Is this an acceptable level of backlight bleed from the corners? (LG 47LM4600 - 5 months old) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-03-2013, 06:52 AM - Thread Starter
FrankTheTank2's Avatar
I have had this TV (47LM4600) for about 5 months with zero problems. Almost overnight I noticed white background spots in the corners. Even after I turned backlight down to 30 I still get them (as shown in photo). Is this normal or should I call LG and try to get a replacement? The bleed is still visible during daylight hours and annoy me when I am watching movies in letterbox format.
Any advice for calling LG to complain? Thanks.
FrankTheTank2 is offline
post #2 of 2 Old 05-03-2013, 09:28 AM
LordAlfred's Avatar
Quoted: 13 Post(s)
Unless someone put pressure on the panel (maybe by wiping it?) I don't see how this could develop overnight. Sometimes you don't notice things that get gradually worse until it hits a certain point, and once you've noticed it you always see it.
Is it normal? Well, in my experience corner flashlighting is not uncommon in edge-lit sets. Even brand new it can be fairly bad. Yours might be a little worse than the ones I've briefly owned.
You could try calling LG, but they may say that some bleed is endemic to the tech and not do anything.
LordAlfred is offline
Reply LCD Flat Panel Displays
