Anyone bought LG LA6200? - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #781 of 806 Old 03-25-2015, 02:00 PM
Andymp3's Avatar
Originally Posted by csuzv View Post
TV repair man fixed the problem, nothing to do with 05.09.02. He replaced an internal power cable with one of a newer design, apparently this is quite a regular occurrence with this design.
I am happy to hear issue was resolved quickly. I had bought the 50A6205 TV and returned it after a week because of screen backlight issues. I did like the TV though. I decided to go with the Samsung 50F6800 and am happy with my purchase but still miss the LG ever once in a while. I especially like the remote and passive glasses. Hope it stands up to the test of time. Good luck sir.
Samsung 50F6800 3D smart TV, LG BP530 3D BR, Logitech Smart Control
Onkyo TX-NR609
2 Polk T600 tower speakers
4 Axiom M3Ti speakers
1 Paradigm CC170 center channel
1 Infinity PS28 Sub, 1 Polk PW125 Sub
Andymp3 is offline
post #782 of 806 Old 04-01-2015, 01:48 PM
Primestar31's Avatar
Quoted: 73 Post(s)
Liked: 45
New firmware out there today: 05.09.03
I've loaded it, but as usual, can't tell what difference it makes.
Primestar31 is online now
post #783 of 806 Old 04-03-2015, 05:55 AM
JackN's Avatar
Quoted: 36 Post(s)
Faster input switching? I thought I'd noticed that with a previous update, but there's always been an occasional hitch where I'd hit the button and experienced a delay...or had to select my desired source a second time. Pretty seamless now; I hope it lasts.
JackN is offline
post #784 of 806 Old 04-13-2015, 09:35 PM
Quoted: 73 Post(s)
Liked: 45
I agree, it does switch faster between inputs.
post #785 of 806 Old 04-16-2015, 07:07 PM
MarkB49's Avatar
Quoted: 35 Post(s)
Originally Posted by MarkB49 View Post
Well
I got so mad I took it apart.
I took some pictures of the mother board and the lines.
Everyting felt cool, I guess it should since it's been off for an hour and a half.
Let's see if the pictures will show up.
I'm tired I put 8 sensor's on my s-10 --1997.
Today 4-16-2015 My 42" 6200 series is still working just Fine!!
MarkB49 is offline
post #786 of 806 Old 07-10-2015, 10:49 PM
PhilipsPhanatic's Avatar
Quoted: 398 Post(s)
Liked: 52
Friend has this model....can someone give me good picture settings for him ? He is still using the factory defaults, plus whatever changes whoever first played with it used.
PhilipsPhanatic is offline
post #787 of 806 Old 08-28-2015, 02:11 PM
Quoted: 73 Post(s)
Liked: 45
Selecting input choices?
Has anybody ever figured out how to DIRECTLY select individual inputs with the remote on this model tv? Instead of hitting the "INPUT" button, bringing up the interactive screen, scrolling to the input you want, and THEN hitting the "OK" button to select it.
I'm hoping there is a DIRECT way to do this?
post #788 of 806 Old 08-28-2015, 02:40 PM
john44a's Avatar
Well....2 weeks short of owning this set for 2 years , it has developed a high pitch whine/squeal ,can't even watch it...I bought the sam's 3 year replacement plan at the time of the purchase...I won't have time to start the process until Monday. But , I'll let y'all know how it goes.
Primestar : that seems to be the only way.
john44a is offline
post #789 of 806 Old 08-30-2015, 10:09 PM
JackN's Avatar
Quoted: 36 Post(s)
Never have. This situation's even worse with LG's LM7600, which only shipped with a "wand" style remote. With that model, the shortest route to input selection had an extra step: pressing 'Quick Apps,' then Input, then selection of desired source and confirming...and that's after waiting for the slower processor in that set to even allow entry to the input screen.
The LA6200's a breeze after that. But if they wanted to make a fundamental improvement in these otherwise solid units, it would be addressing the clumsiness of Input switching...
JackN is offline
post #790 of 806 Old 08-30-2015, 10:12 PM
JackN's Avatar
Quoted: 36 Post(s)
Bummer.
Are you getting this sound over the TV's built in speakers, external audio...or is it emanating from inside the unit itself?
JackN is offline
post #791 of 806 Old 08-30-2015, 10:30 PM
Quoted: 73 Post(s)
Liked: 45
I found DIRECT HDMI-1, 2 and 3 LG codes usable for a JP1 type remote, and programmed them into a remote I had laying around. SO, the codes exist and the tv can do it, it's just a dumb decision on LG's part to not program the capability into the LA6200's regular remote.
First, program your JP1 universal remote using LG TV setup code 0178 (or 10178 depending on the remote, mine was 10178) then:
HDMI-1 direct select (or it also cycles direct through all 3 inputs on each press!) is EFC code: 00174 (for newer 5-digit remotes, 174 for 3-digit remotes)
HDMI-2 is EFC code: 00044 (044 for 3-digit remotes)
HDMI-3 is EFC code: 00081 (081 for 3-digit remotes)
How to Program 'Effective Function Code' (EFC) above for a single device on a universal JP1 remote:
1: TAP a DEVICE button on the JP1 remote (eg, TV in this case)
2: PRESS and HOLD the SETUP (P on mine) button until the red LED flashes twice, then RELEASE.
3: TAP 9 - 9 - 4.
4: TAP the SETUP (P) button
5: TYPE the 3 or 5 digit EFC code above (aka "advanced code")
6: TAP the regular button (eg, VOL+ (whichever button you want assigned this new code)) - two Blinks. You are now done.
This is all thanks to "mdavej" on the tivocommunity.com forum who gave me the idea, and enough info to carry it out. Now that I have DIRECT codes for the inputs, I can teach them to my new Tivo Slide-Pro learning remote when it arrives.
post #792 of 806 Old 08-30-2015, 10:31 PM
john44a's Avatar
Bummer.
I'm running a sony sound bar. The whine is coming from inside the tv. Nothing else on , tv only, internal speakers streaming youtube and it still comes through... If I don't get square trade to replace it , there is a pretty good tv shop just down the road from me. Worst comes to worst I'll go buy a samsung and sell this lg on craigslist "as is".
john44a is offline
post #793 of 806 Old 08-30-2015, 10:38 PM
Quoted: 73 Post(s)
Liked: 45
I had this happen once with my Vizio soundbar I'm using on my LA6200. The optical cable that jumps from the back of the tv set to the soundbar came unplugged just slightly on one end, and it squealed to beat the band. I clicked/reseated it back into place, and it was then fine.
I've read in a few places now about people having certain issues with this tv, that took the back off it, and reseated the board cables, which fixed them.
Maybe one or the other will help you?
post #794 of 806 Old 09-11-2015, 05:02 AM
Liked: 0
Can anyone confirm if this TV plays Full SBS 3D files via USB?
I looked up the manual and this is what I found:
dinosaurus is offline
post #795 of 806 Old 09-11-2015, 10:03 AM
rolltide1017's Avatar
Quoted: 235 Post(s)
Liked: 356
So, was there a firmware update that enable 5.1 pass-through over optical?
Since the newly announced Apple TV no longer has an optical out, I was doing some test with my current Apple TV 2 to find out the best way to get 5.1 to my AVR (it's older and only has 2 HDMI inputs, both in use). I tried plugging the ATV directly into HDMI 2 with optical running out of the TV to my AVR and... it passed 5.1 Dolby Digital to my AVR! I was surprised because I swear this didn't work a few years ago when I bought my 55LA6200.
I works now though, at least with my Apple TV 2, and means less rewiring. Now I don't have to downgrade my PS4 to optical and can keep it hooked up to my AVR via HDMI, instead of the new Apple TV.
rolltide1017 is online now
post #796 of 806 Old 11-10-2015, 01:13 PM
Quoted: 73 Post(s)
Liked: 45
Just downloaded and installed firmware upgrade 05.09.06
As usual, there's no telling what's new in it.
post #797 of 806 Old 11-15-2015, 03:51 PM
Wekurtz74's Avatar
The whole upgrade for this TV is confusing. If you go to their support site for this TV, you can almost be tricked into thinking you can upgrade to web os 2.0. It is very frustrating. I am trying to get my Harmony Hub to work with the SmartTV functions and it seems impossible
Wekurtz74 is online now
post #798 of 806 Old 11-15-2015, 05:19 PM
Quoted: 73 Post(s)
Liked: 45
Well, I don't know what a "Harmony Hub" is, but if you search back to a previous post of mine in this thread, you will see that I have a wireless keyboard with built-in scroll pad hooked up to it, and it works well for doing the keyboard functions when needed. Those keyboards are only around $25 or so at Amazon, and it was plug and play for the usb dongle.
post #799 of 806 Old 11-16-2015, 08:08 PM
Wekurtz74's Avatar
Sorry, I was a bit vague because I was frustrated. Let me elaborate. I just purchased the Harmony Smart Control Hub with simple remote. My basic programming is fine as far a turning tv on with correct HDMI input. However, more frequently than not, the TV is used for smart functions such as Amazon Video and Vudu apps. There is supposed to be a way to set up activities that, with a simple "click" that sets in motion a series of actions................turn on the tv, open the smart TV app of your choice, etc. . I have seen procedures online to set these up, but not LG specific directions, and the options described in the procedures simply do not appear when I attempt set up. That is my issue. I was hoping a firmware upgrade on LGs part might help out. I will attempt to find your prior posts to see if those are revealing concerning this issue.
Last edited by Wekurtz74; 11-22-2015 at 09:33 AM. Reason: Edit: I may have resolved this issue. Will update again if relevant.
post #800 of 806 Old 12-06-2015, 07:34 AM
Quoted: 235 Post(s)
Liked: 356
What is best to use to clean the screen, can you use regular glass cleaner?
post #801 of 806 Old 12-07-2015, 08:19 PM
Quoted: 73 Post(s)
Liked: 45
NO!!
Get a very soft cloth rag, and soak 1/2 of it in water. Then wring it out. Then wipe lightly in straight strokes across the screen, from top to bottom with the wet part of the towel. Then do the same thing up and down. Then if there's still water on the screen, do the same with the dry half of the towel.
Sort of like you are doing a car windshield, with one of those squeegee things. Only using a towel in this case, AND a very light touch! It's easy to scratch these screens. It's also easy to permanently damage them with cleaners, even ones that CLAIM they can be used. Water is plenty good enough...
post #802 of 806 Old 12-24-2015, 05:05 AM
LGERIC's Avatar
Quoted: 14 Post(s)
I am noticing very bad SOE from the internal streaming apps like amazon/netflicks. Bluerays and regular tv are ok. Trumotion is off. Are there settings for this? Am I missing something?
LGERIC is offline
post #803 of 806 Old 09-10-2016, 09:31 AM
Quoted: 235 Post(s)
Liked: 356
For awhile now our LG keeps asking us to accept new TOS when we enter the apps menu every few days. Also, apps added to the quick menu disappear and have to be re-added every few days. Is anyone else seeing the same things, any know solution?
post #804 of 806 Old 09-10-2016, 10:35 AM
john44a's Avatar
what is TOS ? I just installed the redbull tv app yesterday , worked perfect.
mine has not done that yet and I'm in FL.
turns out my tv was not bad (if you read my previous post above)....I developed tinnitus in my ears : / felt like a complete moron.
john44a is offline
post #805 of 806 Old 09-23-2016, 07:53 AM
Quoted: 235 Post(s)
Liked: 356
TOS = Terms of Service
post #806 of 806 Old Today, 03:00 PM
Quoted: 235 Post(s)
Liked: 356
I know this TV has always had "dirty screen effect" problems but it seems to be getting worse and worse as this set ages. Yesterday I noticed a very faint line that goes horizontally across the whole screen about 1/4 of the way down from the top of the screen. I assume this is just DSE getting worse. It appears on all inputs and while all media is playing. It is really only noticeable to me on very bright scene with vertical panning, even then you have to know where to look.
Has anyone seen something like this before?
I paid for the extended BB Geek Squad protection for this TV and it is good through this August. Does anyone know if they will do repairs for DSE? I may call and see what they say, can't hurt I guess. We can't afford a new TV right now but, if this keeps getting worse then I will not be able to stand looking at the image.
Reply LCD Flat Panel Displays
Lg 55 Inch Class Cinema 3d Smart Led Tv Smartv 55lm6400 , Lg Electronics 55ln5400 55 Inch Led Lcd Hdtv With Smart Share , Lg Electronics 39ln5700 39 Inch Led Lcd Hdtv , Panasonic Tc P50st60 50 Inch 3d Smart Plasma Hdtv , Lg Electronics 47la6200 47 Inch Cinema 3d Led Lcd Hdtv
