Official Samsung UNxxF8000 Owners Thread - Page 263 - AVS Forum
post #7861 of 7882 Old 12-05-2014, 02:54 PM
romito201's Avatar
Liked: 1
Originally Posted by jedi29 View Post
About 1204.4 :
Medium to large update , NO picture changes.
This is the Smart Hub change , it is kind of like half 2013 half 2014 hub.
What do I think ?
It`s ok , really is not that big of a deal , I do miss the pane where your 10 most recent pic`s or videos would be , but you can still find them under the Multimedia pane.
All in all , not such a pain !! LOL
Later
Me  HH
i like how popular youtube videos come up in the multimedia tab
romito201 is offline
post #7862 of 7882 Old 12-05-2014, 03:02 PM
jedi29's Avatar
Quoted: 17 Post(s)
Liked: 35
I will admit , I like that , a lot !!!
BTW___do you like the new YT app versus the old ?
For me it`s alright , just took a bit of getting used to , at first I thought all my sub`s were gone , but I found that by pushing the left arrow you can bring up your menu.
So , not to bad , still have the original on my PS3 and Oppo 103D.
Later
G.  HH
jedi29 is online now
post #7863 of 7882 Old 12-05-2014, 04:33 PM
ozark's Avatar
Quoted: 13 Post(s)
I like the old YouTube app better, my TiVo still has the old app.
ozark is offline
post #7864 of 7882 Old 12-05-2014, 08:08 PM
romito201's Avatar
Liked: 1
Later
G.  HH
i like i can watch playlists on it now
post #7865 of 7882 Old 12-06-2014, 09:10 AM
jhartm2's Avatar
Originally Posted by skesler View Post
@jhartm2 My friend has a similar issue in that after 'Listening to tunes for x $TIME' the Pandora (PCM) sound just stops. However, the screen indicates the song is still playing (progress bar).
He is using the HDMI - ARC (Audio Return Channel) to provide sound to his receiver (Denon AVR-E400). We are thinking about switching to S/PDIF output, instead of using ARC, to troubleshoot.
Vudu and Netflix (DD5.1) have no issue.
We recently duplicated the issue of sound dropping (while song progress bar continues) by using local media (.mp3 on USB thumb drive), which uses Stereo PCM similar to Pandora. This indicates a multi-app issue. It seems to be more susceptible to drop sound, when you are skipping songs, or changing channels on Pandora. Same with skipping through the .mp3 list.
I thought someone pointed out you could configure the TV, to output 'Stereo' sound using DTS instead of PCM, and that seemed to solve an issue related to Pandora sound.
Do you know where in the TV menu you have that option?
Did you ever find a solution to your problem?
His setup is:
TV:  UN65F8000 (software version 1120)
A/V Receiver:  Denon AVR-E400
Connection:  HDMI ARC from TV to Reciever
We are trying to zero in on if it is an issue with the TV or the Receiver - or a HDMI handshake issue.
Steve
as it turns out, this is a problem between the yamaha and the samsung. i validated as much as possible by swapping in an old marantz on the same $EVERYTHING_ELSE. in fact, i have narrowed it down to PCM coming from the samsung... doesn't seem to happen with AC3 or any other type of stream. so for whatever reason the yamaha occasionally doesn't sync with the samsung... if i power cycle the yamaha while it's happening, it usually comes back on playing the song fine.
frustrating.
/jer
jhartm2 is offline
post #7866 of 7882 Old 12-06-2014, 10:26 AM
skesler's Avatar
Pandora (PCM) sound drops using ARC - Samsung -> Denon
frustrating.
/jer
Thanks for the response - ditto on the frustration.
Same issue with Denon AVR-E400 receiver. Still not convinced it is not a Samsung ARC issue with PCM audio dropping out.
skesler is offline
post #7867 of 7882 Old 12-07-2014, 12:26 AM
Holland108's Avatar
Finally, the newest update in EU (1122.2) added Netflix 4.0, and the new You Tube.
Did not notice other changes (yet).
Anyone knows how to figure that out?
ekelund likes this.
Holland108 is offline
post #7868 of 7882 Old 12-11-2014, 02:36 PM
mrgud79's Avatar
Anyone looking to get a great deal on SAMSUNG UN75F8000 check this "Amazon" link out! Price is UNREAL!!!
http://www.amazon.com/Samsung-UN75F8.../dp/B00BCGRLV2
Home theater: ​SAMSUNG UN75F8000, UN65F8000 & 65" HU9000, PIONEER ELITE SC 81 Receiver/POLK AUDIO 7.1 Speakers PC: CPU: 4770K @ 4.9| GPU: QUAD TITAN SLI| OS: Windows 8 64 bit | MB: ASUS MAXIMUS VI EXTREME| RAM: 16GB Corsair Vengeance | PSU: Corsair AX 1200| SOUNDCARD: Auzentech X-Fi HT HD 7.1 | STORAGE: two 1TB Samsung 840 Evo SSD's in Raid 0 | CASE: LEVEL 10 GT All watercooled 2x XSPC RX480 | KEYBOARD/MOUSE: Logitech MK710
mrgud79 is offline
post #7869 of 7882 Old 12-14-2014, 04:06 AM
romito201's Avatar
Liked: 1
i have directv what should i use 720/60p or 1080i/60i
post #7870 of 7882 Old 12-14-2014, 02:25 PM
jedi29's Avatar
Quoted: 17 Post(s)
Liked: 35
I`m not sure I understand your question , BUT , if your sat device is capable of outputting 1080 then the F8000 will take care of it. Even if your box only does 720 , you still don`t need to do anything.
There is NO res setting on the F8000.
The panel`s max res is 1080p.
If you had an old VCR that only output 230 lines , then the F8000 would do it`s best to up-convert them to 1080.
I hope this info helps
Later , HH
Me 
post #7871 of 7882 Old 12-15-2014, 12:18 PM
romito201's Avatar
Liked: 1
Later , HH
Me 
my box can do 720p or do 1080i
post #7872 of 7882 Old 12-15-2014, 01:23 PM
jedi29's Avatar
Quoted: 17 Post(s)
Liked: 35
Ok , then I suggest you set your box to 1080.
Later
G. 
post #7873 of 7882 Old 12-18-2014, 09:04 AM
Quoted: 13 Post(s)
Liked: 2
Hi guys. I recently bought a F8500 plasma. The image quality is absolutely spectacular, but is has a pretty significant buzz, so I think I'm going to return it and go with an LED instead. I am deciding between the F8000 and the HU8550. For those of you who have seen both sets, how do they compare on 1080i/1080p content? Thinking about going with one or the other, but the F8000 is a few hundred bucks cheaper. Thanks!
falconcry is offline
post #7874 of 7882 Old 12-18-2014, 07:38 PM
the3kgt2's Avatar
I'm looking to upgrade our Sharp LC-60LE6400U after realizing our TV is way too small since we're sitting 12 feet away.
I'm currently debating between Sharp's LC-80UQ17U for $3500 shipped or Samsung's UN75F8000 for $2800 shipped.
I was able to see Sharp's LC-80UQ17U and was really impressed. I wasn't all that impressed with the UN75H8000 (Same as F8000 but with a curved screen). Could have just been due to calibration.
The Sharp is 5" larger diagonally and has a matte screen for our bright room...but it's $700 more than the UN75F8000. I know the F8000 will look better once calibrated but I'm worried 75" is too small for 12 feet away.
Does anybody have any experience with both these displays?
the3kgt2 is offline
post #7875 of 7882 Old 12-18-2014, 11:31 PM
DRN94's Avatar
Quoted: 33 Post(s)
Liked: 77
The F8000 has deeper native blacks and can even go deeper when the local dimming does its magic during dark scenes. Color accuracy is also superior on the F8000. I honestly would not recommend Sharp if you're looking for the best possible LED picture quality. Movie mode will knock your socks off on the F8000. I've had my 55" F8000 since July of 2013. It's still a visual pleasure to watch each and every time I turn it on. I think you will be more pleased by the F8000 over the Sharp.
According to RTING's viewing distance calculator, 12" matches up with 75" so I think it'll be the perfect size. If you could hold off on upgrading I would recommend you wait for the post Christmas season price drop of TVs as the 2015 models are released. Samsung will be using quantum dots on their new flagships to improve color gamut.
I will agree that Samsung, and all manufacturers for that matter, are obsessed with having their sets in Dynamic-torch-sun-color-overload mode in showrooms. It makes an amazing set look awful, especially when it comes to flagships that are able to produce such a natural, realistic image with subtlety and nuance when properly set up.
The F8000 is slightly sharper with native 1080p content but the 4K support of the HU8550 may be worth the few hundred bucks, not to mention a faster and newer Smart TV interface. Both sets have local hardware dimming and reference picture quality so it's just a matter of 4K support and the newer Smart TV features are worth the few hundred bucks for your needs. The F8000 is a fine set but if I were in the market I'd get the HU8550 or wait for the new 2015 Samsung flagship sets that will feature quantum dots for higher than rec.709 color saturation.
the3kgt2 likes this.
DRN94 is offline
post #7876 of 7882 Old 12-19-2014, 10:13 AM
turboman123's Avatar
Liked: 24
hello
When you come from a plasma, and you appreciate the image quality, you might be disappointed with some LED aspects (less deep blacks, less uniformity). Consider then also an LG OLED. Prices have come down. I bought my 55F8000 a bit more than a year ago. I am satisfied, but if I would have to buy another panel now, I would also look at OLED's as prices have come down, and I like deep blacks.
turboman123 is offline
post #7877 of 7882 Old 12-19-2014, 01:07 PM
thebignewt's Avatar
Quoted: 150 Post(s)
Liked: 53
75" should be fine from 12'. The F8000 is much like mine with local dimming I think. My set looks great. I think the F8000 is no longer sold by Samsung, and you may have trouble finding one if you wait much longer. It's probably a good deal now.
Samsung ES8000 65", Evo Kit installed, Yamaha AVR with Paradigm speakers, iMac, iPad, Apple TV and HTC One phone.
thebignewt is offline
post #7878 of 7882 Old 12-19-2014, 02:38 PM
the3kgt2's Avatar
Thanks. I decided to go with the UN75F8000 over the LC-80UQ17U. Just ordered it.
the3kgt2 is offline
post #7879 of 7882 Old 12-19-2014, 04:40 PM
S_G7's Avatar
Quoted: 13 Post(s)
Where are you seeing the UN75F8000 for $2800 shipped?
S_G7 is offline
post #7880 of 7882 Old Today, 11:51 AM
Holland108's Avatar
Hi,
since the eu firmware update 1122.2, the display goes on black, after switching off Netflix.
The only thing that helps, is switching off/on the TV.
Anyone recognizes this problem?
post #7881 of 7882 Old Today, 12:49 PM
JohnnymoZ's Avatar
Liked: 66
I have and F8000 and a few minutes after starting a movie, beit from the STB or through my Oppo 103, the horizontal black bars will come on screen and on the top one it shows the current resolution....do you guys ever experience this with yours or any other model?
my stuff:
Harman Kardon AVR 3600
Emotiva XPA-3
OPPO BDP-103
Klipsch RF-82II Mains
Klipsch RC 62II Center
Klipsch SS.5 L&R Surrounds
Klipsch SS.5 L&R Rear Surrounds
HSU Research VTF2-MK4 Subwoofer
Samsung UN65F8000 LED Monitor
JohnnymoZ is online now
post #7882 of 7882 Old Today, 02:08 PM
jedi29's Avatar
Quoted: 17 Post(s)
Liked: 35
Originally Posted by Holland108 View Post
Hi,
YES
Bad Firmware , but the tv needed it anyway.
I have had You Tube issues , not signed in / Amazon Instant Video not signed in / VUDU , all my movies were showing as partly viewed , on a side note , VUDU helped , they have the very best US based customer service in all of any electronic company ( Apple would be a close second ) , with Samsung the caboose !!
The Amazon button on the remote no longer works and may be causing the problem , as the first time I had a massive app cascade failure was when I pushed the button.
I have to re-sign into YT / Pandora / Crackle / VUDU / AIV and Amazon Cloud app for music.
I have had a total of 3 non button ( happened without hitting the Amazon button ) app semi mix ups , but nothing like the first.
This could NOT be 1204 related / it could be the new Amazon app pulling more band-width at startup because it is now doing K4 ( Amazon is denying that would be the cause since they are not transmitting in 4K ) , but it is being advertised that AIV is going 4K.
That is what consumer electronics is all about , we are the far left flank of real trouble shooting , and get wounded the most.
Happy Holidays , and keep your head down !!
Gary 
Reply LCD Flat Panel Displays
Samsung , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv , Samsung Un55es8000 55 Inch 1080p 240 Hz 3d Slim Led Hdtv , Westinghouse Ld 3235 32 Inch Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv , Lg 47lm8600 Led Lcd Hdtv , Samsung 55 Inch 3d Ultra Slim Smart Led Hdtv Un55f8000
