Anyone bought LG LA6200? - Page 24 - AVS Forum
post #691 of 706 Old 05-10-2014, 04:28 PM
Dannyboy62's Avatar
I've tried the 30Sec powercord several times, I've even tried to keep the unit unplug all night and after a while it started again. I will try to unplug everything else which is the PS3 and Computer to see what happens next, I also try to download the firmware on a flashdrive and the TV did not recognize it as an update.
Dannyboy62 is offline
post #692 of 706 Old 05-12-2014, 10:40 AM
ShawPing's Avatar
Originally Posted by JackN View Post
I still have to confirm the switch by pressing "OK." Are you using a standard remote, or wand style?
I have a wand (magic) remote, and OK is not required.  However, I just noticed that using the buttons on the right side of the TV still requires the OK confirmation, so I suspect using a standard remote might as well (as is probably your case).
ShawPing is offline
post #693 of 706 Old 05-18-2014, 01:51 PM
tdehnke's Avatar
Recently while watching TV from my Shaw Gateway (Arris) source my 60LA6200 has a lot more jitter and jumpy motion on the screen - both on PVR and Live. IE panning scenes or moving objects don't go smoothly, they jump across the screen. Up till a couple weeks ago it was fine.
I tried a couple other TV's in the house and don't see it there, and I tried both component and HDMI input on my LA from the Gateway.
I'm running firmware 05.06.05 - which I think is new - I'm wondering if maybe something was done in an update (I have not applied any so I'm guessing the TV does it automatically?) that has changed how the set is processing the image?
Anyone else running into any issues?
PS - is there a way to install old firmware, I'd be curious to see if going to an older version cleaned it up.
tdehnke is offline
post #694 of 706 Old 05-21-2014, 08:18 PM
Gustavo Esqueda's Avatar
quick q...how does anyone enable Real Cinema Mode On? it is always greyed out on me.
EDIT: I think I figured it out. I have my laptop connected in clone display mode. For LG TV output, under Intel display options, I just changed refresh rate to 24p. I cannot say I have noticed any significant difference but I will keep my both eyes open :)
BTW, before I had some backlight issues but now it seems to have improved a lot. When I had the problem I previously had to clean my screen with a microfiber cloth and some water so maybe it altered somehow the LCD. Also it was winter at that time and temperature was dropping. I still think there is a temperature factor for lightbleed on this model because even during winter ,after using the TV for a few hours, the effect dissapeared almost completely. Now with a warmer weather I can baerly see the ligthbleed.
Gustavo Esqueda is offline
post #695 of 706 Old 06-04-2014, 06:34 AM
chemicle's Avatar
Just thought that I'd reply to this.  Even though the TV is now discontinued, I just picked up the 50" version and was wondering about a keyboard for this TV.  Browsers are great and all, but you are spot on regarding any sort of browsing without the ability to type.  Great recommendation on the keyboard.  Thank you.
chemicle is offline
post #696 of 706 Old 06-04-2014, 12:29 PM
Primestar31's Avatar
Here's the keyboard you need in my previous post here:
http://www.avsforum.com/t/1466842/anyone-bought-lg-la6200/480#post_23753042
Logitech Wireless Touch Keyboard K400 with Built-In Multi-Touch Touchpad (920-003070)
This model comes with a USB dongle, and works perfectly: http://www.amazon.com/gp/product/B005DKZTMG/ref=oh_details_o06_s00_i00?ie=UTF8&psc=1
Primestar31 is offline
post #697 of 706 Old 06-09-2014, 01:09 PM
LG service menu app updated with support for more devices...can anybody confirm it works with LA6200?
https://play.google.com/store/apps/details?id=it.gmg.android.lgsm
post #698 of 706 Old 06-09-2014, 06:45 PM
Messing with the service menu can be extremely dangerous. So, anybody that's willing to do that should know they could potentially brick their tv set.
post #699 of 706 Old 06-10-2014, 11:01 AM
I know, but I want to see if by gaining access to service menu I can enable the DVR capabilities. I have also heard in forums for other models that enabling local dimming was useful for black levels.
post #700 of 706 Old 06-10-2014, 04:18 PM
Jayadub's Avatar
The app works with the LA6200 but once in the service menu everything in that particular tool set is grayed out. It looks like unless there is another setting in one of the other tool menus that will turn on all the options, there is no way to activate THX mode or local dimming and the DVR.
DVR Time Machine isn't very useful anyway as it only ever worked over the air with an antenna. No way to record any cable broadcasts with it. I have it hooked up as an oddity on a 2011 LG I have, an LW5600 model.
Jayadub is offline
post #701 of 706 Old 06-29-2014, 01:56 PM
RichJH's Avatar
Quoted: 16 Post(s)
Originally Posted by chemicle View Post
<p>Just thought that I'd reply to this.  Even though the TV is now discontinued, I just picked up the 50" version and was wondering about a keyboard for this TV.  Browsers are great and all, but you are spot on regarding any sort of browsing without the ability to type.  Great recommendation on the keyboard.  Thank you.</p>
You can pretty well pickup any wireless keyboard that has a USB dongle. That is what I did because it is very tedious using the magic remote.
Rich
RichJH is offline
post #702 of 706 Old 06-30-2014, 03:07 PM
LGERIC's Avatar
My TV won't stay connected to the network via WiFi.Everything else in the house works perfectly. The TV and router are on the same stand. This is a newish problem I have owned the TV almost a year with no problems. Can anyone help with this?
LGERIC is offline
post #703 of 706 Old 07-07-2014, 10:37 AM
rolltide1017's Avatar
Quoted: 34 Post(s)
Liked: 233
I've had this TV for about a year now and overall I'm pretty satisfied. My only issues is that the dirty screen effect seems to be getting worse, or I'm just noticing it more. Anyone else notice something similar, does DSE typically get worse over time (this is my first LCD)?
PSN ID: RollTide1017
rolltide1017 is online now
post #704 of 706 Old 07-08-2014, 05:19 PM
That used to happen with an older firmware. Have you ever updated?
Is there anyway to run a Ethernet cable to you router, that's a better way t go.
post #705 of 706 Old 07-13-2014, 04:24 AM
LGERIC's Avatar
Yes firmware is current. I am just going to run a cable so I don't have to mess with it.
LGERIC is offline
post #706 of 706 Old Yesterday, 09:06 PM
rdh86's Avatar
Hey, quick question. Does anyone know if the netflix app plays/displays content at its native resolution? ie 23.9/24p. Thank you.
rdh86 is offline
Reply LCD Flat Panel Displays
Lg 55 Inch Class Cinema 3d Smart Led Tv Smartv 55lm6400 , Lg Electronics 55ln5400 55 Inch Led Lcd Hdtv With Smart Share , Lg Electronics 39ln5700 39 Inch Led Lcd Hdtv , Panasonic Tc P50st60 50 Inch 3d Smart Plasma Hdtv , Lg Electronics 47la6200 47 Inch Cinema 3d Led Lcd Hdtv
