Official Samsung UNXXF7100 Owners Thread - Page 184 - AVS Forum | Home Theater Discussions And Reviews
 127Likes
post #5491 of 5835 Old 04-15-2015, 12:55 PM
dynaguy's Avatar
Originally Posted by slow ride View Post
I know I'm in the wrong area but you guys will know the answer.
I'm thinking about putting my modem and router in separate rooms. I will need A 25' data cable to connect the two. Will I lose any performance with that long a distance ? Thanks
If you are talking about the network cable, then it will work fine, just make sure your cable is CAT5e or CAT6. I think the length limit is up to 100 feet.
dynaguy is offline
post #5492 of 5835 Old 04-16-2015, 03:06 PM
azz7686's Avatar
Quoted: 167 Post(s)
Liked: 59
Length limit is 300' minus any patch cords!
Spoiler!
azz7686 is offline
post #5493 of 5835 Old 04-19-2015, 05:41 PM
slow ride's Avatar
Quoted: 27 Post(s)
Thanks for that. Is anyone aware of a surge protector out there that Has a detachable power cord. I'm not sure if they even make one. Thanks
slow ride is offline
post #5494 of 5835 Old 04-25-2015, 09:33 AM
jcase's Avatar
Issue with new Samsung...
2 days ago from a local audio video store I picked up a display model of the Samsung UNF60F7100
The TV was purchased as is for $999 out the door including a tilt wall mount for it. I did not get the actual remote nor the stand. The remote does not include the button to bring up the smart apps.
The screen looked ok on the wall at the store. The following day I noticed spots in the picture as can be seen below.
You can see the spot in the ping area next to the right of the mans head in the first picture.
The 2nd picture has the spots above and to the right of the girls head.
Not sure what to do? Any advice would be greatly appreciated.
Has anybody seen this issue before?
I have a feeling the store will give me store credit but not return my money.
ID:	685225   Click image for larger version
John
jcase is offline
post #5495 of 5835 Old 04-26-2015, 08:39 AM
mrkyymrk's Avatar
It's DSE effect. Dirt screen effect. Most led TVs have this if you look for it. Yours is bad tho. You can turn up the brightness of the screen to minimize it but there is no fix. You will really only notice this on green/grey screens but just by your pics it's pretty bad. If you really look for it tho.. Most TVs will have some sort of DSE somewhere. But some far worse then others..,
mrkyymrk is offline
post #5496 of 5835 Old 04-26-2015, 02:30 PM
jcase's Avatar
Thank you, I returned the screen and got a 60" 7150!
Thanks again!
John
jcase is offline
post #5497 of 5835 Old 04-29-2015, 10:41 AM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
Can anyone suggest their custom auto motion plus settings that doesn't include LED CLEAR MOTION to ON ? for blu Ray only please. Led clear motion seems to flicker and I think it reduced the brightness of the picture. Thanks.
matrix123 is offline
post #5498 of 5835 Old 05-11-2015, 06:08 PM
jcase's Avatar
I'm having a problem on a new tv that I'm hoping somebody will be able to answer
I have the 60" 7150
I'm getting jitter on scene pans, where the video stutters across the pan instead of being smooth.
Has anybody seen this? If so do you know how to fix it.
John
jcase is offline
post #5499 of 5835 Old 05-11-2015, 07:35 PM
slow ride's Avatar
Quoted: 27 Post(s)
I have the 60" 7150
I have a 60" 7100 and I have to set my amp to smooth or else I have the same problems as you. The latest firmware update has helped as well . I also noticed that it's worse on Dvr recordings then it is on live tv.
post #5500 of 5835 Old 05-12-2015, 05:54 AM
jcase's Avatar
Thank you I'll check for new firmware.
Can you explain your comment about setting your "Amp to smooth"
All I watch is DVR recordings.
Thank you,
John
jcase is offline
post #5501 of 5835 Old 05-12-2015, 09:38 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 1975 Post(s)
Liked: 2140
Originally Posted by cfd272 View Post
Gonna keep pressing for a refund until my warranty expires I guess.
That right there is the best solution, normally they will swap. Every rep you talk to "will" have a different answer. So call every day and get a different rep. Persistence is key. Let us know the out come.
I personally see a new set in your future is you are persistent.
PiratesCove likes this.
Cleveland Plasma is offline
post #5502 of 5835 Old 05-12-2015, 07:05 PM
slow ride's Avatar
Quoted: 27 Post(s)
Thank you,
Go to settings. Then picture options. Then auto motion plus. Try the " smooth " setting . This should help with the blurr etc when the camera pans . It did for me.
post #5503 of 5835 Old 05-13-2015, 09:53 AM
macmane's Avatar
Quoted: 748 Post(s)
Liked: 506
New update 2209 anyone updated to it yet?
macmane is online now
post #5504 of 5835 Old 05-14-2015, 08:24 AM
azz7686's Avatar
Quoted: 167 Post(s)
Liked: 59
Updating now did you see any differences?
Spoiler!
azz7686 is offline
post #5505 of 5835 Old 05-14-2015, 09:48 AM
macmane's Avatar
Quoted: 748 Post(s)
Liked: 506
to me I dont like the auto motion now something isn't right about it
post #5506 of 5835 Old 05-14-2015, 10:30 AM
macmane's Avatar
Quoted: 748 Post(s)
Liked: 506
I had to factory reset and now it seems the motion is like normal again for the most part
post #5507 of 5835 Old 05-14-2015, 03:21 PM - Thread Starter
PiratesCove's Avatar
Quoted: 82 Post(s)
Liked: 176
I updated to fw. ver. 2209, Colors still pop and Contrast is excellent.
The motion does have more judder with AMP, but I like judder.
PiratesCove is offline
post #5508 of 5835 Old 05-14-2015, 03:56 PM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
Thanks for the heads up. Updating now.
post #5509 of 5835 Old 05-14-2015, 09:38 PM
macmane's Avatar
Quoted: 748 Post(s)
Liked: 506
Anyone care to share their auto motion plus settings since the latest update? Also do guys use it with film mode on auto 1 or 2?
post #5510 of 5835 Old 05-15-2015, 07:21 AM
emileg's Avatar
Liked: 38
To Update or Not
Does anyone see any reason to update to 2209? Do you notice any improvement in any area over the previous version? Thanks.
emileg is offline
post #5511 of 5835 Old 05-15-2015, 07:32 AM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
I use CLEAR for my xfinity. CUSTOM Blur 10 judder 0 for blu Ray. CLEAR also works good for blu ray.
post #5512 of 5835 Old 05-15-2015, 08:04 AM
macmane's Avatar
Quoted: 748 Post(s)
Liked: 506
do you use film mode with it as well?
post #5513 of 5835 Old 05-15-2015, 08:12 AM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
I never use film mode. It's grayed out on all my sources. Full 1080p on blu Ray and xfinity. But my old box I used film mode 2
post #5514 of 5835 Old 05-15-2015, 08:32 AM
macmane's Avatar
Quoted: 748 Post(s)
Liked: 506
o ok thanks for that. I appreciate it I may turn it off to see any difference. I normally used auto 1 film mode in conjunction with clear auto motion
post #5515 of 5835 Old 05-15-2015, 08:40 AM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
Are you using CLEAR for blu Rays as well?
post #5516 of 5835 Old 05-15-2015, 08:54 AM
macmane's Avatar
Quoted: 748 Post(s)
Liked: 506
yes I use clear for blu rays also . Clear has always been the only setting I used since it gave a crisper picture and better motion imo
post #5517 of 5835 Old 05-15-2015, 09:06 AM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
Gonna try blu Rays with CLEAR tonight. Lately for some reason I think the LED clear motion setting to ON with BLUR 10 JUDDER 0 is making my eyes strain.
post #5518 of 5835 Old 05-15-2015, 09:48 AM
macmane's Avatar
Quoted: 748 Post(s)
Liked: 506
Im just not feeling this update to be honest. I want the previous one back. Is there a way to revert back to the previous one? I downloaded the new version thru the tv but I see on samsung website that the previous one is still showing and I can download that via my usb stick is that possible?
post #5519 of 5835 Old 05-15-2015, 10:05 AM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
I'm not sure. Only gripe I have with the update is that AMP has indeed changed. Picture, contrast, and color are all great. My custom AMP setting for blu Ray used to be fine for me but now it's very jittery. Panning isn't as smooth and easy to look at anymore. Hopefully I can just leave everything on CLEAR and that be useable.
post #5520 of 5835 Old 05-15-2015, 10:21 AM
macmane's Avatar
Quoted: 748 Post(s)
Liked: 506
yea thats my maine gripe the motion and movements is all messed up to me. Color contrast seem great as usual but its the motion which is affecting the picture to me thats bothering me.
Reply LCD Flat Panel Displays
Samsung Un60f7100 60 Inch 3d Ultra Slim Smart Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv
