Official Samsung UNXXF7100 Owners Thread - Page 179 - AVS Forum
AVS Forum > Display Devices > LCD Flat Panel Displays > Official Samsung UNXXF7100 Owners Thread
Bon Trajano
08:04 AM Liked: 0
post #5341 of 5359
12-06-2014 | Posts: 2
Originally Posted by PiratesCove View Post
The new Smart Hub looks like this video for the 2014 Samsung Smart Hub.
There is no favorites tray on the updated F series Smart Hub.
^ Thanks for answering. But my smart hub still looks like the old one. Is it maybe because i updated using usb method?
spockersM
12:12 PM Liked: 0
post #5342 of 5359
12-06-2014 | Posts: 1
Hey There....recently upgraded from the original firmware that came with my (maybe 1202??) to 2203, and now 2204. Has anyone else experienced the same issue I have with the apps...specifically Amazon Prime Video App. It used to work very quickly, with very little lag with the original firmware. Now it freezes, jerks (the progress wheel spins slowly stops, spins slow , stops etc etc), and usually barely functions. Unfortunately there is no way to 'reload' the Amazon app. I've tried rebooting the TV a number of times, with no change. Any ideas?
mgh26's Avatar mgh26
06:11 PM Liked: 58
post #5343 of 5359
12-06-2014 | Posts: 406
Go into the Smart Features Menu and do a Smart Hub Reset. That will uninstall all of the applications and then re-installs them back One at a time. Any Applications you have downloaded will have to be downloaded again. All of the Pre-installed applications will automatically get re-installed. This also will require to re-program the Cable box (in my case) universal remote. The Web Browser will need to be tweeked for your prefrences as you had when you set the TV up the first time.
Hopefully after this your Applications will be OK again. This reset does not cause your Video settings to get erased. This has happened to me as well!
Shark Bait II's Avatar Shark Bait II
10:33 AM Liked: 10
post #5344 of 5359
12-08-2014 | Posts: 9
Does anyone know if the Microsoft Wireless Display Adapter (Miracast) will work with the F7100 running SW 2203?
coykiam's Avatar coykiam
10:15 AM Liked: 10
post #5345 of 5359
12-12-2014 | Posts: 4
Hi All,
So I updated my f7100 yesterday to the latest firmware. After updating I tried opening smart hub and it tells me it's not working. So I resetted smart hub via the "0000" password but still no luck. The network connection and internet test SEVERAL times was successful. I tried both wired and wireless connection with a successful internet connection. I did this for a couple hours but still no luck. I even tried changing the DNS to 8.8.8.8 but still no luck.
Any suggestions? Help please...Thanks in advance
scott81603's Avatar scott81603
05:51 PM Liked: 10
post #5346 of 5359
12-12-2014 | Posts: 5
Pirate,
What's your current calibration with the latest firmware?
PiratesCove's Avatar PiratesCove
07:27 AM Liked: 122
post #5347 of 5359
12-13-2014 | Posts: 4,080
Originally Posted by scott81603 View Post
Pirate,
Calibration Settings:
ygrene321's Avatar ygrene321
09:04 PM Liked: 11
post #5348 of 5359
12-15-2014 | Posts: 81
Hi folks!
I cant figure out how to connect a Bluetooth headphone to a UN60F7100. Is there a trick to this?
macmane's Avatar macmane
10:28 PM Liked: 26
post #5349 of 5359
12-15-2014 | Posts: 223
Originally Posted by coykiam View Post
Hi All,
I had the same issue and what worked me the channel on my router hope it helps
kohmei's Avatar kohmei
10:30 PM Liked: 18
post #5350 of 5359
12-15-2014 | Posts: 54
Originally Posted by ygrene321 View Post
Hi folks!
The F7100 is unfortunately doesn't support bluetooth audio devices, only Samsung's own "SoundShare" brand of wireless connectivity. I also don't recommend it because it introduces synchronization problems which unfortunately has no option to adjust.
10:16 PM Liked: 11
post #5351 of 5359
12-16-2014 | Posts: 81
Ok... I found this nifty device that connects to the headphone 3.5mm jack on the back of the TV. It transmits a signal to bluetooth head phones. So far thats the only workaround .
Avantree Saturn Pro Bluetooth Audio Adapter Transmitter and Receiver 2-In-1 with aptX Low Latency Codec, Titanium
http://smile.amazon.com/Avantree-Blu...rhf_dp_p_img_3
Joe Hu
10:41 AM Liked: 0
post #5352 of 5359
12-18-2014 | Posts: 1
Nice find. Does this thingy supports the iphone bluetooth? As to use the TV speakers as my iphone speaker?
11:45 AM Liked: 11
post #5353 of 5359
12-18-2014 | Posts: 81
Nope..you can try. I really don't think so because the 3.5mm plug is a headphone output only. So when plugged in the thingy will transmit a Bluetooth 3.0 signal to my creative labs wp-380 Bluetooth headphones.
I also have a tx-nr609 in another room that I can plug this device into..switch it into receive mode and send music from my phone. So the big plus for me is that I can use it in 2 different situations.
By the way.. I have found to avoid any latency issues with TV viewing look for the Bluetooth 3.0 version . The avantree saturn pro seems to be one of the very few out right now at a reasonable price that transmits/receives and BT3.0 .
If just listening to music Bluetooth 2.0 should be good enough although range may vary.
walkman666's Avatar walkman666
05:47 PM Liked: 12
post #5354 of 5359
12-21-2014 | Posts: 212
Sorry if this question has been asked and answered before. I tried a quick search within this thread. I have the Samsung UN55F7100, and today most of the apps have disappeared from the Smarthub. Is there an easy way to get them back, aside from a factory reset? Any suggestions or links would be greatly appreciated. Thanks!
05:58 PM Liked: 26
post #5355 of 5359
12-21-2014 | Posts: 223
Yea u can smart hub reset not factory reset and should restore everything
06:39 PM Liked: 12
post #5356 of 5359
Fabulous! Thanks macmane. I will try that once my daughter finishes her flick.
EDIT: Did it, worked. Much appreciated.
06:55 PM Liked: 26
post #5357 of 5359
No problem man let us knw how turned out. Several that since the latest update and we figured u would have reset the smart hub instead of a full factory reset
scotsman25's Avatar scotsman25
04:19 AM Liked: 10
post #5358 of 5359
Today | Posts: 3
Is there anywhere we can see a changelog for firmware updates?
I just updated my UA55F7100 to 2128, which is the newest available that it can find.
08:20 AM Liked: 26
post #5359 of 5359
Today | Posts: 223
Have u tried samsung support page? I wonder if we have a new firmware update for the un55f7100
Tags: Samsung Un60f7100 60 Inch 3d Ultra Slim Smart Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv
Reply LCD Flat Panel Displays
Subscribe to this Thread
Powered by vBadvanced CMPS v3.2.3
