LG 55LM4600 black border issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-17-2013, 02:48 PM - Thread Starter
ganeshch's Avatar
Hi,
I recently bought a LG 55LM4600 from Costco which I think is having black border issue. I have attached the picture after the calibration of the TV using HCFR colorimeter. 3D and normal programming works just fine and I see that only when the screen turns black, that's when I have a movie shot in dark or when I switch my TV on I see that borders have the back light ON causing some white patches to appear. If I reduce the backlight the picture quality is taking a hit. So I'm here to check if this is normal with this model or if there's any resolution for this. I am also keying in the color settings for the TV
brightness : 53
contrast: 75
backlight 85
Blue Contrast : - 7
Red Contrast : +6
blue brightness : -2
red brightness : +1
color : 48
Appreciate your help on getting this issue resolved!
Ganesh
ganeshch is offline
post #2 of 5 Old 04-18-2013, 08:27 AM
rajmarie's Avatar
Quoted: 25 Post(s)
Liked: 26
These things happens to all LCD some more then others. I have the same model...& when new I was seeing it more...but now after using it for sometime...I see that those flashes have reduced/eliminated.
Keep using your set for sometime...since you bought from Costco..you have 90 days to return if you are not happy. So use it..& see if those goes down.
rajmarie is offline
post #3 of 5 Old 06-12-2013, 08:20 AM
lexx0079's Avatar
Hello, I also see the same on my 47". Other than that I would say its a good TV but those corner patches can get annoying. Would you guys agree that this would be one if not the cheapest led 3d tv out?
lexx0079 is offline
post #4 of 5 Old 06-12-2013, 08:30 AM
SMO5007's Avatar
Quoted: 17 Post(s)
Originally Posted by ganeshch View Post
Hi,
brightness : 53
contrast: 75
backlight 85
Blue Contrast : - 7
Red Contrast : +6
red brightness : +1
color : 48
Ganesh
Try turning your backlight/brightness down..
I usually keep mine on about half.
SMO5007 is offline
post #5 of 5 Old 06-12-2013, 09:22 AM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
That first picture looks terrible. It is normal to get some lighting problems but that I would consider unacceptable. No way I would keep a new TV that looked like that, and I didn't. I went through the whole LG line up to the 7600. It did get better as you went up but some even got worse.
eric3316 is offline
Reply LCD Flat Panel Displays
