Official Samsung UNxxF8000 Owners Thread - Page 284 - AVS Forum | Home Theater Discussions And Reviews
 114Likes
post #8491 of 8495 Old 07-13-2016, 07:14 PM
jedi29's Avatar
Quoted: 70 Post(s)
Liked: 57
Hi Guy`s ,
There is new firmware ! . 1215 , so far I have not noticed any difference in performance.
Just wanted to let the users on manual you got something to due !!
Later
Gary 
jedi29 is offline
post #8492 of 8495 Old 07-16-2016, 09:01 AM
arrow201's Avatar
Quoted: 14 Post(s)
Originally Posted by jedi29 View Post
Hi Guy`s ,
Later
Gary 
Thanks Jedi ! Installed and "tested" ...like you said, no difference that I can see ...hmmmm ? TV works fine, streamed a movie via NAS, "smart" hub appears to be the same ...all looks the same as it did before. Maybe they fixed some underlying bugs and/or added some new ones
arrow201 is offline
post #8493 of 8495 Old 07-17-2016, 10:17 PM
highstream's Avatar
You have a link for it? Samsung is still showing 1213.1 on the 46" page. Thanks,
highstream is offline
post #8494 of 8495 Old 07-18-2016, 07:23 AM
arrow201's Avatar
Quoted: 14 Post(s)
I always go through the TV's menuing system to check/update to the latest firmware. If not there, maybe your region doesn't have it yet ?
arrow201 is offline
post #8495 of 8495 Old Today, 09:54 AM
SnakeDoctor's Avatar
Loss of Smarts
It looks like our "Smart" TV just keeps getting dumber. Here is a post from Silicondust - makers of the HDHomerun tuner and DVR software:
Important - disable firmware auto-update on your Samsung TV today. Do not install the 1121 firmware.
Back in June we released HDHomeRun liveTV and DVR support for RUI supported by Samsung 2016 series 6, series 7, and series 8 smart TVs. DVR direct on your TV without a set-top-box.
Samsung firmware update 1121 is being pushed to Samsung 2016 TVs right now. This firmware release appears to remove the RUI feature that shipped with theseTVs.
Samsung TVs default to auto-updating the firmware - for the moment Silicondust recommends disabling the auto-update feature and not upgrading to 1121 until more information is available. Once updated there does not appear to be an easy way to roll back to the factory firmware.
We have reached out to Samsung for comment and will provide further updates as the situation is better understood.
SnakeDoctor is online now
Reply LCD Flat Panel Displays
Samsung , Samsung Un55b8000 55 Inch 1080p 240 Hz Led Hdtv , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv , Samsung Un55es8000 55 Inch 1080p 240 Hz 3d Slim Led Hdtv , Westinghouse Ld 3235 32 Inch Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv , Lg 47lm8600 Led Lcd Hdtv , Samsung 55 Inch 3d Ultra Slim Smart Led Hdtv Un55f8000
