Official Samsung UNxxF8000 Owners Thread - Page 247 - AVS Forum | Home Theater Discussions And Reviews
 118Likes
post #7381 of 8563 Old 07-04-2014, 12:28 PM
Quoted: 18 Post(s)
Liked: 1
Hey guy's, just picked up UN60F8000 model and I'm loving it...gonna start changing my picture options, I'm going to most likely follow CNET's Picture settings, do you guys recommend there's or somebody's else...BTW they say one option is to turn OFF Black Enhancer but i don't see it in my Picture Options, is it a typo, I'm somewhat confused lol....thanks.
johnnyboy1988 is offline
post #7382 of 8563 Old 07-04-2014, 12:42 PM
audiyopapa's Avatar
I have the same model and use the CNET settings, except I use Standard mode vs. movie mode. Only thing I really had to play around with was the back-light and brightness settings. I'm at 7 on back-light and about 50-52 on brightness. Also, the biggest piece of advice I have it to turn "auto motion plus" to "clear". Any other settling caused stuttering/judder on my set and it seems like most people have the same issue. Clear works great. It's a beautiful set - enjoy!
audiyopapa is offline
post #7383 of 8563 Old 07-04-2014, 12:52 PM
Quoted: 18 Post(s)
Liked: 1
Thank You Audiyopapa, i'll try that...So no Black Enhancer setting is actually in the menu...
post #7384 of 8563 Old 07-04-2014, 02:21 PM
bellest's Avatar
Liked: 30
Correct, no black enhancer on the F8000 series, there is however a "black tone" setting under advanced settings.
bellest is offline
post #7385 of 8563 Old 07-04-2014, 03:34 PM
Sam S's Avatar
Quoted: 214 Post(s)
Liked: 106
Originally Posted by eagle_2 View Post
I've complained for months about this very issue and just gave up talking about it. There will never be a fix for auto motion plus. It's beyond repair. I get all the same issues you mentioned on my FiOS. Custom is unusable, including clear motion. Any combination of settings makes everything choppy. This is with blu-ray as well, not just FiOS. Clear is the only AMP mode that is usable. I tend to hate the soap opera effect but at times I do wish to enable it for some content, and I've given up long ago on hoping there would be improvements. In fact I have no idea what the updates even do because after a year of updates I have seen no improvements or tweaks, even in areas I have called Samsung and mentioned (like the fact that the tv forgets your 3D brightness setting every time you turn the tv off - incredibly annoying and I asked Samsung if they could fix it to remember the last setting - they said they have no plans to change it).
The F8000 had an updated processor too, compared to the previous models, but that didn't help AMP one bit. The F8000 is just as choppy with AMP as the ES7500 was.
Turn AMP off, and you will get a proper picture, with frame rates and motion as intended or captured. Any setting with AMP On is just lipstick on a pig.
Sam S is offline
post #7386 of 8563 Old 07-04-2014, 05:31 PM
geekparrot's Avatar
Just wondering about something...
I usually view 1080p content via streaming, cable or Blu-ray. I have some DVDs I would like to see, and I know the UN60F8000 I have upscales content. I have the Sony BD5100 too, which also does up scaling.
I'm curious as to how to get the best upscale picture quality with the tv and BR player. Is it just automatically upscaled, or are there settings I need to enable on either one to upscale it as good as possible?
geekparrot is offline
post #7387 of 8563 Old 07-05-2014, 04:36 AM
Quoted: 18 Post(s)
Liked: 1
One more question on Picture settings...LED Clear Motion On or Off...
post #7388 of 8563 Old 07-05-2014, 06:01 AM
DRN94's Avatar
Quoted: 69 Post(s)
Liked: 99
johnnyboy1988, turning LED Clear Motion to On will noticeably increase your motion resolution without introducing anti-judder "soap opera" effects. However, this setting sometimes has problems with stuttering on cable box feeds. Some TV providers appear to have more issues than others with it. If you can turn it on and don't get any stuttering, I'd recommend keeping it on for the improved motion resolution. It can really make a difference in 60hz content like sports.
DRN94 is offline
post #7389 of 8563 Old 07-05-2014, 06:49 AM
Quoted: 18 Post(s)
Liked: 1
And leaving :
Auto Motion Plus: Off
Blur reduction: 10
Judder reduction: 0
is ok...thnx for reply.
post #7390 of 8563 Old 07-06-2014, 03:32 AM
billy23's Avatar
And leaving :
Blur reduction: 10
Judder reduction: 0
I was just going to pull the trigger on a vizio m series when i came across a crazy stupid deal on a barely used 55in 8000. Needless to say im speechless. I think i got the settings pretty good. I tried searchin most of the pages here. But if anyone has any tips or suggestions would you mind sharing. Id even take a page number to read up on. Thank you in advance.
billy23 is offline
post #7391 of 8563 Old 07-06-2014, 04:48 AM
bellest's Avatar
Liked: 30
Take a look at Buzz's settings on page 6 of this thread.
bellest is offline
post #7392 of 8563 Old 07-06-2014, 08:34 AM
VideoTech's Avatar
Visio huh.
As they said in Monty Python.....RUN AWAY.....
But that's my opinion from problems other people have had with them.
VideoTech is offline
post #7393 of 8563 Old 07-06-2014, 10:12 AM
aukevin's Avatar
I'm getting the 75" this Thursday. Replacing my 58" Panasonic plasma that I've had for 5 years. I love my two Samsung plasmas I have, hoping this LED will be awesome as well.
If I want 5 channel surround sound for the smart tv apps, do I have to use the ARC or can I use an optical cable to my receiver? Thanks.
aukevin is offline
post #7394 of 8563 Old 07-06-2014, 11:04 AM
survivor's Avatar
I tried to set up my new 75 inch F8000 with CNET settings but it seems some of the settings are not available in the menu. Have anyone faced the same issue? Anyone with the 75 inch mind to share your settings please? Thanks!!!
survivor is offline
post #7395 of 8563 Old 07-06-2014, 03:14 PM
VideoTech's Avatar
DOnt have your model so I cant be specific...but some settings are unavailable if other items are set.
post #7396 of 8563 Old 07-06-2014, 03:15 PM
VideoTech's Avatar
Either
aukevin likes this.
post #7397 of 8563 Old 07-06-2014, 07:57 PM
survivor's Avatar
Well, I am following the exact settings listed in the CNET site. I would assume that if those settings are unavailable then they won't list it out or they will specify it as greyed out. But they do list some specific settings that I can't find it in my F8000. I just want to find out whether anyone experiencing the same thing.
survivor is offline
post #7398 of 8563 Old 07-07-2014, 03:43 PM
tq745's Avatar
Quoted: 68 Post(s)
Liked: 39
I'm seriously considering a open box floor model 55" F8000 from BB. They quoted me a price of $999.00. From what I could tell the TV looked great. Will get the 2 year warranty for $100.00 just to be safe. Has everything but the TV base but they are willing to give me 10% off at wall mount. Do you think this is a good deal or should I go with the 55" H7150 for $1499.00?
tq745 is offline
post #7399 of 8563 Old 07-08-2014, 11:17 AM
mruschetti's Avatar
Where are you from ???, USA models have more settings than Canadian o European Models , like Smart LED...
mruschetti is offline
post #7400 of 8563 Old 07-08-2014, 02:28 PM
bellest's Avatar
Liked: 30
I would jump all over that offer, from what I've read the H7150 severely inferior to the F8000...
tq745 likes this.
bellest is offline
post #7401 of 8563 Old 07-08-2014, 02:41 PM
DRN94's Avatar
Quoted: 69 Post(s)
Liked: 99
As long as it is free from uniformity issues, that is a great deal for the F8000.
DRN94 is offline
post #7402 of 8563 Old 07-08-2014, 04:01 PM
tq745's Avatar
Quoted: 68 Post(s)
Liked: 39
Thanks everyone, picked up the tv from BB today. Can't wait to get it wall mounted and see how this tv performs.
tq745 is offline
post #7403 of 8563 Old 07-08-2014, 05:17 PM
JayBizniss's Avatar
Quoted: 67 Post(s)
Where did you read this, as I am looking at buying the 65 h7150.
JayBizniss is offline
post #7404 of 8563 Old 07-08-2014, 06:36 PM
tq745's Avatar
Quoted: 68 Post(s)
Liked: 39
From what I know, the F8000 uses local dimming as opposed to software dimming for the H7150. Also the F8000 has the smart evolution kit which the H7150 doesn't. The H8000 is last year's F8000 sans the curved screen.
tq745 is offline
post #7405 of 8563 Old 07-08-2014, 08:17 PM
survivor's Avatar
I am from USA. Got my TV from Amazon which was sold by Amazon.
survivor is offline
post #7406 of 8563 Old 07-09-2014, 07:34 PM
Liked: 0
1st post 1st page had a few links and one I'm interested in is the enable cal-day and cal-night settings. The link takes me to a whole page of posts. I've searched that whole page three times over. If I'm missing it could some tell me the posting number?
racing4funn is offline
post #7407 of 8563 Old 07-10-2014, 07:45 AM
bellest's Avatar
Liked: 30
The links got messed up when they made the recent site mods.
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1463286-official-samsung-unxxf8000-owners-thread-7.html#post23142413
bellest is offline
post #7408 of 8563 Old 07-10-2014, 02:10 PM
orologio's Avatar
Quoted: 31 Post(s)
Hello,
I recently had my new 75" f8000 calibrated in Cal-day + Cal-night modes.
Because i do not like to manually switch from day to night mode, I was wondering whether there are any reasons why I should not enable Eco sensor to automatically dim, let's say, a Cal-day or a bright Cal-night?
Also if I may ask... can the Cal settings be locked to avoid accidents (like in isf...)?
Thank you
orologio is offline
post #7409 of 8563 Old 07-10-2014, 06:08 PM
StevenPK's Avatar
Locking the Cal Day / Night settings is easy enough but requires accessing the service menu with a traditional remote (ie with number buttons).
To be honest the calibrator should have done this for you and if they were from a big box store then there service may well carry a 1 year warranty which would cover a return visit.
As for activating Eco mode I'd say it's up to you but it will mess up the black levels of your calibration. If you're okay with that then do it.
StevenPK is offline
post #7410 of 8563 Old 07-10-2014, 06:38 PM
orologio's Avatar
Quoted: 31 Post(s)
Thanks for your reply.
I which way the Eco mode messes up the black level? Coming from a Kuro, I sure care about the black level.
I noticed that in night mode, with Eco off, on dark images the screen gets darker to a point that it doesn't make sense. I can see the screen getting gradually darker or lighter before my eyes... I copied the settings to the movie mode, and I think it's the same quality picture (at first glance), where there is no artificial darkening.
Anyway, I'm amazed that the calibrator didn't know about the lock, he said it's not possible.... he is actually a reputable guy around here.
orologio is offline
Reply LCD Flat Panel Displays
Samsung , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv , Samsung Un55es8000 55 Inch 1080p 240 Hz 3d Slim Led Hdtv , Westinghouse Ld 3235 32 Inch Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv , Lg 47lm8600 Led Lcd Hdtv , Samsung 55 Inch 3d Ultra Slim Smart Led Hdtv Un55f8000
