Problem sending e-mail with Samsung Smart TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-19-2013, 07:14 PM - Thread Starter
legaldeejay's Avatar
Hi, I have a Samsung UN55ES7500. I have a G-mail account and have no problems viewing e-mails in the browser on the TV. But when I try to compose and send e-mails, I keep getting a server error message in G-mail. I can't send any e-mails. Does anybody have any explanations for this? Thanks.
legaldeejay is offline
post #2 of 8 Old 03-20-2013, 09:07 AM
sitlet's Avatar
Quoted: 16 Post(s)
Is there any updates for the browser? Gmail uses a fairly new type of html for it's interface. I have a work computer with a version of Internet Explorer that's probably a year old, and it has problems with it too.
sitlet is offline
post #3 of 8 Old 03-20-2013, 09:03 PM - Thread Starter
I am not aware of any updates. If there is an update, there will be a popup message when going into the SmartHub. Never noticed any for the browser.
post #4 of 8 Old 06-29-2013, 02:18 PM
BobGogol's Avatar
I have a 7500 and I am dealing with the same issue...
Bob
BobGogol is offline
post #5 of 8 Old 07-03-2013, 02:05 AM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 623
double post please remove
tubetwister is offline
post #6 of 8 Old 07-03-2013, 02:18 AM
Liked: 623
I don't know about e mail on a TV never tried it with my PS3 . I guess if you can do it on a smartphone it should be OK on a TV could be convenient at times .I presume the TV has a keyboard remote?
Does the smart hub go through Samsung servers like the PS3 does with the Sony server farms? those have not been without problems I know that firsthand .
Sony doesn't communicate very well when problems arise and they aren't the quickest with patches . Bought two new TV's this year not Sammie's but I looked at some the Smart hub and the sets looked pretty good .
I think the TV's use Android OS so Google should be right at home there .. Hopefully they will get with Samsung and update will be out soon . What if your TV was to get a virus and get locked to whatever channel the Kardashians are on now that would not be good! anyway good luck.
post #7 of 8 Old 07-03-2013, 11:58 AM
BobGogol's Avatar
hilarious!
BobGogol is offline
post #8 of 8 Old 07-03-2013, 11:58 AM
BobGogol's Avatar
hilarious!
BobGogol is offline
Reply LCD Flat Panel Displays
