Official Samsung UNxxF7500 Owners Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
Old 06-25-2014, 03:05 PM
Sam Dav's Avatar
XBMC Flicker
I just purchased a Samsung UE55HU7500 4K UHD. Is this the same model as in this thread?
Using OpenELEC, The screens keeps going black for a second and the resolution change notification on my tv comes up.
It's like XBMC is constantly changing the resolution or something but all the notifications say 1920x1080 60p.
This happens only when I navigate the XBMC menus. When I actually play a video inside XBMC, no flicker.
I tried it with 2 nvidia ion HTPCs and the same result. Any ideas?
Sam Dav is offline
Old 06-26-2014, 08:08 AM
VideoTech's Avatar
It may not be fully DLNC compliant. You may need to use a dif streamer.
Did you also check your connection? There was an issue with 7500's dropping the connection but that was resolved a few revisions back. Make sure you have the latest software. Also, try setting your router to a fixed 20 or 40mhz instead of auto. That helps a lot of wireless gear.
As for posting: Generally the threads go by size since Samsung puts more or less features in a given size. So talking to someone with the same model size keeps the focus. There may be a 4k thread (havent needed to check) but for now, the majority of users in this thread have 2k 7500's.
VideoTech is offline
Old 06-26-2014, 11:15 AM
Sam Dav's Avatar
About my Samsung UE55HU7500 4K UHD. I did update the firmware via Ethernet to the latest.
I thought it could be my old HDMI cable and bought the most expensive Monster HDMI cable possible.
Still the same problem. It's not the cable.
To be exact, my hardware is xtreamer ultra. http://www.xtreamer.net/ultra/
Do you think its my hardware? It worked well with my old Plasma TV.
Do you think there is a compatibility issue with new 4K TVs and older
hardware? As I said it worked well with my old TV.
Do you think if I get this new media player, I will not have the blinking problem?
MINIX NEO X8-H
http://www.minix.com.hk/Products/MINIX-NEO-X8-H.html
Sam Dav is offline
Old 06-26-2014, 03:41 PM
CHuntMD's Avatar
Return that Monster cable POS.
Monoprice is all you need to remember. They even sell on Amazon now.
http://www.amazon.com/Monoprice-24AW.../dp/B001UN7FKO
This one is rated for 2K, 4K and 3D(all).
You also need to remember your an early adapter All the source devices are have to play catch-up to the Display devices in the new 4K world.
CEH
Just picked up a Synology 214Play NAS, blows away my old Netgear Stora NAS!
CHuntMD is offline
Old 07-02-2014, 07:59 PM
Liked: 0
My samsung un55f7450 tv won't turn on
Hi I am new to the thread. I bought this tv about two months ago all went well. Tonight when I come home the tv won't turn on. I replaced remote batteries also check manual to turn on the tv on button on the lower right at the back. Also take out plug and try other wall socket won't turn on. It appears the lower bottom right sensor is not on.
I know there is a big thunderstorm in our area tonight? Is this possible damage my tv?
Anyone has any idea?
glin930 is offline
Old 07-12-2014, 08:14 AM
alcast082's Avatar
Try pressing the standby button on the right side of the remote and then pressing power.
Different note, I saw some experienced some clouding and light bleed with their sets. Mine has very little light bleed but I do see clouding in some scenarios it looks like too much brightness and a lack of contrast. Also how is anyone's experience with viewing angles, mine is quite poor. Sitting 7 to 9 feet away and 2 feet off center of one can notice slight different in picture(brightness, colors...) anyone else experience this or did I get a defective set? Un55f7500 thanks in advance for your comments
alcast082 is offline
Old 07-13-2014, 11:24 AM
Liked: 0
Originally Posted by Halpers View Post
Does anyone have a weird "auto dimming" issue with this TV? I have the un46f7500 model. It happens on all sources but is very noticeable during video games. Its difficult to describe but basically if I look at a bright source or pan the camera up in to the sky the brightness goes way down, like some weird eco dimming feature. I made sure all eco and dimming settings are off and tested it with various settings on dynamic standard and movie presets and even tried game mode but it kept happening. I read something about turning off "dimming" in service menu and while I was able to access the service menu I couldn't really see any dimming options and didn't feel comfortable digging around in it too much. Any help is appreciated because its driving me nuts.
Hi halper. I'm from Argentina and I recently bought a UN46F7500. I wonder if you could guide me how to access to service menu.
The remote control is with pad without numbers.
Thanks in advance.
Esteban
eiriart is offline
Old 09-24-2014, 07:57 AM
mustafa811's Avatar
Exclamation motion artifacts
i bought this tv a month ago and didn't notice anything .. 1 week ago after updating software i started to notice some strange looking artifacts in flashing areas with motion plus on .. i owned 4 sets of samsung led TVs before and that artifact was a 1st me .. it seems to me it is a malfunctioning motion plus tv unit ( motion plus usually introduces artifacts but around moving objects and not like this )
it happened to me before and i stumbled in 46H7000 with a malfunction in the motion plus option and i returned it
so anyone here care to share opinions with me whether they see this an acceptable occuring artifact or it is a malfunction
it is very apparent in black areas that light flashes upon .. anyway anyone happen to own World War Z movie bluray .. he will find the recorded scene below at 24:10
i recorded two scenes one with motion plus ON which trigger artifacts .. and one without motion plus with no artifacts
motion plus on
motion plus off
mustafa811 is offline
Old 11-24-2014, 12:17 AM
mc91nyc's Avatar
Do they still make this model at 60 inches? Looking to buy a 60 inches one this coming weekend
And did they continue this model for 2014 and beyond?
mc91nyc is offline
Old 12-27-2014, 08:07 AM
Jim Jardashian's Avatar
What's the best picture calibration settings for the 60" model?
Jim Jardashian is offline
Old 03-18-2015, 10:34 AM
CHuntMD's Avatar
Anyone still reading this forum? My 60" has been working great but in the last week I've noticed where the TV turns off after a few hours. I checked to confirm the power saving / no activity was turned off. There is also a new firmware update that I installed but it happen again last night. Hope this is not a sign of the infamous capacitor issues of the older Samsung's.
CHuntMD is offline
Old 10-21-2015, 09:53 AM
juajar's Avatar
Hi Everyone, I have been searching everywhere but cant find what wireless standard the UN60F7500 supports, is it just N or wireless AC also? Anyone using it with AC>
juajar is offline
Old 10-22-2015, 06:58 PM
CHuntMD's Avatar
I have mine hardwirded along with the NAS, AV Receiver, DVD, Media Streamer. Wireless is more for portable devices IMHO.
CHuntMD is offline
Samsung Un55f7500 55 Inch 3d Ultra Slim Smart Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv , Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
