Samsung UE55ES8000 vs UE55F8000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-14-2013, 08:22 AM - Thread Starter
alexbarreras's Avatar
Hi all,
After a depth review, I'm buying a Samsung 55" panel and I don't know if it's worth the 800€ extra which cost the F model. The only changes are one more HDMI, improvement from 800Hz to 1000Hz and a few changes in Sound, but I'm using an amplifier + 5.1 so they're not important for me.
I'd be glad if you can recommend me a tv to buy, maybe it's a bit risky to buy the top model as next yesr maybe 8000 series have 4K support... But on the other hand, the obsolescence of the ES model is bigger thsn the F. What should I do??
Finally, do you recommend me a media player to play MKV files? I'll watch usually BDRemux and 1080p movies, and a few 3D as well... Or the player inside Samsung's tvs is enough?
alexbarreras is offline
post #2 of 7 Old 04-14-2013, 09:21 AM
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
Hi Alex, I bought and own the UN55ES8000. I could still exchange it for the F8000. It depends on how picky and vunerable you are to what other people say. Are You one of those people that can't stand to live with buyers remorse ? What I mean by that is are you one of those people right after you buy something you wish you would of bought something else ? Are you one of those people that after you own something a couple of months and all through the 2 month period you say to yourself I could Have the F8000 if I didn't try to save some money or I should have bought the F8000 ? If your this type of person You better buy the F8000.
Are you the type of person who knows that most of the inprovments you will never notice on a day to day basis ? Are you the type of person who knows that most of what your paying up for can only be seen with a electronic test device ? Are you the type of person that knows when you play a BluRay movie you will never notice the difference unless you want your mind to ? If your this type person buy the ES8000.
alexbarreras likes this.
Nothing's Perfect So Stop Expecting It ! Glenee
Glenee is offline
post #3 of 7 Old 04-14-2013, 01:36 PM
gary2219's Avatar
Lol glenee well said
gary2219 is offline
post #4 of 7 Old 04-15-2013, 04:37 AM - Thread Starter
Great response, thanks!
And about the media player? Do you think Samsung's media player is enough or it's worth to have a separated media player for 3D, BDRemux, etc?
post #5 of 7 Old 04-15-2013, 08:03 AM
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
I can't Help you here, I have never used it.
Glenee is offline
post #6 of 7 Old 06-05-2013, 10:38 AM
bekindrewind's Avatar
Quoted: 131 Post(s)
Liked: 58
Hi all,
I wouldn't be so sure those are the only changes.
I've heard/read that some of the changes are they fixed the flash lighting, clouding and uniformity issues. That's an improvement in pq!
They have upgraded the processor too. They claim better voice/hand experience with the f8000. Different remote also.
I'd dig a little more into what changes have been implemented. I feel the F8000 is a much better set.
PRO-70X5FD, McIntosh MC205, Marrantz MM8077, Marantz AV7702MKII (7.1.4), Oppo UDP-203, Oppo BDP-93, JL Audio f113, B&W Nautilus, Richard Gray 400S, Harmony One
bekindrewind is online now
post #7 of 7 Old 06-07-2013, 07:27 AM
GunmetalR56's Avatar
Quoted: 162 Post(s)
Liked: 215
Also, you may want to look at both units and compare fit and finish if that matters to you. There IS a difference between the overall build quality and appearance(of the TV exterior) between the two models.
If you can look at them both in a store and play with the remotes..look at the uniformity of the 2 and see if you notice things like clouding/banding. These things have been improved on the F8000 but if you are one of the lucky ones and don't notice those things then you might want to save the money and get the ES.
Ascend Sierra Towers w/RAAL, Ascend Horizon Center w/RAAL, Ascend CBM-170 SE surrounds, PSB Imagine XA Atmos modules (x4)
SVS PB12 Plus (x2) PSA XV15SE (x2)
Denon X4200w / Emotiva Mini-X a-100
Samsung UHD BD K8500 / PS4 Pro
Sony XBR75X940C
GunmetalR56 is offline
Reply LCD Flat Panel Displays
Samsung 55 Inch 3d Ultra Slim Smart Led Hdtv Un55f8000 , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv
