Are there any TV's (LCD or Plasma) that natively accept a 120hz input refresh rate? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-30-2013, 02:30 PM - Thread Starter
DreamAgain2's Avatar
Quoted: 49 Post(s)
Hey guys I'm looking for a 60-70 inch TV for my PC gaming room. Gaming at 120hz vs 60hz is quite a bit of difference in my opinion, I'm having trouble finding which TV's (if any at all) accept 120hz input?
Thx!
DreamAgain2 is offline
post #2 of 12 Old 04-30-2013, 02:40 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Your question should be.... what devices natively provide 120Hz output?
Probably none AFAIK (except perhaps a PC)
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 12 Old 04-30-2013, 02:48 PM - Thread Starter
Quoted: 49 Post(s)
What do you mean by this? I game on a 120 hz monitor.. it works like you would think it works.. Doesn't make you cap gaming at 60 FPS to prevent screen tearing.. once you switch from a 60hz monitor to a 120hz monitor you'll never want to go back.. as far as gaming goes.
post #4 of 12 Old 04-30-2013, 02:52 PM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
No device I know of outputs 120hz. 24, 30, 60 in US. 25/50 for Pal. Frame repetition/Interpolation is done by the TV.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #5 of 12 Old 04-30-2013, 02:55 PM - Thread Starter
Quoted: 49 Post(s)
S~
That cheapo 50" 4k TV apparently will output at 100+hz when ran at 1080p.
http://box.houkouonchi.jp/dp_hdmi/IMG_0627-small.JPG
Not really sure if I want it though.
post #6 of 12 Old 04-30-2013, 03:35 PM
Ratman's Avatar
Liked: 1191
What do you think it means?
60/120 Hz refresh rate has nothing to with FPS (24/30/60) per se. There's more to the equation.
Get a TV that has 120 or 240 Hz refresh and you may be happy.
EDIT:
I'll ask again.... what device that YOU know outputs 120Hz natively?
Ratman is offline
post #7 of 12 Old 04-30-2013, 03:43 PM - Thread Starter
Quoted: 49 Post(s)
Get a TV that has 120 or 240 Hz refesh and you may be happy.
Bro most TV's that advertise a 120 or 240hz refresh rate don't accept an input higher than 60hz. They advertise this because of frame interpolation and what not.
I've had multiple TV's that claim to be 120, 240, or 600hz (plasma) that only accept a 60hz input.
I THINK the reasoning behind this is that blu-ray only goes up to 48hz or so? So no reason to have higher than 60hz input. I understand why most TV's don't accept anything higher than 60hz input I'm just asking IF there are any that you guys know of that do.
Even on TV's that claim to be 120 or 240hz when you play games at higher than 60 fps there's still excessive screen tearing going on.
post #8 of 12 Old 04-30-2013, 04:11 PM
vilfrard's Avatar
Thats in Linux, it does 1080p at 120hz in Windows. A 65" version is coming in June and a 39" later in the year.
vilfrard is offline
post #9 of 12 Old 04-30-2013, 04:14 PM - Thread Starter
Quoted: 49 Post(s)
120hz in Windows sounds amazing! $1,200 is pretty cheap too. Any idea how much the 65 inch version will run?
post #10 of 12 Old 04-30-2013, 04:35 PM - Thread Starter
Quoted: 49 Post(s)
EDIT:
I'm not sure why you keep asking this.. I already told you I'm looking for a TV for my PC gaming room. A GTX 680 which I have can output 120hz natively, I believe it can even go up to 240hz. Higher resolutions like 2560x1600 i believe are capped out at 60hz but im not sure about that.
post #11 of 12 Old 04-30-2013, 08:30 PM
Mark Rejhon's Avatar
Quoted: 14 Post(s)
Liked: 109
Thx!
Yes. The new Seiki 4K HDTV supports 1920x1080@120Hz, and 1280x720@192Hz.
Also see: HDTV Refresh Rate Overclocking HOWTO: 120 Hz from a PC to a HDTV
Success reports include the Vizio e3d420vx and the Panasonic VT50 plasma.
I've been gaming at 120fps@120Hz for the last few months, from a Geforce GTX680 outputting to my brand-new 120Hz computer monitor, Asus VG248QE, which includes an excellent stroboscopic backlight mode that makes it look like a CRT. It outperforms scanning backlights (google 'lightboost', and see see testimonials and media coverage).
Mark Rejhon
www.BlurBusters.com - Everything Better Than 60Hz(tm)
Mark Rejhon is offline
post #12 of 12 Old 05-01-2013, 03:58 AM
Ratman's Avatar
Liked: 1191
Because you never mentioned you were using a PC exclusively. I did make that notation in post #2. wink.gif
Good luck with your quest.
Ratman is offline
Reply LCD Flat Panel Displays
