Installing a wall mount on a Vizio E601i-A3 TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-17-2013, 06:08 PM - Thread Starter
srobin1040's Avatar
I am trying to put brackets for a wall mount on the back of my Vizio TV, and I am afraid to take the 4 screws out of the back of the TV that are already there, as I really know what those 4 screws are there for, and can't find a picture or diagram anywhere that actually shows where they go. Can anyone help me?
srobin1040 is offline
post #2 of 2 Old 04-17-2013, 06:28 PM
overtkill's Avatar
Those are for attaching the bracket to the TV. You can either use them, or longer ones if needed for your specific bracket, as long as they do NOT screw in too far to damage the TV panel. For my Monoprice mount, I used the screws that were included with the TV.
overtkill is offline
Reply LCD Flat Panel Displays
Vizio E601i A3 60 Inch Led Lcd Hdtv
