Return policy about to run out in a couple days. What should I do? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-31-2013, 10:09 PM - Thread Starter
Cradle6's Avatar
Hey everyone,
Just a quick question that hopefully is simple.
I bought a edge-lit LED Vizio M3D550KD from Costco (found literally the last one, everything else was the "KDE" version) a few months ago.
I've really enjoyed the TV, there's a couple minor issues (blacklight bleeds from the sides during very dark scenes, but I've heard that's pretty standard for edge lit LEDs) but nothing too serious.
My real problem is that when the camera pans (mostly during video games or sports), I can notice several very thin black vertical lines in the background throughout the screen: seems to be 3 or 4 evenly spaced vertical lines (is this called vertical banding?).
I can't take a photograph because it only appears during motion.
So my question is, is there a way to fix this? Will this be covered by my manufacturer's warranty? Should I just return this very difficult to find TV set and find something else?
I'm down to the last couple days of my 90 costco return, so I'm wondering what you all would do. Besides this issue, I've really enjoyed this TV.
I appreciate the help!
Cradle6 is offline
post #2 of 3 Old 04-01-2013, 12:40 AM
Quoted: 40 Post(s)
banding is common in all led's and some plasmas. And it cannot get fixed or repaired.
Exchanging a TV is always a gamble. You might a get a better one or worse.
It is all about quality. That is the picture.
JVC DLA-RS20, NEC XG-1352LC 8" CRT, 106" wide StudioTek 130 screen
CaspianM is offline
post #3 of 3 Old 04-01-2013, 05:29 AM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
I am assuming this is a 55" TV? How much did you pay for the TV? I think you would need to evaluate what else you can get in the same price range before making a decision. There are some really good deals going on with TVs daily now as a lot of companies are getting rid of their 2012 models.
eric3316 is offline
Reply LCD Flat Panel Displays
