General Samsung LED Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-16-2013, 04:55 AM - Thread Starter
WSZsr's Avatar
I have a new UN65ES6500 Samsung and every time I change channels, an oversize box giving video resolution and HDMI info appears onscreen. Is there a way to turn that off?
Onkyo TX-NR809
Polk Audio RTI A3 Bookshelf Speakers
Polk Audio RTI A1 Bookshelf Speakers
Boston Acoustic VR10 Center
Energy ESW-310 Subwoofer
WSZsr is offline
post #2 of 3 Old 04-16-2013, 06:08 PM
Ironman's Avatar
Would suggest surfing using the remote "MENU" button. I think you will find a display option info button/selection that will give the desired result. Have not checked out your specific TV model but if similar to others.......
BTW, there is/was a "Info" remote button that will also temporarily &/or (on with push & off with second push) display the mentioned on screen info. Might try it also.
Ironman is offline
post #3 of 3 Old 04-17-2013, 09:09 AM - Thread Starter
WSZsr's Avatar
That is the first thing I did (many times) but can not find a setting that eliminates it. If you have a more specific suggestion, I will give it a try.
Onkyo TX-NR809
WSZsr is offline
Reply LCD Flat Panel Displays
