Official Samsung UNXXF7100 Owners Thread - Page 174 - AVS Forum | Home Theater Discussions And Reviews
 127Likes
post #5191 of 5845 Old 07-07-2014, 04:06 PM
Polishdebin's Avatar
Hey all.
For some reason my previous post didnt go through so if it does pop up I apoligize for the double post.
A little backstory:
In January (2014) I finally upgraded from a 2007 Sharp Aqous to a Pn60f5500 Plasma. I initially enjoyed it but ultimately returned it due to trailing and such when playing games.
My 2nd buy was a Toshiba 58L7300. Big mistake. Clouding, terrible motion and bad blacks.
Ive read about 2300 posts into this thread (So up until August 2013) but i just cant bring myself to read ALL of it.
So my question is, have most if not all the initial issues with this tv been fixed? Clouding, the dimming issue, the power cycling? I really would like to get a 55" of this tv. Apparently its great for gaming. Im on the fence between this and a Sony 55w900a. Input and PQ are both important to me (Ps3,Ps4 and blu-rays)
Im sorry for such a long post. Id really like to be well informed before dropping 1500-2000 on a new panel.
Thank you in advance to anyone who replies and helps me with my decision.
Polishdebin is offline
post #5192 of 5845 Old 07-08-2014, 07:11 AM
matrix123's Avatar
Quoted: 306 Post(s)
Liked: 132
Originally Posted by Polishdebin View Post
Hey all.
A little backstory:
I have the 55 inch and it is great for gaming. Power cycling is gone. Dimming has improved. I don't really notice it while gaming. Doesn't bother me on game mode. Clouding depends on luck. It's a gamble as always with edge lit displays. I get zero clouding with a bias light behind tv and back light set to 4 or 6.
matrix123 is offline
post #5193 of 5845 Old 07-08-2014, 11:47 AM
Liked: 4
Does anyone know if I can I get true 5.1 out of my UN557100 optical digital out?
Of note, I connecting to my AV1 input on my new 2014 Yamaha RX-V677.
Thanks in advance.
Shimmy Bang Bang is offline
post #5194 of 5845 Old 07-08-2014, 07:58 PM
theroys88's Avatar
Quoted: 194 Post(s)
Liked: 79
5.1 from OTA and apps that support DD. Everything else converted to PCM.
theroys88 is offline
post #5195 of 5845 Old 07-09-2014, 05:40 AM
Liked: 4
Would this make a siffer
post #5196 of 5845 Old 07-09-2014, 06:22 AM
Thanks for taking the time to reply. Yeah the panel "lottery" posts have me slightly weary of getting a 7100. But on the other side of things I havent read into the w900 and im sure it has just as many uniformity issues/clouding issues as this tv.
post #5197 of 5845 Old 07-09-2014, 06:32 AM
theroys88's Avatar
Quoted: 194 Post(s)
Liked: 79
What is a Siffer?
post #5198 of 5845 Old 07-09-2014, 06:52 AM
matrix123's Avatar
Quoted: 306 Post(s)
Liked: 132
Yes they prob will. I just looked into ways to Diminish the clouding. Highly recommend a bias light. Can never go back now. Love the look. Also I had the 60 (3 of them) in which I took back cause of terrible clouding. Read that the 60 in is made by sharp and 55 made by Samsung. The 55 looked miles better with only minimal clouding. Also the build quality was better than a 60. Highly recommend the 55 in.
post #5199 of 5845 Old 07-09-2014, 07:05 AM
Im glad you brought that up because I wad wondering if that had ever been confirmed? I had wanted a 60" but due to this Im getting the 55". Are all 55" gaurenteed to have a Sammy panel? From what ive read Im going to assume so.
post #5200 of 5845 Old 07-09-2014, 07:09 AM
matrix123's Avatar
Quoted: 306 Post(s)
Liked: 132
I believe so. Either way you look at it the 55 is a better choice. And I can say that cause I've owned both. Also with latest updates there are zero issues to report. And if gaming is your thing, this tv will impress. Just remember to use game mode. Another tip is to use Piratecoves setting. They are the best. Cheers.
post #5201 of 5845 Old 07-09-2014, 05:11 PM
slow ride's Avatar
Quoted: 27 Post(s)
I have a 60" with no clouding issues .
slow ride is offline
post #5202 of 5845 Old 07-09-2014, 06:07 PM
Liked: 4
What is a Siffer?
That was my bad. I didn't mean to post that typo, I bumped send on my cell phone and didn't realize that it sent.
What I meant to say, does using 'optical digital out from TV to receiver' have any disadvantages when compared to using 'cable box HDMI to receiver along with HDMI video out to TV'?
post #5203 of 5845 Old 07-09-2014, 07:32 PM
theroys88's Avatar
Quoted: 194 Post(s)
Liked: 79
If you want DD or DTS 5.1 you will have to go from your components to your receiver. I believe only Sony and Vizio sets pass DD.
post #5204 of 5845 Old 07-11-2014, 11:27 AM
SiGGy's Avatar
Quoted: 381 Post(s)
Liked: 332
Power cycling still seems to happen. But it's always turning *on* without notice (including turning my receiver on); then it will shutoff a few minutes later.
Clouding was easily fixed just wiping the screen gently with a high quality plush microfiber cloth. You have to kinda massage it out. Unless you move the TV and stress the panel I don't see it coming back. It's been many months since I did mine... There's even a thread about wiping/massaging somewhere.
Never had any dimming issues in movie mode.
I have a 65" AUO panel, AH01. (discussed in detail in the Samsung panel thread) almost all of the 65" F7100's are AUO panels.
(values measured myself in movie mode, all processing turned off)
.008fl MLL (black)
39fl (white).
5,000:1 contrast; static (very good for edge lit LCD)
Motion is good, only real issue I have seen with this TV is off axis viewing. Its about 30 degrees total. So 15 to the left or right of center. A higher flat gamma will improve side viewing. But I would recommend a BT.1886 gamma on this TV to help with shadow detail...
-SiGGy
SiGGy is offline
post #5205 of 5845 Old 07-16-2014, 07:02 AM
Liked: 0
I was wondering for the people using the same source for gaming and watching movies (ps4 or xbox one), what are you guys doing for the picture settings.
I switched the name of the source of my ps4 to PC (to achieve a better input lag) and by doing that I cannot switch the Picture Mode from "Standard" to "Movie".
What are you gamers doing?
spdecoste is offline
post #5206 of 5845 Old 07-16-2014, 11:08 AM
macmane's Avatar
Quoted: 882 Post(s)
Liked: 541
I game on the ps4 and I use standard picture mode
macmane is online now
post #5207 of 5845 Old 07-16-2014, 01:29 PM
rurifan's Avatar
Input lag is identical between PC Mode and Game Mode. I have measured with the Bodnar device many times.
PC Mode displays RGB without converting to YUV422 for processing, but has less color control options and much lower saturation (I think it's undersaturated for gaming). PC Mode also has CE Dimming disabled like Movie Mode.
I recommend that you use Game Mode / Standard and (mostly) defeat CE Dimming by setting Brightness to 53 and White Balance R/G/B-Offset to 21.
rurifan is offline
post #5208 of 5845 Old 07-16-2014, 05:07 PM
Liked: 0
alright thanks for the tip, if I want to go back to my Movie settings, can I just turn off Game Mode and switch from "standard" to "Movie" to watch a Blu-Ray on my ps4? or I will lose my "standard" settings?
post #5209 of 5845 Old 07-18-2014, 06:50 PM
mrkyymrk's Avatar
Originally Posted by slow ride View Post
I have a 60" with no clouding issues .������
Same I have the 60 with very minimal clouding and amazing motion.. My roommate has the 55 and there's no difference! It's the freaking same tv after you calibrate it.. It's all nerd talk
mrkyymrk is offline
post #5210 of 5845 Old 07-18-2014, 08:09 PM
macmane's Avatar
Quoted: 882 Post(s)
Liked: 541
what settings do u use I have the 60 inch as well
post #5211 of 5845 Old 07-20-2014, 03:46 AM
Liked: 0
Freezing Issues
Hi all,
I've owned a 65" f7100 for about 6 months now. It is hanging in my media room and has little mileage on it. I am having an issue streaming with the Apps (Amazon VOD and Netflix are the only ones I use). After about 30 minutes of streaming, the both apps lag badly. It takes about 30 sec to 1 minute for the app to respond to the remote (video still playing fine). After about an hour, the video/audio starts freezing and gets progressively worse. At this point, the TV/app is unresponsive. I can see the red LED flash in response to the remote, but the app does not respond. I cannot even turn the TV off. If I select the smart hub button on the remote, the screen goes black and after 1 minute, and it may go back to the menu (if I'm lucky). As soon as I can cycle the TV off, back on, and reopen the App, the problem is fixed. I have to go through this nonsense every hour or so when I stream a movie. It is not a buffering issue.
To answer a few basic questions:
This issue just started a couple of weeks ago. I could stream perfectly fine without issue since I bought the TV.
I updated to the latest firmware (didn't help).
I updated Netflix and Amazon VOD to the latest software (didn't help).
I can stream from computers, phones, and game systems just fine throughout the house.
I am running an Ethernet cord directly to the TV.
Playing movies through an external player works perfectly fine (TV is responsive to remote throughout viewing).
Before spending 5 hours on the phone with Samsung and getting the run-around, I'm hoping someone on this board has some advice. I would greatly appreciate it.
mspHtown is offline
post #5212 of 5845 Old 07-20-2014, 08:29 AM
tedcousens's Avatar
Quoted: 28 Post(s)
Is the Marantz server down this AM? For the first time, I am unable to stream music from Internet Radio - says the server is disconnected. I am certain I haven't made any adjustments or changes to the unit. I can stream locally using the media server but can't connect online...
I've seen things you people wouldn't believe...
Roi Batty
tedcousens is offline
post #5213 of 5845 Old 07-23-2014, 09:23 PM
votnet's Avatar
Liked: 0
I have exactly the same problem and it started to occur recently, about several weeks ago. I also have 65" f7100 and all the latest firmware/apps. Very annoying.
Originally Posted by mspHtown View Post
Hi all,
votnet is offline
post #5214 of 5845 Old 07-25-2014, 07:05 AM - Thread Starter
PiratesCove's Avatar
Quoted: 82 Post(s)
Liked: 176
I finally used the Screen Mirroring with my Samsung Galaxy smart phone.
Its a nice feature, but I get better quality from the Smart Hub or via. Xbox360.
PiratesCove is offline
post #5215 of 5845 Old 07-25-2014, 06:22 PM
mgh26's Avatar
Quoted: 48 Post(s)
Liked: 91
Originally Posted by low_ball_88 View Post
Anyone know good/bad for the latest firmware 1200? Please advice....Thanks.
Version 1200 has been out for quite some time now. The general posts have all been really positive. I personally believe it has been the best overall version released yet for this model TV with Excellent picture quality & good motion. I got my F7100 early on & have seen each released Firmware update along the way.
mgh26 is offline
post #5216 of 5845 Old 07-27-2014, 03:13 PM
Hey all.
I just wanted to take the time to thank everyone whos posted settings, given advice or anything else in this thread. I literally read the ENTIRE thread before making my purchase of a 55" f7100. You were all instrumental in my decision.
I used PirateCoves settings with a few personal adjustments and im extremely impressed with the picture of this TV.
I think I did luck out a bit mind you. I have almost 0 clouding or uniformity issues. Just a slight bit in each corner but i have to crank my backlight up to 17+ to even notice it. My panel is a UD02 and was manufactured in 2014.
Blu-rays are outstanding a gaming on ps3/ps4 is also unreal. Using the quick work-around of raising the brightness to 53 to eliminate the CE Dimming in Standard mode (for gaming) and it really isnt that bad.
Anyways just wanted to say thank you to you all. SO happy i found this site and this thread. Cheers!
post #5217 of 5845 Old 07-27-2014, 04:27 PM
RKSKYDANCER's Avatar
Quoted: 113 Post(s)
Liked: 84
Glad you mention settings. Can someone steer me to PirateCoves settings or other good settings for the UN55F7100?
What are you guys using for the Motion and Judder settings. Seams I get some middle of the screen Judder at times when watching Blu-Ray movies like War or the Worlds or Oblivion. I used my Disney WOW disc for picture calibration which helped with the overall picture but the Judder or motion I see are another issue. Has anyone been able to get rid of this?
Living room; Samsung PN60F5300B Plasma TV, Marantz SR5008 AVR, Sony UHP-H1 UHD Blu-ray, Definitive Mytho 2's fronts-wall mounted, Definitive Pro Center 1000 speaker, Definitive Di 5.5R in ceiling for surrounds, RSL speedwoofer 10s , Comcast Xfinity HD DVR box.
Garage; Sherwood RX-4105 2 channel stereo receiver, Samsung DVD-C500 CD player, Klipsch KG 2.5 med Oak speakers
RKSKYDANCER is offline
post #5218 of 5845 Old 07-28-2014, 05:23 AM
slow ride's Avatar
Quoted: 27 Post(s)
I agree with this post
post #5219 of 5845 Old 07-28-2014, 12:04 PM - Thread Starter
Quoted: 82 Post(s)
Liked: 176
Link to Settings:
post #5220 of 5845 Old 07-29-2014, 07:54 AM
1080eyes's Avatar
The 7 months that I have owned my 60", it has gotten better with age.
The "white shadowing" (not sure if its the correct term) has improved, to a point where its not noticeable.
1080eyes is offline
Reply LCD Flat Panel Displays
Samsung Un60f7100 60 Inch 3d Ultra Slim Smart Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv
