Official Samsung UNXXF7100 Owners Thread - Page 195 - AVS Forum | Home Theater Discussions And Reviews
 127Likes
post #5821 of 5845 Old 08-30-2016, 04:15 PM
jpav80's Avatar
un55f7100 2220 firmware update resulted in bad flickering
I updated to firmware 2220 today and it immediately caused flickering on the top 3rd of the screen. I found that if I turned off LED clear motion under custom auto motion plus settings the problem goes away. It was working fine under 2214. Anyone else notice this issue or is something now wrong with my TV.
I wish there was a way to go back. I was doing fine with the older firmware.
jpav80 is offline
post #5822 of 5845 Old 08-30-2016, 09:14 PM
mgh26's Avatar
Quoted: 48 Post(s)
Liked: 91
Sounds like you need to do a Full Factory Reset. Write your settings down before you do it if you haven't alrready done that.
Ver 2220 does not cause flickering, at least your the first one to report it so I bet the reset corrects your issue. I've had to do the Factory Reset many times after doing a firmware update. It sucks but it does seem to correct weird issues like the one you are having now. Hope that helps!
mgh26 is online now
post #5823 of 5845 Old 08-31-2016, 09:43 AM
jpav80's Avatar
Looks like my Power Supply for the TV might have went during the update. It appears to match an issue people have experienced with their TVs using the Clear Motion or 3D capability of the TV. I still have support for my TV so I am having Sears take a look.
I will try a factory reset, but I am not putting much stock that it will fix it. Thanks for the advice.
ddcook10 likes this.
jpav80 is offline
post #5824 of 5845 Old 08-31-2016, 12:42 PM
jrn90240's Avatar
Liked: 0
When I go into smart hub and into youtube flickers. Goes light to dark. Will try factory reset.
jrn90240 is offline
post #5825 of 5845 Old 08-31-2016, 01:01 PM
jrn90240's Avatar
Liked: 0
Also if I turn off the boot logo and turn it off 2x it will come back on. Also the eco solution will turn itself on. I just had service here and Samsung was called. Informed no issues like this reported. Also boot cannot really be turned off. Eco should turn off and stay off. Main board was ordered.
jrn90240 is offline
post #5826 of 5845 Old 09-09-2016, 11:37 AM
emileg's Avatar
Liked: 38
Still enjoying the picture quality of 2220. However, the new hub is terrible. I logged into Facebook to see my photos I posted and they were tiny and low resolution. The set logs me into Facebook every time I turn on the TV, even if I don't go to Facebook. I just want to get rid of the app. Anyone know how? Thanks.
emileg is offline
post #5827 of 5845 Old 09-27-2016, 05:27 PM
jpav80's Avatar
Power Supply replaced. Issues and more came back
[QUOTE=jpav80;46450993]Looks like my Power Supply for the TV might have went during the update. It appears to match an issue people have experienced with their TVs using the Clear Motion or 3D capability of the TV. I still have support for my TV so I am having Sears take a look.
So I had my Power Supply replaced by Sears to fix the flashing display on the top third of the screen when clear motion and 3D turned on. Initially this seemed to work, but later in the day the problem returned in the center of the screen, but only on clear motion. The 3d seems to be fine. The clear motion issue was intermittent and sometimes went away with a power reboot. After some a few more days, the TV is now having trouble turning on. It will click on and off several times and eventually turn on and the clear motion is flickering all the time unless I turn it off. I had the Sears guy back and they want to replace the display. I feel like I got a bad power supply and they should try another one first. Anyone think it could be the panel? I hate the idea of swapping a panel since I could get a much worse (uniformity or banding issues)
jpav80 is offline
post #5828 of 5845 Old 09-27-2016, 10:20 PM
mgh26's Avatar
Quoted: 48 Post(s)
Liked: 91
[quote=jpav80;47090625]
Have you tried a full System Reset yet since the update? If so & you probably have already, also could be the Main Board. How's the panel you currently have besides this flashing issue? If it's been a good one up to this point, might try the Main Board first. Consider the possibility of a bad Firmware Download.
mgh26 is online now
post #5829 of 5845 Old 09-28-2016, 04:27 PM
jpav80's Avatar
[quote=mgh26;47095545]
I did attempt a reset last time before having Sears out, but it didn't help. I haven't tried it again since the power supply change mainly because I am worried about the difficulty getting the TV back on. Today it seems to be ok as it started 2 times without an issue. I am happy to have the warranty with Sears, but they are slow as molasses. I am tempted to buy a power supply from PartsStore.com since they offer 30 day return on opened products. I have a feeling they won't fix the issue and I will have to get a new TV. This actually will be the 2nd time they will have to replace a TV under the service plan. The next TV will not be a Samsung since I have now had 2 sets fail after 3 years or less. At least to me their quality is subpar. I might as well spend less money on a Vizio and replace it every 3 years.
jpav80 is offline
post #5830 of 5845 Old 09-30-2016, 03:09 PM
jrn90240's Avatar
Liked: 0
[quote=jpav80;47114817]
I been having the opposite problem. I will turn off the tv and come back to see that it came back on. I thought maybe I did not turn it off...I tested today and it turned off then came back on by itself..
jrn90240 is offline
post #5831 of 5845 Old 10-02-2016, 10:52 PM
mgh26's Avatar
Quoted: 48 Post(s)
Liked: 91
Face Book is an application that can be uninstalled in the Samsung Apps section. Locate the Facebook Icon in the app section and select it. Since it's already installed, it will now give you the option to uninstall it unlike some permanently installed apps. I don't have it on my TV as I also have uninstalled it.
emileg likes this.
mgh26 is online now
post #5832 of 5845 Old 10-08-2016, 12:54 PM
emileg's Avatar
Liked: 38
It took a while to figure out how to delete the Facebook app. When I clicked on the icon, the app kept opening. Somehow, I accidentally got into the edit menu. I think I double clicked on the icon, which put an X over it. Then I clicked on the icon again and the choice came up whether to delete it or not. Samsung certainly doesn't make it intuitive, because I could not find how to get to the edit menu on purpose. Nevertheless, thanks for the head's up that I could, in fact, delete an app.
emileg is offline
post #5833 of 5845 Old 10-19-2016, 11:25 AM
troglodytes's Avatar
I've been going through this thread and I'm convinced buying the 65F7100 is going to be the best bang for my buck I can get when buying a large used tv for our overly long living room. I'm going to pick on up tonight, and I'm wondering how to go about checking the hours on the tv to make sure it hasn't been sitting on all day and night since 2013.
I will have a chance to demo it, to look for dead/locked pixels. Is there anything specifically quirky I should be looking for with the 65" version? I know some where having issues with white boxes in the letterbox space. Thanks
Edit: In addition, this will be used mainly as an output for my HTPC on which we watch Netflix, BluRay, and game. All inputs (HTPC and Cable box) will run through my receiver and thru single HDMI to TV. Is this problematic with this display? Will I need to tweak settings when switching between gaming and movie watching all on the same input?
troglodytes is offline
post #5834 of 5845 Old 01-31-2017, 10:34 AM
dank0723's Avatar
Quoted: 18 Post(s)
Hey guys, Im terribly sorry if this has been answered a ton of times, but I cant find a reliable answer. What size are the screws for the stand for the 65f7100 that I can give to someone at Home Depot or a hardware store? Im taking it off the wall for the first time ever and dont have the original screws, and all the sites that sell them dont actually show what size they are :/ Thanks in advance!
I see M4 screw L16. Is this correct, and if so something that you dont have to buy from some ripoff 3rd party website?
dank0723 is offline
post #5835 of 5845 Old 02-01-2017, 08:42 AM
jvandyne's Avatar
According to the quick start guide you need a total of eight M4 by L10 screws for the 65" version. Four to attach the the stand to the mount and four to attach the mount to the TV. On p.34 of the manual at the link.
https://pdf.crutchfieldonline.com/Im...30546F7100.PDF
jvandyne is offline
post #5836 of 5845 Old 02-05-2017, 08:48 PM
dank0723's Avatar
Quoted: 18 Post(s)
Thank you!
dank0723 is offline
post #5837 of 5845 Old 03-23-2017, 10:48 PM
mgh26's Avatar
Quoted: 48 Post(s)
Liked: 91
New Firmware Ver 2225 released
Well its been a while but in just seeing if any new firmware was nowreleased, I discovered 2225 being avlible for download. I have not done the upgrade as I really love my current version. Has any body done this update yet. Any comments?
mgh26 is online now
post #5838 of 5845 Old 03-24-2017, 10:22 AM
4top455's Avatar
Yes just updated to the latest update. Notable reduction in whatever minor flashlighting i had in the bottom corners while maintaining the same settings as before. Probably they did some algorithm changes to improve LED stuff. Incidentally also had updates on my much newer ks8000 tv also yesterday. Guess it is a system wide update for Sammy's !!
4top455 is offline
post #5839 of 5845 Old 03-25-2017, 12:11 PM - Thread Starter
PiratesCove's Avatar
Quoted: 82 Post(s)
Liked: 176
I updated to Fw. Ver. 2225 and so far its great. Motion and Picture Quality (a little sharper image) are nice.
No negative side-effect (as of yet). I had minor power/backlight issues with Fw. Ver. 2220 so I updated...
PiratesCove is offline
post #5840 of 5845 Old 05-03-2017, 04:15 PM
theking84's Avatar
Has anyone been able resolve the boot logo issue? I don't use any of the smart features and hate how the logo shows each time it's turned on. How do we turn this off for good? Was it fixed with a newer update? I'm currently on 2220.
Version 2220 is really sharp in details just as version 2214 was. I am really happy and would recomend this version . It is just that slight step up in details that I felt was lacking with version 2215 although 2215 was completely acceptable. The only bug I see is what PiratesCove discovered with ver 2215 in that the Boot Logo will NOT stay off when selected. to remain Off. This is really a non-issue and all other functions seem just fine. I can't quite remember how the motion behaved with ver 2214 but 2220 is also really good!!!!! I also really like the change to the Smart Hub that version 2214 did not provide yet if my memory serves me right.
I have also looked at some of the KS series TV's & like what I see. But clouding is very common in Samsung panels due to internal quality control & other external handleing issues SO.... That won't go away but hopefully will get reduced with experience I Hope!!!!!!!!!!
I also updated to Firmware Version 2220 and like it...
I gave up on the Boot Logo issue...
I plan on sticking with the F7100 as it has 240Hz and 3D - 2 features the new HDTV's don't have.
I will hold out for the Samsung OLED (slim to no chance of materializing) or the QLED...
theking84 is offline
post #5841 of 5845 Old 05-08-2017, 05:14 AM
ProfileX's Avatar
If there are awards for first world problems, this might be a good candidate.
ProfileX is offline
post #5842 of 5845 Old 05-08-2017, 06:48 AM
Bgrngod's Avatar
I went from 2214 directly up to 2225 and the boot logo turned back on as part of the upgrade. I just turned it off and it does not show when powering on.
Bgrngod is offline
post #5843 of 5845 Old 05-08-2017, 11:04 PM
mgh26's Avatar
Quoted: 48 Post(s)
Liked: 91
Ver 2220 also allowed you to turn off the boot Logo but it returned back On after secondary TV boots. Does this not happen with the new version 2225? i still have been holding off since I love the picture and motion with ver 2220. I just might update if this is really no longer an issue since the picture quality with ver 2225 has been reported as real good. Please let me know. Thanks alot...............
mgh26 is online now
post #5844 of 5845 Old 05-11-2017, 06:40 AM
Bgrngod's Avatar
Welp, it's a good thing you double checked. It does indeed revert to being turned on. It shows up for only what seems like less than a second, but turning it off is apparently not permanent.
-BG
Bgrngod is offline
post #5845 of 5845 Old Today, 12:59 PM
mgh26's Avatar
Quoted: 48 Post(s)
Liked: 91
[QUOTE=Bgrngod;52898201]Welp, it's a good thing you double checked. It does indeed revert to being turned on. It shows up for only what seems like less than a second, but turning it off is apparently not permanent.
-BG[/QUOTE
]Well I will stay with version 2220 unless sombody can provide any information of any additions or enhansements that are worth the update. My picture and motion are already excellent. I'm really satisfied but still do have Browser issues at times. I think that may be related to the Browser updates and NOT the firmware updates though. Who really knows what Samsung does though? They won't tell us and thats for sure!!!!!!!
mgh26 is online now
Reply LCD Flat Panel Displays
Samsung Un60f7100 60 Inch 3d Ultra Slim Smart Led Hdtv , Samsung Un46f8000 46 Inch 3d Ultra Slim Smart Led Hdtv
