Official Samsung UN**F6300 series LED TV Owners Thread. - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #271 of 2395 Old 10-18-2013, 11:33 AM
Chuck_IV's Avatar
Quoted: 98 Post(s)
Liked: 54
Originally Posted by DJaye View Post
Does anyone know why a F6300 randomly switches inputs on the receiver within 2-4 hours of watching TV?
Is it really random or is it just switching to your ARC input port on the receiver? With ANynet enabled, mine will auto switch to the ARC port on the receiver, whenever I enter a Smart TV app and go back to the input I was ne, when I exit the app. Otherwise, the only time it switches is when I first turn everything on. When the ARC connection is first made with my receiver(Denon), the Denon needlessly insists on changing to the ARC port, even tho I haven't goen to the Smart TV section. I have to manually jump back to the normal input. This is a Denon issue, not a Samsung issue tho.
Chuck_IV is offline
post #272 of 2395 Old 10-19-2013, 09:50 AM
mobileES's Avatar
Quoted: 67 Post(s)
Liked: 45
Just picked up this 55" set (the F6300), coming from my 3yr old 40" Toshiba, I am blown away!!! I am officially a Samsung loyalist for life now. Picture quality is amazing! More connections than I'll ever need. A few things I am curious about, on my Toshiba it had a picture size setting for "Native" and it would automatically display content recorded in 4:3, 16:9, etc in the correct size. Does the Samsung have a default setting for this, I didn't want to have to go through the picture settings menu to watch older tv shows then change it to watch newer movies. Also I know in the manual it says it supports a USB keyboard and mouse, would this include a wireless one say from Logitech?
Dolby Atmos 7.1.4; Onkyo TX-NR3030; Energy C2 (fronts); Energy C-C1 (center); Energy C-R100 Side Surrounds; Energy C-R100 Rear Surrounds; Energy Take Classic Satellites Top Front & Rear; Samsung 65" SUHD 8000 Series TV; Samsung UBD-K8500 UHD Player;
Velodyne VA-1215XII Sub
mobileES is offline
post #273 of 2395 Old 10-19-2013, 03:00 PM
bobjared's Avatar
Earlier in this thread there was extensive discussion regarding Version Numbers and Screen Manufacturer. For the 46" model - UN46F635ax found at Costco the Version no/screen was "TS 01".
Last week I looked again at the sticker on the box at my local Costco and for this 46" model, the Version was: "TU 02". This number was not discussed previously in this thread. Does anyone have any further info on this particular screen or any comparison to the 'TS 01" ?
Thanks so much !
bobjared is offline
post #274 of 2395 Old 10-19-2013, 05:07 PM
heresnowhy's Avatar
Liked: 34
Both my 40 and 46 F6300 have TU 02 on them. Purchased at Best Buy. Was curious myself, just didn't ask...
heresnowhy is offline
post #275 of 2395 Old 10-19-2013, 06:20 PM
Ice Cold's Avatar
Quoted: 25 Post(s)
Thanks so much !
The going theory is that TS01 Are high quality Samsung Made panels. As stated by Samsung technicians. Samsung will make an initial batch of panels. as time progresses a few months they will make fixes or improvements to those Panels, and change the Version number. These improved Samsung made Panels are called Prime Panels. Pretty much the holy grail for Samsung. The Prime panels Versions are TU02. I think pretty much all of the 46 inch F6300 series are these the Prime Panels.
This could be explained by several other posters confirming their Version numbers. And I personally have 2 46 inch F6300 models both TU02. And it stands out because bother are perfect. By that I mean.
- No banding
- No DSE
- No smearing or trailing while gaming like on the F7100 series (yikes)
- No Flashlighting not even a little I can have a white ball in the center screen surrounded by black only the white ball gets lit up with crisp bordered and no dimming.
CNET's review points out the F6300 is a True 120hz panel. And that it displays 1200 lines of motion resolution, a feat that matches the $3,000 F8000 Series. And delivers near reference quality colors when calibrated. Now thats Samsung quality. Samsungs Speciality is the Mid range thats what they do best. And they did it.
Ice Cold is offline
post #276 of 2395 Old 10-19-2013, 06:33 PM
brian2013's Avatar
Have the 40F6300
All apps just got deleted - currently ONLY have the web browser. anyone else had this happen?
Tried seseting TV etc
suggestions?
brian2013 is offline
post #277 of 2395 Old 10-19-2013, 10:55 PM
Jocelyn84's Avatar
Originally Posted by brian2013 View Post
Have the 40F6300All apps just got deleted - currently ONLY have the web browser. anyone else had this happen?Tried seseting TV etcsuggestions?Thanks
Same here (F6300), I was worried but they all came back a little while ago smile.gif
Jocelyn84 is offline
post #278 of 2395 Old 10-21-2013, 07:45 AM
brian2013's Avatar
Jocelyn84, thanks, yup some of mine have returned but not all. At least the ones I used the most have returned, but it did mess up my Saturday Night Movie redface.gif)
post #279 of 2395 Old 10-21-2013, 10:07 AM
mobileES's Avatar
Quoted: 67 Post(s)
Liked: 45
Originally Posted by Nevermore0 View Post
Alright, so I looked again and I had definitely hurt my black levels with those adjustments, but I've tweaked things some more and I think it's looking really good right now. Surprisingly the flesh tone setting does seem to help a bit. Here are all of my settings:
Backlight: 16
Contrats: 95
Brightness: 48 (this might be a little high for some people, but I like being able to see all the details in dark scenes)
Sharpness: 15
Color: 47
Tint G/R: 50/50
Flesh Tone: +10
White Balance---
R-Offset: 21
G-Offset: 23
B-Offset: 22
R-Gain: 19
G-Gain: 10
B-Gain: 45
Gamma: +1 (you can increase this if it still seems too yellow to you, but everything else washes out too)
Looks pretty fabulous with these setting IMO, but your mileage may vary. The one thing I would note is that blues don't quite pop as much as you may like, but it's not something I'd even notice if I wasn't directly comparing it to my desktop monitor. Blue things are still blue.
Hope these work for you all. Good luck!
I used these settings a so far the picture looks great with the newer movies like Oblivion.
mobileES is offline
post #280 of 2395 Old 10-21-2013, 10:38 PM
bookcookr's Avatar
- No banding
- No DSE
What does the following mean?
- No banding
- No DSE
bookcookr is offline
post #281 of 2395 Old 10-22-2013, 02:55 PM
kohmei's Avatar
I've had my 46" F6350 for about a week now, and during a video I was streaming on Netflix, the audio started randomly cutting out: at first for just a second or two, but then up to several minutes at a time. It's just the audio, as the video keeps playing uninterrupted, as if someone put the TV on mute; and, it's the stream audio only, as the beeps and boops the menu software makes continue to play. I've tried different streams on the TV and the problem is definitely there, as well as tried the same streams on other devices without experiencing the same problem.
I tried googling this problem, only to find one single reviewer on Amazon reporting the same problem. He says the problem is commonplace, but his review is the only evidence outside the two of us I can find of it occuring. Is this indeed a common problem and I just can't find any more instances of it? Did I just get a lemon?
kohmei is offline
post #282 of 2395 Old 10-25-2013, 10:58 AM
cu52's Avatar
Bright spots on Screen?
I have recently purchased a UN60F6300. I am not thrilled with the picture and have played with a lot of the settings, i might have figured out why.
When I turned off the system with my harmony remote, i was too far to the side to turn the TV off. So the TV was still on and no input from the HDMI cable. I noticed several bright sports on the screen. (backlight at level 13)
Samsung chat help was usless. "Change backlight to 7 and leave it for a week let us know if it returns". Guessing it would remain but be less noticeable.
Thoughts?
Do I need to exchange this TV?
Thanks in advance for your assistance.
cu52 is offline
post #283 of 2395 Old 10-25-2013, 06:54 PM - Thread Starter
1ceTr0n's Avatar
Liked: 33
Yep, exchange that thing pronto
1ceTr0n is offline
post #284 of 2395 Old 10-25-2013, 07:04 PM
snorge's Avatar
Quoted: 154 Post(s)
Liked: 39
Thanks so much !
Someone already replied to this but just to add to it TU02 is basically the same panel as TS01 but from the next manufacturing cycle which may include improvements. What improvements? Who really knows... If you check the panel ID in the service menu both TU02 and TS01 give the exact same code. Whichever you get they are both definitely Samsung panels I have a TU02 and it has been great so far.
snorge is offline
post #285 of 2395 Old 10-26-2013, 09:12 AM
cannondale0815's Avatar
Did anyone try the new firmware 1115.1 that came out yesterday?
http://www.samsung.com/us/support/owners/product/UN60F6300AFXZA
Description as follows:
This firmware is for TV Model(s): LED F5500/F6300/F6350/F6400/F6800/F7050/F7100/F7150, PDP F5500
The version is 1115.1
This firmware update will improve the following:
- Solves Network Connection Issue with Wireless Router.
- Improves Picture Quality.
- Solves the issue Screen Mirroring does not work.
- Solves the issue Digital Clean View does not work correctly.
cannondale0815 is offline
post #286 of 2395 Old 10-26-2013, 09:49 PM
milkk's Avatar
Quoted: 86 Post(s)
Liked: 32
Just installed the update via usb tv works fine so far smile.gif It's late my eyes are closing don't know if the picture quality is better lol I'm still mesmerized by the tv, only had it 2 weeks ehhe.
cannondale0815 likes this.
Samsung UN60H7150AF/Xbox One
Denon AVR-S710W
SVS Prime Bookshelves - SVS Prime Center - SVS PB-1000 - Onkyo SKH-410
milkk is offline
post #287 of 2395 Old 10-27-2013, 11:40 AM
scottvamp's Avatar
Liked: 31
Did the update yesterday. Took close to an hour and I have pretty fast internet. TV works fine but I still have that annoying pop up everytime I change sources:(
scottvamp is offline
post #288 of 2395 Old 10-27-2013, 12:09 PM
milkk's Avatar
Quoted: 86 Post(s)
Liked: 32
Try Samsung Support maybe they might have a fix? I have never seen that on mine but I have never really used the Samsung remote other than to access the menu quickly just use my Harmony.
Denon AVR-S710W
milkk is offline
post #289 of 2395 Old 10-27-2013, 12:30 PM
snorge's Avatar
Quoted: 154 Post(s)
Liked: 39
Did it let you update through the tv or did you download the usb package?
snorge is offline
post #290 of 2395 Old 10-27-2013, 12:45 PM
milkk's Avatar
Quoted: 86 Post(s)
Liked: 32
I think he did it via the TV if it took that long. I didn't have the TV option yet here in Canada so I grabbed it off the website and installed via USB.
Denon AVR-S710W
milkk is offline
post #291 of 2395 Old 10-27-2013, 01:48 PM
scottvamp's Avatar
Liked: 31
I did it through the tv. I thought some tweeker would have figured out my pop up issue - lol
I will have to call Samsung this week. That update did not fix any major issues that I was aware of.....
post #292 of 2395 Old 10-27-2013, 08:34 PM
vinnny's Avatar
Should I be leaving the digital sound option to Neo 2:5 ? PCM is the only other option. When PCM is selected my AVR display only shows 2 speakers but when Neo 2:5 is selected the display shows 5 speakers but I don't hear anything from the rears. confused.gif
vinnny is offline
post #293 of 2395 Old 10-27-2013, 10:53 PM
HoundBaby's Avatar
Quoted: 53 Post(s)
Liked: 31
Just tried to update via the TV software update menu.. Get the message there are no new updates for you at the moment. My current ver. 1113.
HoundBaby is offline
post #294 of 2395 Old 10-28-2013, 07:09 AM
HoundBaby's Avatar
Quoted: 53 Post(s)
Liked: 31
Was able to perform upgrade via TV software menu. Upgrade took a little over 5 minutes. Current ver. 1115. This is the third firmware update since I purchased this TV Sept. 30. Firmware ver. 1108, 1111, 1113, and now 1115.
post #295 of 2395 Old 10-28-2013, 01:27 PM
sicknesstv's Avatar
Has anyone had issues turning your tv on (65inch 6350 from costco)? About once maybe twice a week my 6350 wont turn on and the light at the bottom left will blink red. If I unplug the tv for a few seconds and plug it back in it seems to work just fine.
Wondering if my set is faulty .. or if my monster green power surge protector is the culprit... I will most likely be exchanging this weekend.
sicknesstv is offline
post #296 of 2395 Old 10-28-2013, 02:07 PM
sabih786's Avatar
Does anyone know what HDMI versions this tv has, I plugged in a chrome cast but it does not provide power via only the HDMI. I thought this tv was HDMI V1.4 and as such should support power?
sig
sabih786 is offline
post #297 of 2395 Old 10-29-2013, 03:00 PM
Chromecast needs to be powered via the USB cable that came with it.
Some discussion on this here.
sabih786 likes this.
post #298 of 2395 Old 10-30-2013, 04:52 PM
vinnny's Avatar
Are any settings lost when doing a firmware update ?
vinnny is offline
post #299 of 2395 Old 10-30-2013, 09:37 PM
HoundBaby's Avatar
Quoted: 53 Post(s)
Liked: 31
All my settings remained the same after each firmware update.
post #300 of 2395 Old 10-31-2013, 05:42 AM
Scott Oakley's Avatar
Quoted: 76 Post(s)
Liked: 95
Same here...
Panasonic 2013 55VT60
Marantz SR-5012 AVR
B&W 805 Speakers
Velodyne 10" Sub
TiVO Premiere
Scott Oakley is offline
Reply LCD Flat Panel Displays
Xbox 360 250gb Console With Kinect
