Sound probelms with Vizio M650VSE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-06-2013, 06:41 PM - Thread Starter
rdwells's Avatar
I just purchased a Vizio M650VSE. I haev DIRECTV and I have my surround sound system connected to the satellite recevier. The only problem is that when I have both the surround sound system turned on and the TV speakers on I get a terrible echo. Is there a way to correct that? I tried turning off the Dolby digital on both the TV and the surround sound but it didnt make a difference. thanks
rdwells is offline
post #2 of 3 Old 04-07-2013, 01:02 AM
rickie's Avatar
if you're going to use your surround sound system, i think you will need to turn off the TV speakers in the tv audio menu.
Rick
rickie is offline
post #3 of 3 Old 04-07-2013, 01:27 AM - Thread Starter
rdwells's Avatar
Okay thanks
rdwells is offline
Reply LCD Flat Panel Displays
