Ofiicial Sony XBR-55X900A / XBR-65X900A Anticipation Thread ( Local Dimming and 4K Technoligy !! ) - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 303 Old 06-14-2013, 12:33 PM
joevfx's Avatar
Quoted: 29 Post(s)
To bad none of the movies that are on the 4k blu ray were actually shot in 4k. They were all shot 2k.
joevfx is offline
post #302 of 303 Old 06-15-2013, 07:35 PM
dreaux's Avatar
Quoted: 80 Post(s)
Liked: 51
If shot in 35mm it is 4K. If shot in 70mm it was shot in 8K equivalent.
4K is the equivalent of 35mm 1.85:1 in resolution (give or take). Where as 70mm's frame is over twice the width of 35mm's and about double 1.85's height..it will take more than 8K to capture 65/70mm 5-perf and three times that for IMAX.
dreaux is offline
post #303 of 303 Old 06-15-2013, 08:54 PM
Mark Rejhon's Avatar
Quoted: 14 Post(s)
Liked: 109
Don't forget the degradation that a 35mm original goes through, before the print gets projected in a multiplex projector.
Real 4K projected in a 4K digital cinema -- sadly -- is much sharper than most 35mm film projected in a multiplex, due to all the losses of the multiple steps (e.g. negative -> masters -> print)
Now....a flagship presentation in Chinese Mann Theatre, or one of the top-tier theatres.... That's a different story. Those really make sure the losses are minimal.
Mark Rejhon
www.BlurBusters.com - Everything Better Than 60Hz(tm)
Mark Rejhon is offline
Reply LCD Flat Panel Displays
Sony Xbr 55x900a 55 Inch 4k Ultra Hd 3d Led Tv , Sony Xbr 65x900a 65 Inch 1080p 120hz 3d Led 4k Ultra Hdtv , Sony
