06-24-2014, 11:18 AM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
I have mine wall mounted and I am using model SM-T-XL from snap av that my dealer got me. See link here.
HPQ is offline
Old 06-24-2014, 12:59 PM
Thanks HPQ, Looks like a great wall mount. I think I'll go with a tilting mount like the one you showed me. I like that it isn't too close to the wall, but also not so far away from it either. How difficult is it to place it high/low enough on the wall, as I'm planning on having my soundbar rested on my tv stand. I just don't want to wall mount the tv, then find afterwards its either too high or too low.
Old 06-24-2014, 01:04 PM
bellest's Avatar
Liked: 30
I just purchased this one from amazon:, good reviews and a decent price.
http://www.amazon.com/gp/product/B001L6EPCQ/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
bellest is offline
Old 06-24-2014, 01:52 PM
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
I'll check out their Canadian website when I get home. Thanks guys!!
Old 06-24-2014, 03:02 PM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
See my signature for pictures of the tv on the wall and how it looks. Very easy install actually.
HPQ is offline
Old 06-24-2014, 06:47 PM
Thats exactly what I'm looking for. Your setup looks so clean. I think I'm going to find the wires (HDMI and power) of my setup annoying since they'll be visible unlike yours. Unfortunately I live in a rental unit so I won't be able to do much about that. How high up is your tv from the floor to the top of the wall mount bracket? And how high up is the top of the tv from the floor? Just to give me an idea on where to place my wall mount once my tv comes in.
Old 06-24-2014, 09:30 PM
HPQ
HPQ's Avatar
Quoted: 35 Post(s)
Liked: 73
I live in a 2 story house and the "game room/ home theater" is upstairs. I have the wiring all hidden so to speak since it is in the attic.
I can't see the bracket details since it is wall mounted.
I can only give you measurements from what I see when looking at the TV in the front.
From the bottom of the TV to the floor is 42 1/2 inches
From the top of the tv to the ceiling is 16 inches.
When I watch the tv, I usually have the sofa reclined so the view is perfect since the tv is tilted toward me.
HPQ is offline
Old 06-25-2014, 04:33 AM
bellest's Avatar
Liked: 30
Inuk,
While you're shopping at Amazon, look into "cable management". They have a ton of items that will help to clean up you're install!
http://www.amazon.com/Monster-MGMT-4...le+wire+covers
bellest is offline
Old 06-25-2014, 06:07 AM
Thanks HPQ and bellest, I will definetely look into the cable management and see what I can get. Only 2 more months !!
Samsung , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv , Samsung Un55es8000 55 Inch 1080p 240 Hz 3d Slim Led Hdtv , Westinghouse Ld 3235 32 Inch Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv , Lg 47lm8600 Led Lcd Hdtv , Samsung 55 Inch 3d Ultra Slim Smart Led Hdtv Un55f8000
