Suggestion for 47 or 50 inch LCD with no soap opera effect - AVS Forum | Home Theater Discussions And Reviews
Old 05-13-2013, 01:36 PM - Thread Starter
Ands's Avatar
Can anyone please suggest LCD with doesn't have any soap opera effect. I have been considering 47LA6200 since it's new i couldn't lot of review on it.
Ands is offline
Old 05-13-2013, 01:45 PM
grjelectronics's Avatar
Do you have price range? Also, most TVs usually have a way to turn off the setting that causes a "soap opera" effect. Of course these sometimes also makes the quality worse.
grjelectronics is offline
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Soap Opera Effect????
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
Old 05-13-2013, 02:09 PM - Thread Starter
Ands's Avatar
Around ~1000. I heard is most TV's even if you switch it off there is some effect coming through. Any idea if it can be turned off completely in LG LM6700 or 47LA6200
Ands is offline
Old 05-13-2013, 02:10 PM - Thread Starter
Ands's Avatar
Movies looking like taken using a handy camera
Ands is offline
Old 05-13-2013, 07:58 PM
I will read the manuals but for now, I can't say for sure if you can for either of those TVs. Do you need it be a smart TV and/or 3D? How many HDMI ports do you need? I only ask because you can always get a TV that only does 60hz but they tend to be more basic models (not necessarily worse just without the bells and whistles like 3D).
Old 05-13-2013, 09:48 PM
I looked at the manuals for those two models. The LM6700 has a trumotion section where you can manually put in a dejudder setting (presumably you will be able to turn it off there) while the LA6200 makes no mention of that setting so I can't say if you can for that model though it doesn't look like it.
Old 05-14-2013, 01:57 AM - Thread Starter
Ands's Avatar
Thanks for looking at it. I'll try to find more info on LA6200. 60HZ is ok but i wanted TV with smart apps.
Ands is offline
Old 05-14-2013, 05:42 AM
8mile13's Avatar
Quoted: 1484 Post(s)
Liked: 828
60Hz LCd's do not have Motion Interpolation (which is mainly responsible for SOE). For 3D you can best buy a 240Hz. For movies its best to buy a 120Hz, . You can turn off motion smoothing (including Motion Interpolation) on most TVs.
http://www.rtings.com/info/what-is-the-refresh-rate
8mile13 is offline
Old 05-14-2013, 01:26 PM
You might want to look at Samsung's UN46EH5300. It is a 60hz model but has a CMR 0f 120 (Samsung says that that number tells you how well it can depict fast moving images). It has wifi built in and is a smart TV. Now, looking at the manual, there is talk of LED Motion Plus but I don't know if that is something you can turn off. You might want to see if you can find it in a store if interested so that you can check it out in person.
