Official Samsung UN**F6300 series LED TV Owners Thread. - Page 72 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #2131 of 2395 Old 06-23-2014, 04:33 PM
Vampidemic's Avatar
Quoted: 33 Post(s)
Liked: 48
Originally Posted by renegade72 View Post
can someone please explain to me what is the hdmi arc port on the back of the tv....I know it is for audio purposes but is this an input or output from the tv?
Both. It functions as an input for video + audio like the other HDMI ports, but can also output audio from the TV to an AVR when HDMI-CEC is enabled on both devices.
ARC = Audio Return Channel
Vampidemic is offline
post #2132 of 2395 Old 06-25-2014, 01:41 AM
JingoFresh's Avatar
Quoted: 37 Post(s)
Just wondering if I could get your input..
I understand ARC is the replacement for optical and HDMI-CEC allows for power on / poweroff..
Are ARC and CEC used on the same HDMI port, the receivers single HDMI out?
I just bought the Yamaha YHT-49 receiver and speakers package, which supports true surround and HDMI-CEC and ARC. I had the option of getting that or the Onkyo HT-S3500 which seemed much the same, but I figured Yahoo was a better quality brand.
Was one of those systems better than the other or more compatible with this series of TV?
JingoFresh is offline
post #2133 of 2395 Old 06-25-2014, 07:24 AM
Vampidemic's Avatar
Quoted: 33 Post(s)
Liked: 48
HDMI-CEC can work on any port if both devices support it. It can be used for other control functions besides power off (example: volume, channel change, etc.)
ARC requires specified ports. Your TV has an ARC port, on a receiver it would be the TV connection port.
Not sure as to whether either of those receivers have compatibility issues with this TV. These issues, if present can be annoying, but are usually manageable.
post #2134 of 2395 Old 06-25-2014, 07:29 AM
JingoFresh's Avatar
Quoted: 37 Post(s)
Only thing I am unclear on is if HDMI-CEC and ARC can be on the same HDMI port or not?
post #2135 of 2395 Old 06-25-2014, 07:35 AM
Rbrodzinsky's Avatar
Quoted: 14 Post(s)
Yes, the TV is plugged into the HDMI-Out port on the AVR. HDMI-2 input on the TV allows the use of ARC (and CEC), while the HDMI-1 input only supports the CEC commands, without audio return.
Both brands you note are good, and you can find avid supporters of either.
Rick Brodzinsky
SF Bay Area - OTA & Xfinity
Samsung UN46F6350
Marantz NR1604
TIVO Premiere
Samsung BD-5900
Rbrodzinsky is offline
post #2136 of 2395 Old 06-25-2014, 08:17 AM
Vampidemic's Avatar
Quoted: 33 Post(s)
Liked: 48
Yes, HDMI-CEC must be on to use ARC.
post #2137 of 2395 Old 06-26-2014, 02:58 PM
tatanka01's Avatar
I think a lot of people use WMC, so not sure why you are having this issue. I think there is a WMC thread where you might want to ask about this.
I like Serviio though, it has remuxing and transcoding features that increase compatibility for playback.
Thanks! I'll do some playing. Lots to learn in the world of media servers -- I just today noticed that I can play movies at work on my phone that are hosted on my PC at home via "Samsung Link." What will they think of next?
tatanka01 is offline
post #2138 of 2395 Old 06-26-2014, 03:00 PM
NuSoardGraphite's Avatar
Quoted: 397 Post(s)
Liked: 360
Yes, HDMI-CEC is the control capability that is a part of the HDMI spec. It allows HDMI devices to control each other. For example, if you have an HDMI-CEC capable Blu Ray player, an HDMI-CEC AVR and a Smart TV, they will control one another in certain circumstances. If you power on one, it will likely power on all of the devices. If you use the volume adjustment on your TV remote and HDMI-CEC is enabled, it will change the volume on your AVR.
Audio Return Channel, or ARC is a part of HDMI-CEC control. ARC capable devices can send AND receive audio through ARC but HDMI-CEC must be enabled. I had to do this on my F6300 and my Denon 1912 in order to get the F6300 to send audio to my speakers through the Denon AVR when watching content from the smart menu of my TV (Netflix, youtube, Spotify etc)
Enabling HDMI-CEC on your devices will create some annoying quirks. My tv likes to take control of my AVR when I power it on and automatically turn my AVR input to "TV" so that the smart hub will send audio to the AVR. But 90% of the time, I use my PS3 for content (Blu Ray, Netflix, Amazon Prime, games etc) so for a while I would have to manually switch my AVR back to PS3 (BD) input after power on even though my Harmony Remote already sent the signal to go to the PS3 input....the smart TV would take control and make the AVR switch to "TV" input because obviously the SmartTV takes precedence. So I eventually figured out that if I turn on my PS3's HDMI-CEC, when I power everything on and the SmartTV tries to take control, all I have to so is fiddle with my PS3 controller and the PS3 then takes over the AVR and makes it switch to the PS3 input. That poor Denon AVR is everybody's bitch.
it was annoying until I figured that out. Now it's just a little quirk. It doesn't really interfere with my ability to watch content, but until I figured that out I was pulling my hair out. LOL!
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #2139 of 2395 Old 06-27-2014, 06:28 AM
yankeeman's Avatar
Quoted: 390 Post(s)
Liked: 499
My wife just saw a message on the tv, so I dont know the exact wording, but she says it said something like "The terms and conditions of the smart tv have changed and you have to agree to the terms and conditions in order for it to work." Before she could do anything she said it disappeared. Anybody seen this or know what it is??????
never take life seriously
yankeeman is offline
post #2140 of 2395 Old 06-27-2014, 07:18 AM
JingoFresh's Avatar
Quoted: 37 Post(s)
Anybody using the Vizio s425 with this TV?
post #2141 of 2395 Old 06-27-2014, 06:40 PM
Vampidemic's Avatar
Quoted: 33 Post(s)
Liked: 48
I have seen this a few times, I have never pressed the okay button before the message timed out or paid much attention to the message. There doesn't seem to be a way to disable these messages or revisit them after they time out, but I have never been forced to 'agree' to anything to proceed either.
yankeeman likes this.
post #2142 of 2395 Old 06-28-2014, 01:04 PM
JingoFresh's Avatar
Quoted: 37 Post(s)
So I have a receiver, the Yamaha 497bl.
HDMI cable is connected from HDMI out on receiver (marked as ARC) to hdmi2 on my TV (also marked as ARC).
I got the TV to recognize the receiver, but no sound comes out no matter what audio input I choose on receiver.
Trying to play stuff through amazon and Netflix.
Everything is plugged in and connected correctly. What am I doing wrong?
post #2143 of 2395 Old 06-28-2014, 03:09 PM
Vampidemic's Avatar
Quoted: 33 Post(s)
Liked: 48
Make sure you have HDMI-CEC enabled on the TV and receiver, then check receiver input settings. There may be a thread for your receiver to get feedback on the needed receiver settings to use ARC.
post #2144 of 2395 Old 06-29-2014, 04:38 PM
Digiti's Avatar
I used the SmartTV function today and I was greeted by a TOS contract from Yahoo.com for some of its content which I accepted. Has anyone else received this?Thanks.
Digiti is offline
post #2145 of 2395 Old 06-30-2014, 01:35 AM
JingoFresh's Avatar
Quoted: 37 Post(s)
Is the official skype camera really the only one that works with the TV? Would like to just have one webcam and would be fine with switching it each time. $70 for a dedicated TV webcam seems expensive.
post #2146 of 2395 Old 07-02-2014, 02:33 PM
yankeeman's Avatar
Quoted: 390 Post(s)
Liked: 499
Thanks bud. We havent seen it again. Why oh why are electronics nowadays so flaky???? So far after a few months though, the set works perfectly, including Netflix (I havent checked to see what software level i am on, but when it was delivered the Geek Squad set it up for automatic upgrading).
post #2147 of 2395 Old 07-09-2014, 04:42 PM
ss-stingray's Avatar
Hi,
I have a un60f6350 and it is on OTA antenna with a tivo roamio. The last 2 weeks when I turn it on in the morning it will change from HDMI 1 to antenna all by itself. I had it down load the 1200 firmware, but it still changes imput to antenna. Sorry if this issue is common but I'm new to this thread.
SS-Stingray
ss-stingray is offline
post #2148 of 2395 Old 07-10-2014, 06:27 PM
Digiti's Avatar
As far as I know the Samsung camera is the only one that works properly.
Digiti is offline
post #2149 of 2395 Old 07-10-2014, 08:14 PM
Vampidemic's Avatar
Quoted: 33 Post(s)
Liked: 48
Originally Posted by ss-stingray View Post
Hi,
SS-Stingray
If you are using ARC and an AVR , this is a common issue affecting certain AVRs. The most effective resolution is to feed the AVR with the optical output and turn off HDMI-CEC/ARC.
FYI, as best I can tell, the TV never sends anything other than AC3 (up to 5.1) or PCM (2.0) using ARC. I don't believe there is a quality advantage to using ARC (as would be the case if the TV could output DD Plus not supported over optical).
post #2150 of 2395 Old 07-11-2014, 06:45 AM
Thanks but I didn't understand your reply. I called Samsung and they remotely reset to factory. I will know tomorrow if fixed. It seems to be fixed since it didn't repeat after reset. Once again smart tv's that dumbed down.
SS-Stingray
post #2151 of 2395 Old 07-11-2014, 03:19 PM
obonillaf's Avatar
Quoted: 68 Post(s)
Liked: 37
Hello. Don't blame but sometimes I like the so called "soap opera effect" (judder reduction). I use a 32F6300 HDTV with my PC and whenever I play a BD movie or watch a youtube.com video I can clearly see these "soap opera effect" but whenever I watch a movie in the .mkv format (via players like VLC or JRiver or any other player) no "soap opera effect" is there. Reading the judder reduction description of my TV it says that it works with "video source with film signals". If my TV reads the signals fed from my BD player and from youtube.com how can I make my TV to read the signals from my .mkv players as "film signals" too so I can have said SOE when watching those .mkv files? Any help would be much appreciated!
obonillaf is offline
post #2152 of 2395 Old 07-13-2014, 03:26 PM
Liked: 0
Sorry for the noob questions. I'll be receiving a UN50F6300 in a few days, it will be my 1st smart TV.
1- Can it play most movies typically found on torrent sites in 720p mp4 (x264) ?
2- Do you guys recommend I get a sound bar?
3- Any must-have accessories i should get? (keyboard, remote, mouse, xbmc box, etc?)
cataplexy is offline
post #2153 of 2395 Old 07-13-2014, 06:56 PM
Rlin's Avatar
For #2 yes, get a sound bar. I find the speakers to be kind of weak.
Rlin is offline
post #2154 of 2395 Old 07-13-2014, 07:22 PM
FriscoDTM's Avatar
Quoted: 303 Post(s)
Liked: 272
Go check out the DIY speaker forum; specifically the SEOS Tempests
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One S, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #2155 of 2395 Old 07-14-2014, 05:17 AM
sensibull's Avatar
Forgive the dumb questions, but I don't have a smart tv and I'm trying to get some answers for a buddy who has this set and knows even less than I do.
1. Is it possible to control a smart app on this set (say, Pandora) with an iPhone, but with the tv's screen off? He'd like to use it as the source for his whole house audio setup, but doesn't necessarily want the tv on the whole time he's listening to music.
2. What's the best remote control app for the iPhone? I keep seeing terrible reviews for the official one from Samsung.
sensibull is offline
post #2156 of 2395 Old 07-14-2014, 02:48 PM
Liked: 0
Can the F6300s play x264 files in mp4 format?
post #2157 of 2395 Old 07-15-2014, 11:25 AM
n2speed125's Avatar
Quoted: 120 Post(s)
Liked: 127
Have a UN60F6300 that I purchased back in July of last year and recently have issues with the screen going completely black while the sound continues to play.. It only happens when I initially turn the tv on, it starts on and everything is fine for about 5 seconds and then the screen goes completely black.. If I hit the volume, the tv light up but turns off again a few seconds later.. Turning the tv on and off again usually fixes the problem but I'm afraid something is about to break.. The tv gets all it's input from an Onkyo receiver via a single HMDI cable that I just recently replaced thinking it might be the issue.. Any ideas? Had service center come out yesterday and they changed the t-con board but I can't really tell if it fixed it or not since it doesn't happen every day..
n2speed125 is offline
post #2158 of 2395 Old 07-19-2014, 10:25 AM
arrush's Avatar
Just a quick question, I picked up a 6300 on clearance and I am very happy with the set, until I get off center. We have couches all around and the picture really washes out at the sides. I was wondering how much different the viewing angle is on something like a 7100 compared to our 6300. Is it the same type of panel?
arrush is offline
post #2159 of 2395 Old 07-19-2014, 02:17 PM
yankeeman's Avatar
Quoted: 390 Post(s)
Liked: 499
I was surprised at how fast the picture washes out on the sides, just start getting few feet to the side and there it goes. Straight on its incredible though. If i have people over I put them right in front of the set and I sit on the side.
post #2160 of 2395 Old 07-20-2014, 06:44 PM
04ctd's Avatar
subscribing.
where is the motion control/jitter judder reduction?
motion seems to be jerky on the 60
UN60F6300AF (not sure what the AF means)?
thanks.
04ctd is offline
Reply LCD Flat Panel Displays
Xbox 360 250gb Console With Kinect
