LCD TV has developed ink spots across top (with pic) - AVS Forum | Home Theater Discussions And Reviews
Old 03-15-2013, 09:44 PM - Thread Starter
shattered00's Avatar
I transported an LG4250 by laying it face up in the backseat of a car with pillows surrounding it (no box available). I then placed it face up in the garage on padded blankets and left it there for approximately a week. I recently hooked the TV up and it has developed these "ink-like" spots at the top that appear to be evenly spaced. Obviously it is because of something that I did, but I wanted to know if there is anyway I could fix this issue or hire a repair technician to fix it at a reasonable price? IMG_0498[2].JPG 1405k .JPG file
shattered00 is offline
Old 03-16-2013, 05:19 AM
Navigationroad's Avatar
What was the temperature in the garage? Lower than your house temp? Did you let the TV acclimatize before you powered it up? Just wondering whether it might be condensation between the screen layers.
Navigationroad is offline
Old 03-16-2013, 07:59 AM
walford's Avatar
I believe the there may be some screen separation caused by keeping it flat instead of the recommended vertical position during shipping and storage. Have you tried pushing the top of the screen over the spots slightly?
walford is offline
Old 03-16-2013, 09:14 AM - Thread Starter
During the week that the TV was in the garage, the temperature ranged from 40 degrees F to 85 degrees F (Texas). The day that I moved the TV in from the garage to the house it was about 74 degrees outside and 79 degrees inside. I have not tried pushing the top of the screen in slightly, but I will do that now. Will post results.
Old 03-16-2013, 10:21 AM - Thread Starter
Unfortunately, the distortions are still there after gently massaging along the top of the screen. Is this something that could go away with time? Maybe the effects would be counteracted if I laid the TV face down for a week or so?
