Official Samsung UNXXF7100 Owners Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 127Likes
post #541 of 5835 Old 06-08-2013, 01:15 PM
XBRSteve's Avatar
Quoted: 12 Post(s)
Originally Posted by PiratesCove View Post
Wow..sorry to hear that.
Do you use Anynet+ ?
I wonder if the Universal Smart Touch remote maybe part of the power cycling.
Also a few pages back was a report of 2nd Generation replacement boards.
I have anynet off and its power cycling. I thought about the remote being the issue as well.
Sharp Elite Pro 60
Pioneer Elite VSX-52 Receiver
Pioneer Elite  BDP-62FD BluRay
XBRSteve is offline
post #542 of 5835 Old 06-08-2013, 01:36 PM
XBRSteve's Avatar
Quoted: 12 Post(s)
Does anyone have a td01 60" panel?
Sharp Elite Pro 60
XBRSteve is offline
post #543 of 5835 Old 06-08-2013, 01:48 PM
XBRSteve's Avatar
Quoted: 12 Post(s)
Pulled the batteries out of the remote same issue, time to return it.
Sharp Elite Pro 60
XBRSteve is offline
post #544 of 5835 Old 06-08-2013, 03:11 PM - Thread Starter
PiratesCove's Avatar
Quoted: 82 Post(s)
Liked: 176
Have you tried a factory reset?
If its a firmware issue it may be corrected with the next update.
The ES7100 went through a series of bad fw updates that caused various bugs.
PiratesCove is online now
post #545 of 5835 Old 06-08-2013, 03:18 PM
David Kovacs's Avatar
hi, have a new 65 inch - having same issue -samsung support suggested blu ray player/hdmi cable but don't believe it-curious what is the right fix
David Kovacs is offline
post #546 of 5835 Old 06-08-2013, 03:34 PM
XBRSteve's Avatar
Quoted: 12 Post(s)
I have not tried a reset yet. If it were a firmware issue you would think there would be more complaints.
Sharp Elite Pro 60
XBRSteve is offline
post #547 of 5835 Old 06-08-2013, 03:36 PM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
I also thought about the remote being the issue. Actually about 1 week ago the TV power cycled and I remembered a post that thought it could be the universal so I took it out of the TV room and last night was the first time it acted up again. The only thing I haven't done is a factory reset but the software seemed just fine for several days beyond the lastest upgrade on the set. I guess I'll go for the 2nd generation main board but I'm not happy with my panel now. I know all pixels are good but the left side of the screen has this light leak that's actually about a 1 & 1/2 " strip of lighter image. I think it's called edge bleed but it seems to have gotten much more noticeable recently. I have switched to Movie mode for TV and blu-ray viewing so I do admit the standard mode seems to hide it but not all the way. I know a small amount is normal but usually it is equal on the left and right sides of the panel. My left side is about 50% brighter on the edge as the right side but only after TV warm-up. When powered on cold, the TV has no flashlighting or edge bleed. After mabye 5-10 minutes of warm-up it shows up. I do live in Las Vegas and the temperature has gotten alot warmer so mabye the 5-6 degrees warmer inside temperature makes a difference to this particular TV. It should not if it didn't have some type of thermal issue, my guess being the panel it'self. So I guess here I go again playing the stupid panel lottery if approved for repair exchange this comming week. Well I hope all works out or it will be another new TV exchange for me.
mgh26 is offline
post #548 of 5835 Old 06-08-2013, 03:43 PM
XBRSteve's Avatar
Quoted: 12 Post(s)
Good luck I am in the same boat. I had my panel adjusted just the way I like it. The picture is great, minimal flashlighting and now this :-(. Hmmm..LG?
Sharp Elite Pro 60
XBRSteve is offline
post #549 of 5835 Old 06-08-2013, 03:59 PM
XBRSteve's Avatar
Quoted: 12 Post(s)
It only happens when watching bluray?
Sharp Elite Pro 60
XBRSteve is offline
post #550 of 5835 Old 06-08-2013, 04:59 PM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
Just got replacement from best buy. Tv was un used this time and shipped with out any damage to box. Testing now in day light and I see three lighter spots in middle top of tv. Can see only in bright light images shown on screen. Not sure if this is a different form of light bleed or the pixels are firing brighter in that area. Not even sure if this type goes away over time. Any thoughts are welcomed.
matrix123 is offline
post #551 of 5835 Old 06-08-2013, 05:10 PM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
So are you saying the used TV looked better? You were warned. lol
Weird that it would be brighter in the center of the screen. Is that on a black screen or with an actual picture up? Doesn't sound normal if that is something you are seeing while watching the TV.
eric3316 is offline
post #552 of 5835 Old 06-08-2013, 05:15 PM
matrix123's Avatar
Quoted: 292 Post(s)
Liked: 123
Only during a very bright scene in that area. Don't see any thing when letterbox bars are on and nothing on dark screen. Still light out out so I haven't put it through night time tests yet. Your right. As of now old one was better but night time on old one was littered with clouding and flashlighting. This one has yet to show its ugly dark side. I'll replace this one again if that's the case I don't care. I brought the protection plan for an extra $250. Got on more hour till darkness though for other tests.
post #553 of 5835 Old 06-08-2013, 05:25 PM
eric3316's Avatar
Quoted: 839 Post(s)
Liked: 959
Usually the daytime light will cover up most of the flaws found with LED TV's. If you are seeing problems in the daytime I surely would not be keeping it. I have been through 7 LED TV's over the last few months and none of them showed brightness pops at the center of the screen. Not even some LG entry level LED TV's I started with.
eric3316 is offline
post #554 of 5835 Old 06-08-2013, 07:14 PM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
Having a bad blu-ray cable would show up blotchy or unstable/no video. My blu-ray player is GREAT and did not even hicup when my TV re-booted while using it. Also, my TV will normally turn Off the blu-ray player if powered off during blu-ray viewing. This does not happen so it seems like the firmware to make that happen is also by-passed when this re-boot occures. Final thought is that if a bad blu-ray cable somhow did cause a TV power cycle reboot, why does the time clock get reset also? I recall a recent firmware fix to prevent the time from resetting that reportedly worked but now it does seem weird that my time clock has reset issues. You would think though that many others should heve seen this crop by now though. Do you guys set the clock in Manual mode or Automatic mode. I am using Manual mode. AND.....It really does feel firmware related. BUT..... Mabye it only affects marginal Main Boards that got hardware design updated in the 2nd generation batch thats now being used. I can only hope! Good luck to all that have this issue. It is APITA but has not showed its ugly face since last night's 6 re-boots eek.gif.
mgh26 is offline
post #555 of 5835 Old 06-08-2013, 08:08 PM - Thread Starter
Quoted: 82 Post(s)
Liked: 176
I also thought about the remote being the issue. Actually about 1 week ago the TV power cycled and I remembered a post that thought it could be the universal so I took it out of the TV room and last night was the first time it acted up again. The only thing I haven't done is a factory reset but the software seemed just fine for several days beyond the lastest upgrade on the set. I guess I'll go for the 2nd generation main board but I'm not happy with my panel now. My left side is about 50% brighter on the edge as the right side but only after TV warm-up. So I guess here I go again playing the stupid panel lottery if approved for repair exchange this comming week. Well I hope all works out or it will be another new TV exchange for me.
Wow eek.gif....Best of Luck...
I also had the TV turn off and on with losing the Time about a week ago.
I was during a storm and only happened once- so I didn't think too much of it. I had fw 1103 at the time.
Now on fw 1104 I haven't had any issues.
post #556 of 5835 Old 06-08-2013, 08:52 PM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
Thanks Alot. As I recall I believe the first reset was most likely with Ver 1103. My Apt building was being prepared for a re-painting so I also thought it might have been sombody messing with the building power for a split second. I know better now. As far as the panel issue, I've blasted the AC all afternoon and the edge bleed may be slightly less. My picture is still really good over all and it is a scary proposition to do any more panel swap outs. It will be interesting to see what the Samsung tech has to say about it anyways.
mgh26 is offline
post #557 of 5835 Old 06-08-2013, 11:19 PM
5gr3y's Avatar
My 65 inch is powercycling I did an update this morning and it has happened 3 times now.hasnt happened before.
5gr3y is offline
post #558 of 5835 Old 06-09-2013, 07:50 AM - Thread Starter
Quoted: 82 Post(s)
Liked: 176
Hopefully its a firmware glitch that can be corrected since you and others are reporting it to Samsung.
The PQ issue may be related to the power cycling and heat build-up.
post #559 of 5835 Old 06-09-2013, 07:51 AM - Thread Starter
Quoted: 82 Post(s)
Liked: 176
Do you mean firmware update or Smart Hub?
The reason I ask is that 95% of the time my HDTV is disconnected from the net./ Wi-Fi.
post #560 of 5835 Old 06-09-2013, 08:14 AM
5gr3y's Avatar
The reason I ask is that 95% of the time my HD disconnected from the net./ Wi-Fi.
It happened after ver 1104 which is firmware I think. Anyways I found a fix that works for me. I went to No signalpower off and turned it off(was set at 15 min)and it hasnt happened since.
5gr3y is offline
post #561 of 5835 Old 06-09-2013, 08:56 AM - Thread Starter
Quoted: 82 Post(s)
Liked: 176
Thanks, I also think its a bug related to Eco Solutions or the Clock / Timers.
post #562 of 5835 Old 06-09-2013, 09:10 AM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
It was a fimware update and not a Smart Hub update. As for the No signal power off solution, It is NOT the solution as mine is set to OFF and my TV power cycled again just now. I was watching another blu-ray so this fault may be related to the HDMI I/O but not the cables. My time and date did reset again as well. I reprogramed tie time and date but afterwards I set the clock to Auto instead of Manual. I just want to see if this helps with holding the setting and stops the issue for now. I'll report later if I get another power cycle using this new time configuration setting. I really do believe the latest firmware update contributed to this since My player and cable have been 100% flawless. I also have a 2nd blu-ray/3D player on a different HDMI port that I will be testing later today to see if also has the power cycle issue when watching. If not, I'll try and swap to my unused HDMI port with the 2D player that is currently power cycling.
mgh26 is offline
post #563 of 5835 Old 06-09-2013, 10:25 AM
Mike Zaaaaayyyy's Avatar
Samsung 7100,Bose Lifestyle T-20,Oppo-Bdp-93:)
Mike Zaaaaayyyy is offline
post #564 of 5835 Old 06-09-2013, 10:28 AM - Thread Starter
Quoted: 82 Post(s)
Liked: 176
It was a fimware update and not a Smart Hub update. As for the No signal power off solution, It is NOT the solution as mine is set to OFF and my TV power cycled again just now.. My time and date did reset again as well. I reprogramed tie time and date but afterwards I set the clock to Auto instead of Manual.
My Clock is set to Auto on fw 1104 (no cycle) and before it was Manual on fw 1103 (with 1 cycle).
Thanks for keeping us posted. I hope somebody at Samsung figures out what is causing this.
post #565 of 5835 Old 06-09-2013, 11:30 AM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
Your welcome. I now know setting the Clock in Auto or Manual mode does not matter. I got another power recycle in auto mode. I am now considering HDMI port #2 (ARC Port) may be contributing to this as my HDMI port 3 has not re-cycled as of yet while watching a blu-ray with identical settings as HDMI port #2 SO... I now have connected my 3D blu-ray and HDMI cable from port #3 to port #2 and am re-testing. If this issue is related to port HDMI port #2, I expect to see a power cycle but since this is intermintent this may or may not be conclusive test results if I don't get the issue. with this configuration. For anybody that has this problem, what HDMI port were you using when the power re-cycle happened. I'm curious to know if it was also HDMI port #2. Edit: 5 minutes into this test, I got another power re-cycle like I expected. This is with my 3D player and cable that was just fine in HDMI port #3 for over 1 hour. I am now back in port #3 with this player and cable. If no further re-cycles occur, I am going to have to assume I am right and the issue seems port #2 (ARC) related. I'll continue to test for the next hour or so and then I'll report back again. If no further re-cycles happen, I'm going to turn off that Aynet feature next to see if the "Smart auto handshakeing functions" between the TV and Blu-ray player are now triggering this issue in port #2 since the firmware update. I really hope I can isolate it. Either way, it looks like a new Main board is in my TV's future for the quickest problem resolution.
mgh26 is offline
post #566 of 5835 Old 06-09-2013, 11:46 AM
5gr3y's Avatar
I am using port 2 arc but as mentioned earlier I havent experienced it since switching no signal power.may want to checksleep timer and auto power off
5gr3y is offline
post #567 of 5835 Old 06-09-2013, 12:01 PM
mgh26's Avatar
Quoted: 45 Post(s)
Liked: 91
Good suggestion but I did and they are OFF. Question to XBR Steve.... Are you also having your Power re-cycle issues while using HDMI Port #2?
mgh26 is offline
post #568 of 5835 Old 06-09-2013, 01:48 PM
Sebas Garcia's Avatar
I was watching pirates of the caribbean last night when a whole bunch white boxes started running through the top of the screen . I read someone else had this issue and did a factory reset question is how do i do a factory reset?? also anyone know the cause of these things? is the tv faulty?
Sebas Garcia is offline
post #569 of 5835 Old 06-09-2013, 02:19 PM - Thread Starter
Quoted: 82 Post(s)
Liked: 176
Originally Posted by Sebas Garcia View Post
I was watching pirates of the caribbean last night when a whole bunch white boxes started running through the top of the screen . I read someone else had this issue and did a factory reset question is how do I do a factory reset?
To reset go to Menu > Self Diagnosis > Reset - the code should be 0 0 0 0 (four zeros).
What was the Movie source?
post #570 of 5835 Old 06-09-2013, 02:34 PM
I'm using my 160 slim ps3 through HDMI 1 running through my sony receiver all with HDMI 1080/24p
Reply LCD Flat Panel Displays
Samsung Un60f7100 60 Inch 3d Ultra Slim Smart Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv
