Open Box/Display Sony XBR-65HX950: Should I buy? PLEASE HELP! - AVS Forum | Home Theater Discussions And Reviews
Old 04-26-2013, 12:45 PM - Thread Starter
lothian110's Avatar
I started looking at this tv a couple of months ago, but decided the price point was too high. Now that they've come down in price it seems like every Best Buy is out of stock.
I did find one for 10% off the most recent BB price, but it is a display unit. They are asking $3150. It is in the store mounted in the magnolia center.
Would you guys consider this unit at that price point? I have to move quickly and I wasn't sure if I should be concerned about the display set.
I also found another one that is open box with a dead pixel. It is priced at $3k. I was told I could buy it with the protection plan and the plan would cover that dead pixel. If they can't fix it I would get an equivalent or better TV. Is this true? Since they aren't carrying this unit anymore, what do you think I would get? Is it worth the risk?
What do you think? Should I go for either one, or skip it all together?
Of course both come with BB's very generous (sarcasm) 15 day return policy.
Please help, thanks!
lothian110 is offline
Old 04-26-2013, 12:52 PM
malcolmp6's Avatar
Quoted: 76 Post(s)
Take a look at the W900a coming up soon. According to Sony reps this TV will be better than the HX950.
malcolmp6 is offline
Old 04-26-2013, 01:00 PM - Thread Starter
lothian110's Avatar
I want something 65"+. It is my understanding that the w900a doesn't come in anything bigger than a 55".
Old 04-26-2013, 01:31 PM - Thread Starter
lothian110's Avatar
Just spoke to a sony service rep. They said they would normally exchange or repair a tv for a dead pixel if the tv is under warranty.
Does anyone have experience with that?
I might go pick it up and see what they say while I have my 15 day return period. If I don't get the answers I want, I can always bring it back.
Any thoughts?
Sorry for the urgency, I just feel like I have to move on this if I want it.
Old 04-26-2013, 08:55 PM
digmor crusher's Avatar
From what I understand most if not all manufacturers would not replace a set with just 1 dead pixel.
digmor crusher is offline
Sony Xbr 65hx950 65 Inch Bravia Led Hdtv
