Official LG XXLN5700 / XXLN5750 Owners' Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 203 Old 08-12-2014, 12:47 PM
Liked: 0
Originally Posted by ryll1121 View Post
Greetings all, I purchased the 55ln5750 a few month ago and have finally gotten settings that I quite enjoy. I first tried a few settings for similar panels but ended up going with a mix of a few settings. Few things before I post the settings....the tv is in my basement so not a lot of natural light. Even with the room lit to the max I still enjoy the colours. I also don't have a lot of the features enabled like Tru Motion or Super Resolution. I don't really like how they affect the picture.
Enery Saving: off
Pic Mode: Expert 1
Backlight: 60
Contrast: 82
Brightness: 50
H Sharpness: 10
V Sharpness: 10
Color: 58
Tint: G2
Picture Options:
Black Level: Low
All Other Options: Off
Expert Control:
Color Gamut: BT709
Gamma: 2.2
All other settings: Off
The White Balance and CMS settings I am using are from this post:
LG 55" 55LM7600 calibration
White Balance:
Color Temperature: Medium
Method: 20 Point IRE (See Settings Below)
Pattern: Outer
Luminance: 130
IRE Settings:
IRE Value: Red, Green, Blue
100: 12,21,9
95: 50,50,40
90: 50,50,37
85: 42,22,32
80: 34,18,36
75: 40,20,42
70: 50,30,50
65: 50,34,46
60: 29,18,24
55: 24,11,26
50: 22,4,18
45: 24,12,22
40: 20,9,20
35: 18,10,18
30: 15,7,14
25: 4,0,4
20: 2,-1,2
15: 2,2,4
10: 10,8,2
5: -3,4,-16
Color Management System Settings:
Color: Saturation, Tint, Luminance
Red: -6,5,17
Green: -10,8,4
Blue: 8,0,5
Cyan: 0,5,5
Magenta: 0,-1,4
Yellow: -10, 1, -2
I purchased the Samsung HW-F450 soundbar at the same time and have it running just on digital optical for the sake of being lazy and having it automatically power on/off when we are watching tv. I know I know...the audiophiles here will rant and rave about HDMI being better for audio or whatever.....I have been to a lot of concerts in my day and in all honesty I probably couldn't hear the difference. So suck it...laziness auto power on wins.
I have been messing around with passive room lighting lately and might still setup an ambilight knock off for chits and giggles.
Calibrated my TV this past weekend with a friends Spyder4 colorimeter and came up with a couple of different settings:
With the above IRE settings (saved -> Expert1):
Color Temp: Warm2
Backlight: 60
Brightness: 50
Contrast: 94
Color: 48
Tint: 39
With No changes in IRE points (saved -> Expert2):
Color Temp: Warm2
Backlight: 50
Brightness: 50
Contrast: 94
Color: 59
Tint: 49
ryll1121 is offline
post #182 of 203 Old 08-12-2014, 06:11 PM
Spudsicles's Avatar
To narrow it down you could try connecting it to a different network...maybe try turning your phone into a hotspot and see if it works that way? I have also heard that LG doesn't allow for spaces in passphrases, I have made that mistake myself the last time when I changed out routers.
Here's the problem it won't even give me the list of available wireless networks. Also I have no spaces in my password.
Spudsicles is offline
post #183 of 203 Old 08-13-2014, 07:55 AM
Liked: 0
Ya...that's not a good sign at all if it isn't detecting any wifi at all. I don't know of any other way to reset the tv back to stock
ryll1121 is offline
post #184 of 203 Old 08-20-2014, 07:42 PM
Bigborefan's Avatar
Liked: 0
I have an LG 50LN5700.
I have it streaming content from a Windows 7 computer via WiFi. Everything works great except for one problem. When browsing the shared folder on my PC from the TV, I do not see all the files and folders. It is very sporadic, hit and miss. For instance I have a folder called Masters of Sex, and I have five files in that folder. The computer can see and play all five files, but the TV only sees 3 of the 5 files.
I copied the five files to a USB drive, plugged in the USB drive to the TV and was able to see and play all five files.
Anyone had any similar issues?
I must say I so far I am not a not of a "smart tv". Might as well just use a computer, since that's all the smart tv is anyway, and not a great one at that.
Bigborefan is offline
post #185 of 203 Old 08-22-2014, 08:44 AM
Bigborefan's Avatar
Liked: 0
I fixed it. Wasn't the TV at all. Tech issues can be so bizarre sometimes. Was just a DNLA/Windows Media Player issue.
post #186 of 203 Old 09-29-2014, 02:21 AM
Liked: 0
Hi Guys
I have just purchased a 50LN5700 LG. I am based in South Africa and would like to stream Netflix but my menu does not show the Netflix Icon.....this might be due to my region. Is there a way to install the app or fool the TV into thinking its in the US? Also what 3D file formats are supported via USB as my regular downloads from Yiffy does not play in 3D.
Regards
Fang50 is offline
post #187 of 203 Old 09-29-2014, 04:51 PM
Mr. Cinema's Avatar
Anyone having Netflix issues with the 55LN5700? I've had this tv for about 14 months and it's been flawless. Unfortunately, I think LG's last update in June has caused my Netflix streaming to stop working. The app loads normally, but if I select any title, it says it can't play it right now and to try again later. Anyone else experiencing the same? I have several other streaming options and Netflix works fine, so the problem is with the TV. Obviously I don't need to use the app on the tv with other streaming devices, but it still bothers me that this latest firmware is the cause.
Mr. Cinema is online now
post #188 of 203 Old 10-17-2014, 10:41 PM
cesar123's Avatar
Quoted: 376 Post(s)
Liked: 557
Honestly, I've given up on the TV apps. The "smart features" never truly worked for me. Netflix was good for a while but after an update, its stability completely changed.
Great PQ, but the TV never really reached the high levels that I was expecting (apps, refresh rate, and LG's customer service).
cesar123 is offline
post #189 of 203 Old 11-11-2014, 05:08 PM
DeAd MiKe 187's Avatar
I had the same problem. I signed out, and signed back in, and the problem was solved.
They just released a new software update today. So far, I can't notice any changes. Everything SEEMS to work fine.
DeAd MiKe 187 is offline
post #190 of 203 Old 11-27-2014, 07:34 AM
Liked: 0
I have an Lg 47LN5700 with the same problem it stopped connecting to wireless WiFi. I was working fine until a couple of days ago. When I try to connect I get an error message. It does not detect any wireless networks at all. Anyone have this problem or solution. I have tried anything even resetting to factory. I see a lot of post where it was the password but my password has been the same since I bought the TV and my password has no spaces.
wentworth1234 is offline
post #191 of 203 Old 12-14-2014, 02:53 AM
Liked: 0
I have had a LG 42LN5700 for over a year now from Telus free TV deal when signing up.
So now my TV has decided to drop my wireless connection. I tried to get it to reconnect but now it won't even give me a list of wireless networks available to connect to.
Things I have tried:
  • Updated the software to 05.06.17
  • Reset the whole TV with the initialize app
  • Reset my modem and router, just in case but everything else wireless works
  • Tried to connect to a wireless network, but just gives me an error message "To connect to the network, check the connection status of LAN cable or AP."
Is there another way to factory reset this bad boy and other than the in house menu option?
Or has my TV's wireless card crap the bed, but it seems like a software issue to me rather than a hardware one?
Any suggestions would be great! Thanks in advance!
I am having exactly same issue. Did you found a fix?
Prashant1979 is offline
post #192 of 203 Old 12-14-2014, 09:42 AM
Liked: 0
post #193 of 203 Old 12-14-2014, 09:44 AM
Spudsicles's Avatar
Yeah, I bought a used WiFi card off Amazon and installed it in the TV... fixed!
Easy to do, lay your tv down on it's face... take out all the Philips screws... pry gently and remove the back cover... locate the chip, unplug and remove... plug in the new one... close her back up!
post #194 of 203 Old 12-14-2014, 09:56 AM
Liked: 0
Thanks for the info. Will try it after talking to LG support as my TV might be still covered under warranty.
post #195 of 203 Old 12-20-2014, 11:34 AM
Liked: 0
Hi all,
Apologies if this has been discussed previously....
I have a 50LN5700. Purchased July 2013. It's been working fine until yesterday. The remote doesn't work with it at all, except to power it on. And even then, it takes upwards of 10 seconds before the picture appears (AFTER the initial LG welcome screen, which has been coming on normally). The same happens when I use the buttons on the tv itself (power on takes several seconds, and the channel/volume, etc, etc. get no response).
Does anyone have any suggestions? We've done the obvious (replaced batteries, checked plugs/wiring, etc).
We've also read that there is a way to reset the tv itself. We kept it unplugged all night last night and still no change.
Is there an internal reset? The idea that we wasted this much money is really raining on our parade.
Thanks in advance!!
kkshaf is offline
post #196 of 203 Old 12-31-2014, 06:45 AM
Yup, somewhere in Settings. Look for an option to 'Initialize.' Hope it helps!
post #197 of 203 Old 01-17-2015, 06:05 PM
mostdope's Avatar
I have a few questions. I've been gone a for a while, just got my PC back up and running. I have LG 42LN5700 Smart TV.
- My TV is always drooping it's WiFi connection. For example, I have Plex installed on my PC. I'll go to Input List on my TV and select Plex. Every movie plays fine, but usually, I'd say 5-20 minutes into any movie it just stops, disconnects. I then tried using DLNA from my PC to TV as well. I play a movie and every time, at least once during the movie. it just stop and the TV's WiFi is off? It goes from green to a red X saying I lost connection. After about 5 minutes it turns back on and I can play the movie again. Sometimes during the TV on and off works but not often, I basically just have to wait, almost like my TV is trying to catch the WiFI. This is such a pain in the ass. I bought a Chromecast recently, the WiFI drops happen but rare. Downstairs however, I have a WDTV Live hooked up to my Plasma and I never experience any issues, a hiccup here and there but nothing like the SmartTV upstairs. Any ideas how to fix this annoying issue.
- Is there a website that can help calibrate my TV to get the best settings for color. I'm new to all this and I have no idea what settings to use, I just leave it at stock. I'm sure I could make the TV look more beautiful I just know now what settings to use.
MD
mostdope is offline
post #198 of 203 Old 02-03-2015, 01:03 PM
sgtmike_44's Avatar
Help! I'm looking for help in troubleshooting an issue with my LG 47N5790. When initially turned on, the LG logo dislays for a half-second before the LED back-lighting goes off. Audio remains on and an image is displayed on the panel (determined by performing the "flashlight test") but that's it. When turned off again the picture flashes for another half-second before going off. Has anyone seen a similar issue and how was it corrected?
I've already replaced the power supply board on the advice of the ShopJimmy.com website suggesting the LED driver was the cause, and it was probably built into the PS board, but the problem continues. (There are only 3 boards: a main board, a power supply board and the T-Con board in my TV. The forums here suggest the 47LN5750 model may also have a WiFi board as well; the "90" uses an included dongle for internet access.)
sgtmike_44 is offline
post #199 of 203 Old 04-14-2015, 07:49 PM
avsfish's Avatar
Liked: 0
sgtmike_44,
Sounds like I am just a couple of months behind you. I have the exact same issue and I too replaced the power supply on the advice of ShopJimmy.com and got the same results you did (no change).
Were you ever able to determine the root cause of our issue?
avsfish is offline
post #200 of 203 Old 04-25-2015, 02:09 PM
sgtmike_44's Avatar
47ln5790
Unfortunately, I could not repair this set. Luckily, I paid with Discover during the original purchase and they offer to double the life of your warranty when their card is used. They required it first be examined by an authorized service tech to determine if it is a simple (i.e., cheap) repair or if they return your money. The service estimate (with the inflated labor cost) was higher than my purchase price so Discover paid me. I ended up buying another Samsung.
Note that I eventually tried swapping out the mainboard and T-Con board with replacement parts purchased on E-Bay (the service tech had reported this as the problem to Discover) but to no avail. Sorry! I have still have the set if anyone has other ideas.
post #201 of 203 Old 11-10-2015, 01:39 PM
Liked: 0
Hey guys, sorry for a bump but trying to figure out my issue. I downloaded a software update last night, and afterwards the tv restarted. Upon powering back up, it just sits at the LG screen. Prior to this nothing had ever gone wrong. I'm assuming there is some sort of bug in the software update causing problems somehow. Is there a fix? Does LG have some sort of hard reset I can punch in to boot the tv in default mode so I can reset the tv?
Thank you in advance.
joeylow is offline
post #202 of 203 Old 11-04-2016, 11:09 AM
Liked: 0
I purchased the 47ln5700 demo at Target. Used approx. 11 mo then it started losing the pic but could see the image with a flashlight and had sound. Cut to the chase it was the panel and was replaced in my home. Dodged a bullet on that one.
cardor0 is offline
post #203 of 203 Old 11-04-2016, 11:24 AM
Liked: 0
Also sorry for the extremely late bump. Just wanted to share my experience. btw I was able to get into the secret menu back in April 2014 and the set had 3867 hours on it when purchased ouch. I knew it would be high but 24/7 for 5.4 months is crazy.
cardor0 is offline
Reply LCD Flat Panel Displays
Lg Electronics 39ln5700 39 Inch Led Lcd Hdtv , Lg Electronics 55ln5700 55 Inch Led Lcd Hdtv With Smart Tv , Lg Electronics 47ln5700 47 Inch Led Lcd Hdtv With Smart Tv , Lg Electronics 42ln5700 42 Inch Led Lcd Hdtv With Smart Tv , Lg 32ln5700 32 Inch Led Lit Smart Hdtv , Lg Electronics 50ln5700 50 Inch Led Lcd Hdtv With Smart Tv , Lg 47 Inch Led Smart 47ln5750 Hdtv
