Official LG 55ga7900 owners thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 381 Old 08-08-2014, 03:12 PM
NahsiK's Avatar
Originally Posted by Captain Sid View Post
After having this TV for just over a year, it kicked the bucket on me last night. But even before that, it had been nothing but trouble. I won't be buying anything from LG again.
Pros:
Great image, as far as you're able to calibrate it.
Great passive 3D.
Fairly decent built-in apps.
Cons:
Takes a long time to boot up, during which you can't even change the input on the TV.
Won't switch to an input that it doesn't find a signal on, so you always have to turn on your Xbox, PS3, satellite receiver, etc. before you can switch to the input. This makes using a universal remote like my Logitech Harmony difficult. So dumb.
Sometimes it says it's on a particular input when it isn't. This can only be corrected by changing the input to something else and changing it back.
Mandatory firmware update killed the only use I had for the built-in Google TV: Flash video playback.
Brightness fluctuations between light and dark scenes in TV and movies even with all dynamic lighting, eco, and local dimming features turned off.
But as I said, last night it finally died. I was playing an Xbox 360 game with my son when suddenly the screen froze, and a grey "wind" swept from the right side of the screen to the left until the entire image was grey. Now that's all I get when I turn it on. LG says they won't send a technician to my house because I don't live in a large metropolitan area. Even though I paid $1600 for this thing just 14 months ago, I'm almost relieved that I have an excuse to replace it.
Damn! That's crazy! Sorry to hear your troubles. LG keeps sending me letters to buy their 3 year service plan. I've almost had my tv for a year, maybe I should buy it now that I know you're having issues with it. But from when you wrote it sounds like you were having issues for a while? I haven't had any with mine and my family and I watch it every day.
NahsiK is offline
post #362 of 381 Old 09-10-2014, 10:10 PM
WeStayClean's Avatar
does anyone know if i can buy a regular lg remote and use it? i need to reconnect my tv to wifi and lost the og remote.
WeStayClean is offline
post #363 of 381 Old 12-01-2014, 10:34 AM
Liked: 0
Originally Posted by pateli04 View Post
Well I got a good deal from buydig.
I miss my plasma but the one I wanted was 1700. I got this tv for 1k.
I like that I can go to playstore and download apps but in addition I have a Roku (which is what I use most times).
I guess I really don't use the smart tv functionality so it doesnt bother me much.
Anyway....any help would be great on the antenna question because I can't find a way around it.
I don't want to waste money on a amplifier if its still not going to work.
I had the same problem, fixed it by going to Home, All Apps, Settings, Video Input, Configure video input. From the list of source that provides, select "broadcast" - whatever your zip code is (assuming you set that up). It will scan all the channels. After you do that, "Built in tuner" shows up in the inputs, above HDMI-1.
Hope this helps, I was about to give up until I was exploring options on the TV just now and it worked.
Great TV for what I use it for, which is not much (u-verse and OTA)
nolaw70 is offline
post #364 of 381 Old 12-04-2014, 07:44 PM
mercennarius's Avatar
Quoted: 97 Post(s)
Liked: 49
You can download the newest Play Store app using this APK link:
http://www.apkmirror.com/apk/google-...re-5-1-11-apk/
Also using Aptoide you can update a lot of your apps that the factory Play Store is no longer supporting for our Google TV. Additionally you can search a library of apps that are not normally available for our TVs, many work just fine though not all will be comaptible:
http://m.aptoide.com/installer?lang=EN
mercennarius is offline
post #365 of 381 Old 12-16-2014, 03:09 PM
E55 KEV's Avatar
Quoted: 22 Post(s)
I don't have HULU Plus so was hoping the regular HULU app was available for this set. The app I recently downloaded on my Android phone is standard HULU and not the subscription based HULU Plus.
E55 KEV is offline
post #366 of 381 Old 12-16-2014, 03:40 PM
Quoted: 97 Post(s)
Liked: 49
Under Settings make sure "Unknown Sources" is checked. Then download this APK on your TV:
Aptoide will allow you to download the version of Hulu from your phone/tablet onto your TV as well as any other app that isnt available on the regular TV app store. It should be noted that not all apps will work but many will work just fine.
post #367 of 381 Old 12-17-2014, 06:46 AM
E55 KEV's Avatar
Quoted: 22 Post(s)
Thanks, downloaded aptoide and then loaded Disney Movie Anywhere and Hulu (non Hulu Plus) app. DMA did not work and refers users to view the movies on Google Play Movies. Tried Hulu but it still wants to log you in as a HULU Plus member.
E55 KEV is offline
post #368 of 381 Old 02-05-2015, 09:50 AM
anyone having problems with their wifi? my tv used to drop in and out of wifi and now it doesn't even find the network
post #369 of 381 Old 02-05-2015, 09:56 AM
E55 KEV's Avatar
Quoted: 22 Post(s)
That's awful. Can you use an ethernet cable? I had spotty WiFI on another LG model. Make sure no ethernet cable is in when using WiFi. I always had to reconnect with password because I had the cable in.
E55 KEV is offline
post #370 of 381 Old 02-16-2015, 01:26 PM
Liked: 0
Rooting the 55GA7900
Hi all,
I've been a fan of this TV since purchasing it new in 2013. There hasn't been a lot of information out there regarding issues with it, so I've been following this thread every now and then hoping for someone to come up with a way to downgrade after that awful update that removed features some of us really liked. Hell, I bought the TV because it had Plex built in. I saw it on the showroom floor and was sold. At the time, there was very limited Smart TV support for Plex, but I was an avid user.
Anyway, fast forward to shortly after the update and I began searching for ways to downgrade. So far my search for the stock firmware has been fruitless, but one thing I did manage to accomplish that I haven't seen anywhere else is gaining root. Once rooted, I modified the build.prop file to trick the Google Play Store into thinking the TV is a Samsung Galaxy S3 phone. I'll probably switch that up to a device with specs that more closely match the GA7900, but it worked well enough to open up the entire play store so I can install apps that aren't limited to the device! I've had mixed results. Some work flawlessly, others wouldn't orient themselves properly due to the lack of accelerometer (fixed with an existing setting in the TV's menu), and some just flat out crashed.
I did this back in November, and have been looking for a recovery option like TWRP (TeamWin Recovery Project) or CWM (ClockworkMod) in order to back up the existing system before I really stuff things up and need to restore the whole thing. I've been extremely lucky so far, and the process is definitely not for the faint of heart. If anyone is interested, I can post as much detail as I recall, but looking back, it was relatively easy.
Enable ADB Debugging (I used a third-party app because the built-in debugger wouldn't connect via network for some reason)
Use Cydia Impactor to gain root
installed SuperSU
You don't need a debugger that REQUIRES root, just allows the connection so that Cydia Impactor can made the modifications necessary. I read in a few places that this process was not a permanent root, meaning you would lose it on a reboot. That has not been my experience so far. This method has survived all reboots, and a few scary issues where I thought I bricked it.
So I say all of this to ask a question:
Do any of you still have your system on the factory installed firmware and willing to take a chance? I'm working on finding a way to back up and restore the entire file system. If I can get that working, the next step will be downgrading, or at the very least, finding apps that will restore the functionality we all lost with the update.
Please note: I am not a developer, so if you're not familiar with the rooting process of most Android devices, you might want to steer clear of this. Unless of course you have a bunch of disposable income and don't mind bricking your set
Questions welcome.
Remedee
remedee is offline
post #371 of 381 Old 02-21-2015, 02:16 PM
lmbebo's Avatar
Looking for possible replacement remote for this tv. Wife/daughter spilled and now the joy stick part of the remote does not work.
Not sure how easy it is to find a replacement.
Alternatives out there?
lmbebo is offline
post #372 of 381 Old 03-08-2015, 03:46 PM
Sinistar83's Avatar
Does anyone know if there's a way to disable the power going to the USB when the TV is turned off?
I just got one of these from Amazon http://www.amazon.com/Antec-HDTV-51-...dp/B007TG5EG8/ and it's powered by USB but I want it to turn off and on when the TV turns off and on, so it doesn't stay on the whole time. There's a little manual 'flip switch' on the USB cord itself but its going to be a pain to have to reach behind the TV to turn it off an on.. I'd rather just leave the switch on the whole time and toggle power by the TV
Sinistar83 is offline
post #373 of 381 Old 09-13-2015, 05:31 PM
E55 KEV's Avatar
Quoted: 22 Post(s)
E55 KEV is offline
post #374 of 381 Old 09-13-2015, 06:51 PM
eagle132's Avatar
Only 2 years and the app support is almost non-existant on the TV and for GTV in general. Huge disappointment. If only there was a way to flash the LG WebOS software on there instead .
On another note, during very dark scenes the TV's brightness noticeably lowers. I have disabled every auto setting that you may think could be causing this but it doesn't seem to be working - getting very frustrated!
eagle132 is offline
post #375 of 381 Old 09-13-2015, 07:46 PM
E55 KEV's Avatar
Quoted: 22 Post(s)
WebOS losing AIV also. No 2014 or 2015 WebOS models on the approved list.
E55 KEV is offline
post #376 of 381 Old 11-03-2015, 10:21 PM
jjt3hii's Avatar
Liked: 0
So what is the lastest software version for this TV?
Mine shows 03.09.03
Andriod version 4.2.2
kernel version 3.4.5 october 2013
I cant find a way to check for updates in the menus.
jjt3hii is offline
post #377 of 381 Old 12-22-2015, 07:59 AM
Sinistar83's Avatar
So I just noticed today the 3D World got discontinued.. Anyone know how to delete the icons and section off the homescreen for it?
I emailed LG support and they suggested I factory reset my TV... Wouldn't that bring that default stuff back?
post #378 of 381 Old 05-05-2016, 08:21 AM
Quoted: 17 Post(s)
Liked: 0
Has anyone owned this TV for a long period of time and can comment on it's reliability? I'm hesitant to buy LG again after such a terrible experience with my 42LS4700, which had backlighting problems
RandyLahey007 is offline
post #379 of 381 Old 01-24-2017, 09:56 PM
Sinistar83's Avatar
I still have mine, but I just replaced my DVR and now it's not detecting the new one under Settings > Video Input > Configure Video Input (setup TV service Provider)
it gets stuck on "Select your lineup provider (MY ZIP CODE) unable to obtain lineups for your location" error.
Also the PrimeTime app will no longer show TV listing, I get error "there is nothing to be displayed here, check your network settings" - yet the TV is hooked up to my home WiFi.
So I suspect the software settings for this TV has been abandoned. It is still on Android 4.2.2.
The picture is still as good as I got it, the 3D still works well, and no power issues or light bleeding issues as far as I can tell.
post #380 of 381 Old 01-31-2017, 08:28 PM
NahsiK's Avatar
I've had this tv for years, I wanna say 4-5 years? It works good, no issues. However, I did just replace it with the LG OLED65C6P which is INCREDIBLE!
This tv has now been moved to my bedroom for casual viewing before I go to sleep.
NahsiK is offline
post #381 of 381 Old Today, 03:43 PM
Liked: 0
Dead unit
Im in search of a dead unit with a working screen mine was in great working condition but took a baseball to the screen. id pay $300 plus shipping.
tgfelkner is online now
Reply LCD Flat Panel Displays
Lg Electronics 55ga6400 55 Inch Cinema 3d Led Lcd Hdtv
