Samsung T220HD tuner question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-07-2013, 09:02 AM - Thread Starter
papa1930's Avatar
Hello all.
Just bought a Samsung T220HD off ebay (store demo model). I am wondering if there is a way to tell if the built-in HDTV tuner is ATSC or DVB by the model number, or something else on the back of unit.
Anyone know if it's possible?
Thanks in advance.
info:
Samsung T220HD HDTV
model: T220HD
I
model code: LS22TDNSUV/ZA
s/n: TD22HVJS902195N
W3034634
(bar code)
papa1930 is offline
post #2 of 4 Old 04-07-2013, 04:28 PM
sitlet's Avatar
Umm, did you Google "Samsung T220HD"? If you did, the first 10 results give you your answer.
sitlet is offline
post #3 of 4 Old 04-08-2013, 09:44 AM - Thread Starter
papa1930's Avatar
Uhmm... yes I did, and....... NO it doesn't.
The T220HD is listed both ways, with an atsc, and also dvb tuners. I'm trying to find out how to differentiate between the two, and have even been to the Samsung website. Samsung euro lists the t220hd with a dvb tuner, and all the american sites list it with an atsc tuner.
THAT'S what I'm trying to figure out. How to tell which one I have by the model number, or some other way.
thanks for replying anyway.
papa1930 is offline
post #4 of 4 Old 04-15-2013, 12:00 AM - Thread Starter
papa1930's Avatar
Well,
After all the extremely helpful assistance here (insert extreme sarcasm smilie) I e-mailed Samsung directly, and they said that it actually had both atsc, and dvb tuners built-in. Seller had it listed as dvb only, but I took a chance it was atsc, and it paid off. I was having trouble getting my channels scanned, but I finally got it right, and all is well now.
papa1930 is offline
Reply LCD Flat Panel Displays
