Official Samsung UNXXF7100 Owners Thread - Page 186 - AVS | Home Theater Discussions And Reviews
post #5551 of 5574 Old 05-26-2015, 05:38 PM - Thread Starter
PiratesCove's Avatar
Quoted: 29 Post(s)
Liked: 131
Originally Posted by matrix123 View Post
Since the new update I am now seeing small texts and thin lines flicker. For example: the texts that pop up over the Science Channels logo during shows or small sentences during car commercials. I did see this way back when I first got the TV but an update fixed it. Seems like it's back now in this update. Any one seeing this? Also I'm using AMP CLEAR. This flicker also still happens when AMP IS OFF too.
Sorry to hear this, I've never seen this on any Firmware Version (including the latest) on the F7100.
I have DirecTV for my 1080i sources and use Film Mode: Auto 1 with AMP, LED Clear Motion : On.
Sounds like an interlacing issue- I have seen this on a bad panel Samsung D6900.
I think its a processing issue, I didn't see this even before my factory reset fw. ver. 2209.
Does this happen on all channels (Fox and ABC are native 720p so they should be OK) ?
PiratesCove is offline
post #5552 of 5574 Old 05-27-2015, 05:42 AM
matrix123's Avatar
Quoted: 13 Post(s)
I'm using Comcast xfinity with video preference set at 1080p @60. I don't think this setting should matter but I'm guessing the xfinity X1 box is up scaling the original signal to 1080p. I did test blu Ray and call of duty on ps4 and saw non of the issues I prev said. I will also test with 1080p off and see what happens at 1080i
matrix123 is offline
post #5553 of 5574 Old 05-27-2015, 07:30 AM
mchigantvfan's Avatar
Even after reading about the text flickering issue, I decided to take a chance and update from 2207 which I thought looked great. I'm happy to report I see none of the flicker that some have reported. The image looks great to me although, I have to say, I don't notice much difference. I did have to go into WB and turn blues down just a little but other than that, 2209 looks much like 2207 to me.
mchigantvfan is offline
post #5554 of 5574 Old 05-27-2015, 04:16 PM
asburyf's Avatar
I recently updated the firmware and did a complete factory reset following. I then set everything (I think) back to what is was before. All is good except now when there is a dark screen, in the absence of any objects, the screen switches to all black (like it was off) then as soon as a credit roles it switches back. Very annoying when it is switching back and forth. This is on movie mode. Any thoughts?
asburyf is offline
post #5555 of 5574 Old 05-27-2015, 09:48 PM
mgh26's Avatar
Quoted: 24 Post(s)
Liked: 60
matrix123 I saw in another thread a really close description to what you are seeing & the cure was to turn down the Sharpness. You are on 20 I believe... Should be OK but try around 15 & see if that helps. Maybe this version tweaked the sharpness back to super sensative? I don't know since I stuck with ver 2207.
Pirate & anybodyelse care to comment on the SOE effect with ver 2209... Higher judder was mentioned I think. Does that creat more SOE? Less SOE? The same.... Compared to Ver 2207 that is.
mgh26 is online now
post #5556 of 5574 Old 05-28-2015, 06:35 AM
matrix123's Avatar
Quoted: 13 Post(s)
I've done some testing and the flicker Iam seeing seems to be with very thin texts, thin lines say on someone's suit or hair. I also see what appears to be flashing when say the sun shines through Trees. This also happens when light hits grass too. I only noticed this after new update. I have tried changing the resolution to 1080i with no change. The only other time I saw this issue was after I first got the TV but it went away after an update and changing my film mode (which is grayed out now on new xfinity X1 box) so now i don't know what to do.
post #5557 of 5574 Old 05-28-2015, 07:03 AM
macmane's Avatar
Quoted: 14 Post(s)
Liked: 27
we just have to wait for another update to b honest. ive said it since the first day of this patch that it was not right but I understand the frustration man I really do
macmane is online now
post #5558 of 5574 Old 05-28-2015, 07:12 AM
matrix123's Avatar
Quoted: 13 Post(s)
I'll try the sharpness test later when I get home. My sharpeness is 15 for gaming and 10 for TV and Blu Ray. Sharpness def needed a reduction after latest update. Especially on my game mode for ps4 and Xbox one.
post #5559 of 5574 Old 05-28-2015, 07:22 AM
matrix123's Avatar
Quoted: 13 Post(s)
One thing I forgot to mention earlier and hope this means something to someone who can help out, the flicker and lines issue I explained earlier does STOP when I PAUSE the show/channel.
post #5560 of 5574 Old 05-28-2015, 09:38 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 131
With fw. ver. 2009 before the reset the Judder was high with no SOE (with my settings).
I haven't used AMP Clear on 2209 so I really can't comment on SOE options.
After the reset the Judder was reduced and motion was more fluid.
1080i sources still have that slight jerkiness on panning shots.
720p and 1080p motion is flawless on 2209.
2207 motion had less Judder overall, but more 1080i jerkiness and AMP Clear was very SOE-like.
I believe the update was worth the deeper black levels- the picture has more "Pop".
post #5561 of 5574 Old 05-28-2015, 09:49 AM - Thread Starter
Quoted: 29 Post(s)
Liked: 131
Sounds like a combination of the Xfinity box's output of upscaling 1080i and its interaction with the F7100's film mode de-interlacing. Film Mode: Auto 1 is the fix as the default (Off ?) won't resolve all the interlaced lines. The firmware version may have switched the greyed out default from Auto to Off.
post #5562 of 5574 Old 05-28-2015, 10:01 AM
matrix123's Avatar
Quoted: 13 Post(s)
I think when i checked the film mode setting it said off (greyed out) I'll have to double check. I'm also gonna try reducing resolution again and see if film mode returns for me to test. I think it was greyed out because I was pushing 1080p at 60p. Other options are 1080p 30p, 1080i 16:9 and 720p 16:9.
post #5563 of 5574 Old 05-29-2015, 06:09 AM
matrix123's Avatar
Quoted: 13 Post(s)
Well I did all the tests I could test with no results. That 65js9500 or 65js8500 looking very good right about now.
post #5564 of 5574 Old 05-29-2015, 09:13 AM
macmane's Avatar
Quoted: 14 Post(s)
Liked: 27
those are 4k correct?
post #5565 of 5574 Old 05-29-2015, 09:42 AM
matrix123's Avatar
Quoted: 13 Post(s)
Yes. Been thinking of upgrading in the next year. The js9500 is full array back lit which is what I want the most vs edge lit. But don't know how I feel about the curve screen. The js8500 is the only top tier flat screen and 2 grand cheaper.
post #5566 of 5574 Old Yesterday, 10:48 AM
PainKiller89's Avatar
PirateCove,
Can you please post your updated picture TV settings? After the update everything was reset and now picture quality looks crap.
PainKiller89 is offline
post #5567 of 5574 Old Yesterday, 01:55 PM
Can anyone tell me what i should set this settings to?
Picture Options
Color Temp Warm2
Dig Clean View – Off, Auto or Low
Mpeg – Off, Auto or Low / HDMI black level- Normal: Xbox360- RGB / Expanded
Film - Auto 1, Auto 2
Auto Motion Plus – Off, Clear, Custom - Blur 10 - Judder 0 - LED Clear Motion On
Cinema Black Low, Medium or High
post #5568 of 5574 Old Yesterday, 03:31 PM
macmane's Avatar
Quoted: 14 Post(s)
Liked: 27
Picture Options
Color Temp Warm2
Dig Clean View ? Off, Auto or Low
Mpeg ? Off, Auto or Low / HDMI black level- Normal: Xbox360- RGB / Expanded
Auto Motion Plus ? Off, Clear, Custom - Blur 10 - Judder 0 - LED Clear Motion On
I use warm 2 standard mode mpeg off hdmi black level low amp set to clear film mode auto 1 cinema black medium digital clean view off
post #5569 of 5574 Old Yesterday, 03:36 PM
macmane's Avatar
Quoted: 14 Post(s)
Liked: 27
Picture Options
Color Temp Warm2
contrast 92 brightness 44 sharpness 20 color 47 white balance default since I dont have meter dynamic contrast off black level enhancer off gamma 0 backlight 5
post #5570 of 5574 Old Yesterday, 05:35 PM
mgh26's Avatar
Quoted: 24 Post(s)
Liked: 60
Still holding off with this new version but I have lowered my Two Point RGB Offsets to 24 (Default = 25) for slightly darker black's. Somwhere along the line of updates, I do think Black got slightly a bit less deep or it could be Panel age? I'm not really sure but I bet I have over 4500 hours of use on my TV now & still looking really Good.
I do hope Samsung does come out with another update ASAP that helps the Motion thing some have reported while still giving the picture more "Pop" that ver 2209 has! That would be Ideal.
mgh26 is online now
post #5571 of 5574 Old Yesterday, 06:06 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 131
PirateCove,
No update to Picture Settings for fw. ver. 2209, still looks awesome to me...
post #5572 of 5574 Old Yesterday, 06:16 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 131
The motion on fw. ver. 2209 is as good as fw. ver. 2207 after the Factory Reset.
The Pop factor is really only the darker black levels.
After experiencing both versions I'd say it's OK to stick with 2207.
mgh26 likes this.
post #5573 of 5574 Old Today, 12:58 AM
zeuswsu's Avatar
I know some have reported the TV turning off, but I'm wondering if what I'm experiencing is the same thing. I have my PC hooked up to the TV and sometimes when I stop playing a game to switch to the desktop the TV turns its self off. When I push the powerbutton on the remote, the red light on the TV will blink that it is registering the remote but the TV stays off. Then after a little while later the TV will turn its self on. The whole process takes about 15-20 seconds.
This happens maybe once a week. Anyone else experiencing something similar?
zeuswsu is offline
post #5574 of 5574 Old Today, 09:31 PM
Liked: 0
may 22 I had my UN60H7150AFXZA delivered. right off the get go i had to chat with samsung about the picture being cut off and freezing of netflixs, also the only page that loads up proper is the google start page.
youtube works ok other than the clumsy way the remote works. when the tv started freezing and force closing i contacted sammy again and they are sending a tech.
I see where some people think browsing is only for a computer? I bought this to have both and I am seriously thinking about returning it for a different model or another brand. does anyone have any kind of fix for the freezing and browsing that sucks ? thanks
what tv would you buy if you had a chance to replace the lemon you bought ?
jrny99 is online now
Reply LCD Flat Panel Displays
Samsung Un60f7100 60 Inch 3d Ultra Slim Smart Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv
