Which is "smarter" ? PS3 vs. Sony HX850 - AVS Forum | Home Theater Discussions And Reviews
Old 03-16-2013, 11:06 AM - Thread Starter
acd483's Avatar
Quick question all. I just purchased a Sony KDL-40HX850 and want to know whether it will be better to stream Netflix through the TV or through the PS3. The PS3 doesn't have as good a WiFi connection as the HX850 but could the TV actually be faster at processing the data for a better viewing experience? Any advice is appreciated. Thanks!
acd483 is offline
Old 03-16-2013, 11:40 AM
Dr.Shankenstein's Avatar
Quoted: 234 Post(s)
Liked: 142
In most cases the PS3 would be faster. The general consensus that I have seen around most forums is the 360/PS3 seem to stream content better. This isn't fact, but just from opinion.
Dr.Shankenstein is online now
Old 03-16-2013, 04:23 PM
sitlet's Avatar
Yea, I can't speak for that tv itself, but Netflix puts MUCH more effort into their PS3/360 apps than they do ones on tv's. Netflix on my ps3 works way better than if I connect my HTPC and view that way.
sitlet is offline
Old 03-17-2013, 12:46 AM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
Netflix works well on my PS3 also
tubetwister is offline
Old 03-17-2013, 03:47 AM - Thread Starter
acd483's Avatar
Thanks guys. One more thought. Instead of the PS3 or the TV, I was thinking of picking up a Mac Mini for streaming. Surely that would be better than the PS3?
I will say, by the way, that the Netflix app on the set and the ps3 are identical in look and feel (makes sense as they are both Sony products) and that's why I got to thinking about the difference between processors.
acd483 is offline
Old 03-18-2013, 05:27 PM
Liked: 622
The new Roku 3 is the best of the set top streamers new dual core processor is supposedly fast also along with a new user friendly interface reviews are solid.
Actually the PS3 may be better than the mac mini which is way overpriced for a small htpc. Streaming does not require a lot of processing power just decent WiFi and internet you can manually set your PS3 wifi settings also . I have mine on auto it works well.
If you are getting buffering that would be an internet connection bandwidth issue ,if you are getting WiFi disconnects that's another thing altogether. Try re setting the PS3 connection either manual or auto . Although the interface isn't the greatest once you are logged on to Netflix it's fine . The Sony PS3 has plenty of video processor (way more than you will ever need) for streaming. Although the interface isn't the greatest once you are logged on to Netflix it's should be fine . If you have a lot of Apple stuff the apple TV STB is another option .
Other than that the Roku 3 unless you wan't an HTPC .
acd483 likes this.
Old 03-19-2013, 02:39 AM - Thread Starter
acd483's Avatar
Thank you tubetwister! Greatly helpful.
While I'm sure I will have redundant services across devices, it's great to know which is best at what.
TV - displaying content
PS3 - gaming, streaming, blu-ray
Mac Mini - iTunes, downloading media (thank you Switzerland!)
That should have it covered.
acd483 is offline
Old 03-19-2013, 07:21 AM
steve1971's Avatar
Quoted: 498 Post(s)
Liked: 431
If it were me I would stream movies through your PS3 or through another device such as a Blu ray player ect. For some reason the streaming quality of movies through my Blu ray player is better then going through my tv. But thats just my opnion mind you.
steve1971 is offline
Old 03-22-2013, 02:59 PM
Liked: 622
That's not unreasonable the PS3 has good fast video processing ,I imagine a decent B-ray player would as well.
Sony Bravia 55 Inch Led Tv 3d Support Bravia Hx850 Kdl 55hx850 , Playstation 3 160gb System
