Official Samsung UNXXF7100 Owners Thread - Page 176 - AVS Forum
post #5251 of 5268 Old 09-27-2014, 09:05 PM
mgh26's Avatar
Liked: 52
Originally Posted by tyro13 View Post
Thanks for the response. I honestly don't feel the need of upgrade as I have been satisfied and enjoying my TV. Only issue I recently noticed is the bottom information bar does not disappear automatically as it used to do in a sec of so after the channel was changed, so logged on to forum to enquire about it and noticed that couple of firmware versions have been released since last December.
Quick question - If factor reset is done after loading new firmware, will it override the custom picture settings?
A Factory Reset erases all settings except the network that was previously set up.. SO... YES the Custom picture settings will be gone. Write them down before the reset.
tyro13 likes this.
mgh26 is offline
post #5252 of 5268 Old 10-04-2014, 08:51 AM
slow ride's Avatar
Just to be clear, a firmware update does not include a factory reset as well, right ?
I Assume factory reset is done separately
slow ride is offline
post #5253 of 5268 Old 10-04-2014, 10:00 AM
electronics craz's Avatar
do you have to do a factory reset after firmware upgrade to take effect?
electronics craz is offline
post #5254 of 5268 Old 10-04-2014, 12:21 PM
mgh26's Avatar
Liked: 52
Right. A Factory Reset does Not happen automatically during a Firmware update and it is done separately. Also... It is not required after the firmware update for the changes to take effect. The TV powers down & then back on with the installed changes taking affect after the update. In some instances in the past, after a Firmware update, it has been is necessary to do a factory Reset if any normal TV functions appear to be out of wack. In some of the earlier Firmware releases there were post update glitches that corrected themselves by doing the Reset. I haven't seen this come up in several releases now though so it really shouldn't be needed.
mgh26 is offline
post #5255 of 5268 Old 10-09-2014, 06:51 AM
s1njin's Avatar
Quoted: 39 Post(s)
Liked: 26
Originally Posted by PiratesCove View Post
Firmware version 2203.1 looks good, with a little sharper picture quality.
Motion is still excellent with A.M.P. on.
I've always had a jerky motion with AMP, even with your settings. I'm wondering if it's because of my connections:
STB HDMI --> Denon AVR-595 --> HDMI OUT to Samsung 7100
I'm wondering if my older Denon is adding something to the mix w/ regards to the picture processing. I'm going to to get myself a optical/digital cable and try going STB HDMI --> Samsung 7100 --> Optical Out to Denon AVR-595.
This will at least take the receiver out of the mix for the image processing.
Think its worth the effort?
s1njin is offline
post #5256 of 5268 Old 10-09-2014, 06:23 PM
mgh26's Avatar
Liked: 52
Has anybody else noticed some of the Samsung applications (without notice), has uninstalled some previously downloadable Free Aps? My Redbox Application Icon just disappeared a few days ago and is no longer avalible for download either Other Apps gone as well?
mgh26 is offline
post #5257 of 5268 Old 10-09-2014, 06:49 PM
s1njin's Avatar
Quoted: 39 Post(s)
Liked: 26
Okay so scratch the Digital Audio out from the TV. It doesn't pass 5.1 from the STB (or anything else besides OTA HD apparently).
I still get some studder when I put AMP on to Pirate's settings. Its bugging the crap out of me b/c nobody else is complaining about it.
s1njin is offline
post #5258 of 5268 Old 10-11-2014, 05:17 AM - Thread Starter
PiratesCove's Avatar
Quoted: 12 Post(s)
Liked: 119
I get very mild stuttering via. DirecTV (1080i) with a panning shot filled with motion, or perhaps a sports or news channel with a scrolling ticker (moving words at the bottom) with AMP on- due to the TV processing more lines of resolution.
Previous firmware versions had frame rate drops and more pronounced stuttering.
I have never had any frame rate drops or stuttering from a 1080p source (Blu-ray, Video games or Smart Apps) with AMP on.
s1njin likes this.
PiratesCove is online now
post #5259 of 5268 Old 10-11-2014, 05:21 AM
s1njin's Avatar
Quoted: 39 Post(s)
Liked: 26
Ok, this is what it I'm seeing as well. You also answered another question I had - moving to D* isn't goin to fix it either. I make THAT switch this coming Saturday.
s1njin is offline
post #5260 of 5268 Old 10-13-2014, 05:29 AM
s1njin's Avatar
Quoted: 39 Post(s)
Liked: 26
I've upgraded the firmware on my TV maybe, 4 times now? I never did a factory reset - so I did one this morning and re-did my settings to PC's recommendations. I'm wondering how the AMP may work now that I performed the reset.
I had time this AM, so I figured what the heck?
s1njin is offline
post #5261 of 5268 Old 10-13-2014, 05:09 PM
delevin1's Avatar
Liked: 0
Problems with Program Guide (accessed by clicking the lower right button on the remote)
I use my UN60F7050 with OTA tv signals (via an antenna on my roof) I don't have cable or satellite service), connected to the internet via Wifi with a new Netgear AC1900 router, and 3-4 bars of signal. (Other devices get 5 bars in the same location, but I'll save my complaints about the terrible wifi on this tv for another post). We have Time Warner 20MB/second high speed internet service.
When clicking on the guide button while watching an OTA show, I initially see the program listings for 7 channels, with the show I was watching still playing in the upper left portion of the screen. Often, but not always, when I scroll down to see the next channel's listings, the guide hangs for 3-10 seconds (I assume this is to "load" the new content from the internet). The real problem is that the picture and sound of the show disappears and is replaced by a spinning icon while waiting for the info to load.
Needless to say, this drives us crazy. I've spoken to Samsung tech support many times and have been given the run around and promised that firmware updates would fix it. I've installed each new firmware, including the recent one, but nothing's resolved this.
Is there anyone else who uses the Guide for OTA channel listings? Have your experiences been similar?
Thanks in advance for your help.
delevin1 is offline
post #5262 of 5268 Old 10-14-2014, 12:25 PM
santie321's Avatar
Red face 2203 rocks
not sure specifically what samsung did but just installed the 2203 update last night and bam! best PQ i've seen on my set.
santie321 is offline
post #5263 of 5268 Old 10-17-2014, 04:53 AM
Liked: 0
On a UN60f7100af is anyone else having an issue where you set your sound to receiver or external? When you power it down it resets to TV speakers. This only occurs when CEC is turned on. I just got dish and have the hopper connected to my Pioneer VSX1123K and then to HDMI 1 on the TV. It works on the power off to turn TV off and Receiver off. Then When I turn the TV on it turns the receiver on. Then it resets the sound setting to TV speakers and then will not turn off the receiver again. Any Ideas? I was with Samsung support for a couple of hours and nothing worked.
klein103103 is offline
post #5264 of 5268 Old 10-20-2014, 06:57 PM
emileg's Avatar
Liked: 25
First of all, a warm welcome to AVS forum and congratulations on your first post. Unfortunately or fortunately, I have not encountered this problem. However, I have a somewhat similar problem. After a few seconds, the receiver switches from our DVR, which it found correctly, to the Smart Hub of the TV. This is a documented problem that neither the the receiver companies nor the TV companies care to fix. Sorry I can't help with your issue. But, thanks for asking. As this thread is winding down, as our TVs are now 1.5 years old or so, you might want to check on the 2014 Samsung thread for similar TVs or else the thread for your particular receiver. Good luck.
emileg is offline
post #5265 of 5268 Old 10-20-2014, 06:58 PM
emileg's Avatar
Liked: 25
No doubt the picture quality with 2203 is as good as before. However, my TV is still turning itself on and off when I am not watching it, in spite of what the update notes claim.
emileg is offline
post #5266 of 5268 Old 10-21-2014, 03:59 PM
danbo99's Avatar
Same for me. At least twice a day the TV turns itself on for about a minute and then back off.
danbo99 is offline
post #5267 of 5268 Old 10-22-2014, 05:55 AM
s1njin's Avatar
Quoted: 39 Post(s)
Liked: 26
Quoting myself - heh.
Just to round this topic out - I'm getting almost NO studdering w/ AMP on PC's settings now that I'm on D*.
Another reason I don't miss my cable TV now.
s1njin is offline
post #5268 of 5268 Old 10-23-2014, 03:57 AM
s1njin's Avatar
Quoted: 39 Post(s)
Liked: 26
On another note, my TV has mysteriously started changing inputs all on its own within a minute of powering up. Maybe within 30 seconds.
Happened right around the time I switched to DirecTV. And right around when I switched out the batteries of the remote. I've since pulled the remote batteries out to see if its something wonky with my remote control.
s1njin is offline
Reply LCD Flat Panel Displays
Samsung Un60f7100 60 Inch 3d Ultra Slim Smart Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv
