Official LG GA6400 Series Owners Thread - Page 14 - AVS Forum | Home Theater Discussions And Reviews
post #391 of 418 Old 08-05-2014, 08:38 AM
JOHNNY672003's Avatar
60ga6400
I bought a 60ga6400 form amazon, the bezel is alot thicker than i was hoping, the Pic is pretty good for a 120hz, I still have the 3.2 and dont plan on updating even though I keep getting the popup to do so, my question is this, can xbmc be loaded on this model, I tried but for some reason it wont install, any advice?
JOHNNY672003 is offline
post #392 of 418 Old 08-26-2014, 07:29 AM
stuart628's Avatar
Quoted: 48 Post(s)
Liked: 31
Well I got this tv last night for 500, its the 47ga6400...it was a best buy display model which if that takes lets say 2-3 years off its life so be it...I figured I will at least get a good 8-10 years out of this set. I am really impressed with it and I am sad it didnt sell better then it did. I have not tried the 3d yet. One problem I did have was it did not come with qwerty remote...but Logitech k400 keyboard solved that so I could get through the setup. I love the picture quality. thanks for this thread and what you guys have done, it really helped get my tv setup nice and easy....I understand I can just use the theater glasses with this tv for 3D is that correct?
stuart628 is offline
post #393 of 418 Old 08-26-2014, 07:48 AM
jblank74's Avatar
Quoted: 32 Post(s)
Yes, you can theater 3d glasses. I have about 10 of them and they work perfectly.
jblank74 is offline
post #394 of 418 Old 08-26-2014, 09:44 AM
stuart628's Avatar
Quoted: 48 Post(s)
Liked: 31
Good to know thank you...How satisfied with this tv are you? So far I have liked what I have seen and to be honest, dont think I will find anything near its quality in the 500 price range!
post #395 of 418 Old 08-26-2014, 10:37 AM
jblank74's Avatar
Quoted: 32 Post(s)
On a 1-10 scale with 1 being "I hate it, this is a terrible TV" and 10 being "I am in love with this TV, it's awesome!" I am at a 4.
It lacks the ability to tweak settings for the streaming products, so you can't turn off Trumotion or any of the other crap, for Netflix, etc. Plus, the picture quality, while easily customizable, seems difficult to make "perfect". I know that is a poor word to use, but I have never been able to get this TV to a picture quality level that I am happy with. I find myself constantly tweaking this or that, which is troubling. Also, the apps available are sparse, it is no longer supported from LG (and presumably Google), and it lacks some streaming services which should be no brainers. Also, while I haven't used them in some time, the speakers on the TV are among the worst I have ever heard.
The WORST thing about the set though is the moronic decision by LG to make it so that the auto-dimming cannot be turned off or adjusted, by the TV's owner, without a special service remote control. Watch a dark film like Fright Night and count how many times the screen brightens and darkens. I (embarrassingly) have had to tell people that this is a "feature", apologizing for their stupid decision.
That said, the WIFI is strong, it has lots of inputs, and the 3D is outstanding, so not everything is bad. I'm just so disappointed considering what this TV was supposed to be.
Imagination will often carry us to worlds that never were. But without it we go nowhere.
Carl Sagan (1980)
jblank74 is offline
post #396 of 418 Old 08-26-2014, 11:08 AM
stuart628's Avatar
Quoted: 48 Post(s)
Liked: 31
well then I am sitting pretty lol...I dont care for the smart features as my xbox one will handle that...and the picture quality I am happy with as its better then the 2007 toshiba its replacing 3D my projector does, but its a nice bonus to have this one as well!!!
post #397 of 418 Old 08-26-2014, 12:02 PM
jblank74's Avatar
Quoted: 32 Post(s)
Glad you are pleased. Enjoy it!
Carl Sagan (1980)
jblank74 is offline
post #398 of 418 Old 08-30-2014, 01:37 PM
dusadus's Avatar
Am I still the only one who can't get the tv to start on full screen instead of the home screen upon startup? Is it because I have quick start enabled?
dusadus is offline
post #399 of 418 Old 08-30-2014, 01:49 PM
dusadus's Avatar
I guess I'm the only one hat gets annoyed by the home screen default setup. Got through to LG. this is a feature that can't be changed. You can't have it start by default on tv.
dusadus is offline
post #400 of 418 Old 09-01-2014, 05:16 PM
jblank74's Avatar
Quoted: 32 Post(s)
I'm surprised they'd answer any questions about the unit. Almost seems they are doing all they can to forget about it.
Carl Sagan (1980)
jblank74 is offline
post #401 of 418 Old 09-02-2014, 07:09 AM
stuart628's Avatar
Quoted: 48 Post(s)
Liked: 31
I must be missing something, my tv starts at the normal tv screen not the home app, I do not have the quick startup enabled and it takes it awhile, but its there. I am really liking the picture quality of this tv and think it will be a great tv, especially during fantasy football season, I am assuming I can install my yahoo and espn fantasy apps and just check the scores of my teams through the app while on a commercial break! that will be sweet...I am going to start playing around with the android side of things here soon...first tip, check the dont rotate screen correct?
post #402 of 418 Old 10-21-2014, 10:22 PM
john1655's Avatar
Liked: 0
Ive had this issue for a while but I just found the solution. In start apps at startup one of the "apps" is live TV. It now starts live at startup. Crazy huh.
john1655 is offline
post #403 of 418 Old 10-24-2014, 05:59 PM
mercennarius's Avatar
Quoted: 221 Post(s)
Liked: 105
Just an FYI, I was able to update some of my factory Android apps with the Aptoide app store. One of which was the Play Store app which I now updated to the new Android Lollipop 5.0 version, it looks much cleaner and is actually much faster than the one currently on our TVs. I highly recommend downloading Aptoide and updating your Playstore as well as any other apps (Chrome).
mercennarius is offline
post #404 of 418 Old 11-10-2014, 07:23 PM
Facebook's Avatar
Liked: 0
Can you help me get my TV to start in the home screen instead of the regular TV?
Facebook is offline
post #405 of 418 Old 07-08-2015, 03:53 PM
Liked: 0
Do I have to do anything for 120Hz mode?
Do I have to do anything special to put it in 120Hz mode? I only use my TV for computer games, as I have my computer hooked up to it via HDMI 1.4
I put it in game mode because that's the only mode where there is no input lag. Does game mode have any bearing on the framerates?
Patrick McGuirk is offline
post #406 of 418 Old 07-14-2015, 07:03 AM
GizmoDVD's Avatar
Everyone still enjoying this TV?
I really like the new 2015 LGs, but this QWERTY remote is really great.
Still wish I had freaking Hulu App.
GizmoDVD is offline
post #407 of 418 Old 08-02-2015, 11:29 AM
trev01's Avatar
To Hulu, install XBMC/KODI/TV ADDONS. I installed and have a home page shortcut, actually have it on now. No need for Xbox, Amazon Fire HD etc.....
trev01 is offline
post #408 of 418 Old 10-10-2015, 12:19 PM
GizmoDVD's Avatar
Does the Amazon Instant Video app work for anyone? I can't connect anymore.
GizmoDVD is offline
post #409 of 418 Old 12-20-2015, 08:20 PM
Sinistar83's Avatar
So I just noticed today the 3D World got discontinued.. Anyone know how to delete the icons and section off the homescreen for it?
EDIT: I just noticed I posted this in the wrong thread. I have a 5GA7900 model, though I'm guessing it got deleted from all LG 3D TVs?
Sinistar83 is offline
post #410 of 418 Old 12-21-2015, 07:42 AM
GizmoDVD's Avatar
i'll have to check as well. No way to delete them as I still have the YouTube one which doesn't even work.
The only Apps I use are Netflix (though the AppleTV Version is better), Plex (once again AppleTV is better), Vudu and YouTube (which I had to side load just to work since YT discontinued the version for this TV).
So really just Vudu since it's not on AppleTV. Netflix is easier for my wife to find built-in.
What apps are others still using? Most don't work on this TV.
GizmoDVD is offline
post #411 of 418 Old 12-24-2015, 08:29 AM
GizmoDVD's Avatar
Gone for me
Sad a TV that is 2 years old already has so many discontinued services. Wish I could still access Amazon VOD still.
GizmoDVD is offline
post #412 of 418 Old 01-26-2016, 05:06 AM
Bond 007's Avatar
Quoted: 2596 Post(s)
Liked: 2061
Did a quick search but cant find an answer.
Im assuming the 6450 is not a full array LED tv. Is it direct lit or edge lit?
Do the Amazon, Netflix and Youtube apps work well?
Licence to Kill
Bond 007 is offline
post #413 of 418 Old 01-26-2016, 07:27 AM
GizmoDVD's Avatar
Not sure if the 6450 is a variation or not....but the 6400 only has the Netflix App and now a crappy Youtube app which has the highest quality video of 360p. I "downgraded" to an older 1080p version, thankfully. Amazon no longer works.
GizmoDVD is offline
post #414 of 418 Old 01-26-2016, 08:29 AM
Bond 007's Avatar
Liked: 2061
Thank you.
According to the first post in this thread the 6400 and 6450 are the same.
Bond 007 is offline
post #415 of 418 Old 02-21-2016, 08:52 AM
GizmoDVD's Avatar
Looks like LG Killed the NEWS feed from the Home Menu.
GizmoDVD is offline
post #416 of 418 Old 03-27-2016, 10:57 AM
GizmoDVD's Avatar
And magically it came back yesterday.
GizmoDVD is offline
post #417 of 418 Old 03-27-2016, 01:14 PM
Bond 007's Avatar
Liked: 2061
Happy Easter!
Bond 007 is offline
post #418 of 418 Old 06-21-2016, 06:31 AM
GizmoDVD's Avatar
News Feed stopped working a few days ago.
So glad LG is still supporting a TV that is barely 3 years old
GizmoDVD is offline
Reply LCD Flat Panel Displays
Lg Electronics 50ga6400 50 Inch Cinema 3d Led Lcd Hdtv With Google Tv And Four Pairs Of 3d Glasses , Lg Electronics 47ga6400 47 Inch Cinema 3d Led Lcd Hdtv With Google Tv And Four Pairs Of 3d Glasses
