Official Sony [X9] XBR-55X900A / XBR-65X900A Owner's Thread - Page 208 - AVS Forum
post #6211 of 11845 Old 03-25-2014, 09:33 AM
Geoff D's Avatar
Quoted: 134 Post(s)
Liked: 212
Grazie mille.
Geoff D is offline
post #6212 of 11845 Old 03-25-2014, 09:55 AM
HDTVAV's Avatar
Liked: 156
Originally Posted by mitico303 View Post
absolutely. when will sony answer me I'll immediately post the information obtained here..
Even when Sony does answer you - it is 50/50 whether they are right or not...
HDTVAV is offline
post #6213 of 11845 Old 03-25-2014, 10:03 AM
mitico303's Avatar
Quoted: 12 Post(s)
Liked: 64
Originally Posted by Geoff D View Post
Grazie mille.
non c'è di che! :D
yes, it's true. but at least I've something in my hands to use to complain with Sony at a later time... and you know, 50/50 is better than zero.
however you're right, I don't expect that the answer from Sony will solve all my doubts, but it's a beginning..
mitico303 is offline
post #6214 of 11845 Old 03-25-2014, 11:32 AM
falconhawke's Avatar
Thanks for the discussions and help provided the last few pages guys, very useful as I am trying out various settings on my new 65" X9 set up in my family room for a couple of days now. July '13 build date, HDCP capable, PKG4.201AAA from 2/7/14 updated.
One thing seems obvious, and that is Sony could and should do a better job of informing it's customers about the envelope of effects settings their TVs provide, describe for example how they might work (or not) in conjunction with each other on different types of sources, and clearly communicate some better facts regarding the input ports and HDMI/HDCP etc.. How hard should this stuff be, not much really, and it would give a definite sales advantage to them for going the extra bit-mapped inch.
'Course, this might be said of other manufacturers also.
Thanks for the detailed info, I'll at some point post a few observations and maybe ask a question or two. PQ so far is very good, with some definite source differences from the 60" Vizio E series it replaced, which was really also very good on all sources it took on.
I am loving the speakers/sound also, and retired the small Roland 'Cakewalk' powered speakers I was using often on the Viz, whose sound was better than I expected, but no match for the X9.
AVS Forums Rock !!!...
falconhawke is offline
post #6215 of 11845 Old 03-25-2014, 11:41 AM
Rudy1's Avatar
Quoted: 30 Post(s)
Liked: 99
Do you guys think this calculator is accurate enough that prospective buyers could use it to determine screen size?
http://referencehometheater.com/2013/commentary/4k-calculator/
Rudy1 is online now
post #6216 of 11845 Old 03-25-2014, 12:48 PM
flinchn's Avatar
Quoted: 134 Post(s)
Liked: 199
I think so, given the ranges. I watch at 7ft away on my 65". There is no doubt that there is a perceivable improvement over 1080p native. Those that say that watching 3ft away is pleasant- I don't understand at all.
flinchn is offline
post #6217 of 11845 Old 03-25-2014, 12:51 PM
flinchn's Avatar
Quoted: 134 Post(s)
Liked: 199
I can't believe no one sees a difference with Super Bit Mapping off- although i didnt notice a difference when I first got the set an i never revisited. Makes me think the feature was possibly defected on my set an when I turn it off the defect is negated. Or maybe the cumulative effect of all of the settings I have that are unique allow me to perceive a benefit. Or maybe it doesn't like the Darblet signal.
I can describe the difference I see if that helps
- Improved sharpness especially around edges. Easily seen in graphics and text
- Improved uniformity of colors
- improved maintained detail during movement
- bumped up luminance. Had to reduce my backlight from 6 to 5, although I have not measured this
flinchn is offline
post #6218 of 11845 Old 03-25-2014, 02:21 PM
MGTR420's Avatar
In the process of replacing my Marantz A/V receiver and have only been using my X900's speakers, I am really surprised how these speakers sound. I am really tempted to sell all of audio equipment...I know that the surround sound is really needed for the full effect.... I am just really confused on what to do now... confused.gif
MGTR420 is online now
post #6219 of 11845 Old 03-25-2014, 02:43 PM
MultimediaGeek's Avatar
Wait... you are saying that your picture IMPROVES like this when you turn it off? I will have to try it. I use AustinJerry's settings. Are you settings close to those?
MultimediaGeek is offline
post #6220 of 11845 Old 03-25-2014, 02:50 PM
flinchn's Avatar
Quoted: 134 Post(s)
Liked: 199
Umm not really in certain respects, exactly the same as Jerry's and Geof's in some basic measurements. I have them dialed in to other scene selects to compare. I believe there is enough deviation between individual sets to make certain settings that affect grayscale and such unique, since it has always been this way for HDTVs
Jerry often says there are one set of settings that indicate "calibrated" but I must admit that I now tend to go with what I "perceive" is better with content. But I do agree with Jerry.
flinchn is offline
post #6221 of 11845 Old 03-25-2014, 02:51 PM
AustinJerry's Avatar
Quoted: 381 Post(s)
Liked: 671
I am experimenting with the Super Bit setting right now as well, trying to determine whether I see a difference.
AustinJerry is online now
post #6222 of 11845 Old 03-25-2014, 04:11 PM
Geoff D's Avatar
Quoted: 134 Post(s)
Liked: 212
They are good, aren't they? I've seriously considered getting rid of my 5.1 setup too, but in the end I decided to downsize my speakers. I still want 5.1, I still love 5.1, but I can't justify having these big floorstanders and whatnot when they're hardly getting used because the TV is so good!
Geoff D is offline
post #6223 of 11845 Old 03-25-2014, 05:45 PM
HDTVAV's Avatar
Liked: 156
What do you use for music...?
I too am looking for a solution to clear up the "cluttered" look of big tower speakers, etc...
But I too like the sound of 5.1/7.1, etc...
HDTVAV is offline
post #6224 of 11845 Old 03-25-2014, 05:47 PM
norml4721's Avatar
Hello :
I also have a 5 and some times a 7.1 sound system and I can notice a HUGE difference in the sound between the Sony onboard speakers and my surround speakers. especially listening to music videos or movies. In fact I did the initial comparison and have not listened to the Sony speakers since then. in fact have not turnred off my surround setup in years.
Maybe watching the news but not anything else no way.. I have 10 focal (JM Labs speakers ) that I use in various configurations .If you want to free up some space its one thing but if you want that true home theater experience with the various master audio formats available to us you need at least 5.1 or even better 5.2. and some sound tracks are 7.1
Just think about that lightning strike or helicopter flying behind your head or that dinasor thundering through the trees etc.
I have a home theater in my family room and a TV upstairs in the living room.
Just my thoughts and the sony speakers are good for what they are. To each his own
LOL
Norm L
norml4721 is offline
post #6225 of 11845 Old 03-25-2014, 06:27 PM
flinchn's Avatar
Quoted: 134 Post(s)
Liked: 199
I agree, especially with films. But it's pretty awesome that some people say they are the best inbuilt speakers ever made.
flinchn is offline
post #6226 of 11845 Old 03-25-2014, 06:49 PM
HDTVAV's Avatar
Liked: 156
Dang... if you guys are saying these speakers sound that good...
I can't image how good the speakers on the B model sound with the matching wireless sub...
HDTVAV is offline
post #6227 of 11845 Old 03-25-2014, 07:56 PM
everunman's Avatar
Quoted: 17 Post(s)
Liked: 36
I gotta chime and and say how much i love the speakers, havent turned on my 5.1 once since i bought the TV eek.gif
everunman is offline
post #6228 of 11845 Old 03-26-2014, 12:54 AM
Crimsoncleaver's Avatar
Quoted: 29 Post(s)
What's this matching wireless sub, do you have a link?
Crimsoncleaver is offline
post #6229 of 11845 Old 03-26-2014, 02:12 AM
Covfam's Avatar
Liked: 43
The x900a also has an external subwoofer available sa w2500 but it's not wireless, it a small but good 70 Watt that works good, it works with the few TV's with subwoofer ports like the x900a w900 and it can be added to most Sony sound bar and multi speaker home theater systems.
Covfam is offline
post #6230 of 11845 Old 03-26-2014, 03:16 AM
I don't see a subwoofer out port on the x900a.
post #6231 of 11845 Old 03-26-2014, 03:52 AM
norml4721's Avatar
Hi Guys :
I absolutely can not believe what I am reading on the AVS forum. You are saying that the Sony onboard TV speakers are anyway near the sound of a middle to high end quality 5.1 system. There are thousands of members of this forum who I am sure disagree with you, I think we are getting a little bit carried away here.
These Sony speakers are good for what they are. Put those behind a curtain with a decent 5.1 system and A & B them. We are not talking about a slight or suttle difference here.
Come on guys. did we waste thousands of dollars here on speakers.
Again I am not putting down the Sony TV speakers and anyone who wants to just use them.
How can we be so critical about video and not be the same about audio. especially audio. This is the Audio Video Forum.
I quess one more time to each his own. Doesn,t anyone here agree with me ?
LOL
Norm L
post #6232 of 11845 Old 03-26-2014, 04:48 AM
flinchn's Avatar
Quoted: 134 Post(s)
Liked: 199
I tried to say the exact same thing a few weeks back but since I have thought about going over to a high-end receiver forum and saying their paired TVs are not up to the video standard they set for their audio. Probably wouldn't go well.
Not all videophiles are audiophiles and vice-versa. And some here on AVS are just rich wink.gif. I like good fidelity audio and most of my friends and families sound systems aren't very good, but I am way pickier (borderline insane?) about PQ.
There is also a huge aesthetic difference between a large nice looking TV and speakers or wires and many have to pass their decorating decisions by someone who might be just as happy going to Walmart and picking up a Sceptre.
For me it's about the total immersive experience and I haven't used stereo off the TV or otherwise in 15 years when I first went 5.1. Now I'm at 8.1 front heights Klipsch reference and a 1k receiver and even I think it's getting pretty ridiculous myself. smile.gif This TV is much higher end in its respective component category than my sound system.
flinchn is offline
post #6233 of 11845 Old 03-26-2014, 04:56 AM
Geoff D's Avatar
Quoted: 134 Post(s)
Liked: 212
norm, try to relax. You keep saying "to each his own" and then go on about how superior 5.1 is; that's not the point of that phrase. biggrin.gif
Look, no-one's saying that it does actually sound better or more surroundy or whatever than a "middle to high end quality 5.1 system". But what it DOES do is sound fantastic for what it is - it's just speakers in a TV! - and given how some people's lives don't revolve around 5.1 sound it's a superb substitute with none of the clutter and mess of a conventional 5.1 system.
I myself have damaged hearing owing to my surround sound escapades, so I'm starting to dial it back simply because I can't get the full benefit any more. I changed from 7.1 to 5.1, and then swapped out my chunky monkey speakers for some small satellites and a sub so I still have some sort of 5.1 system.
And besides, this is a specific thread for talking about this TV, so why shouldn't we discuss all aspects of it? The cracking sound is one of the reasons why I bought it. As flinch said, it's the equivalent of one of us going into the audiophile threads and waffling on about the lame TVs that those guys may/may not have. (Reminds me of a certain laserdisc enthusiast who pops up on various forums, he's got actual cinema Dolby processors and giant JBL speakers hooked up to a 28" CRT, I **** you not.)
wase4711 likes this.
Geoff D is offline
post #6234 of 11845 Old 03-26-2014, 04:57 AM
Originally Posted by norml4721 View Post
Hi Guys :
LOL
Norm L
George Lucas said that "Sound is 50 percent of the movie‑going experience, and I've always believed audiences are moved and excited by what they hear in my movies at least as much as by what they see.” I guess it also depends on what equipment they are comparing it too. I have spent about as much on my sound system as I have on my TV. I use the TV speakers when my family is sleeping or when I am only powering up the TV for a brief period (e.g. checking out the Super Bit setting) . I have a MUCH lesser system in another room with a 50" flat panel and a surround system and I wish it had the X900A speakers smile.gif.
post #6235 of 11845 Old 03-26-2014, 05:08 AM
For what its worth, my wife would be very happy to see the speakers removed from the walls, the mini-towers gone, etc. leaving only the X900A and its speakers. Makes the X850A more appealing to me ... smile.gif
And the quote for George Lucas is probably misquoted horribly over and over lol.
post #6236 of 11845 Old 03-26-2014, 05:09 AM
flinchn's Avatar
Quoted: 134 Post(s)
Liked: 199
Ironic that I stopped listening to both stereo AND George Lucas about 15 years ago. wink.gif
flinchn is offline
post #6237 of 11845 Old 03-26-2014, 05:09 AM
LeeSoFl's Avatar
Quoted: 89 Post(s)
Liked: 191
funny!
LeeSoFl is online now
post #6238 of 11845 Old 03-26-2014, 05:10 AM
norml4721's Avatar
antz
Hi Flinchn :
Most if not all of my friends including my adult children do not have anything but a TV in their house and the TV is of low to mid quality at that. They do not even know what 4K is. I on the other hand have a great deal of money and time tied up in my audio video equipment especially audio. My speakers are outstanding ( At least my opinion ) I have a 3.1 system with an old McIntosh tube amp with Focal speakers and a 7.1 all Focal speakers in my home theater. Focal used to be JM Labs a French speaker company.
I have been an audiophile for about 40 years in fact used to own a store called Auidio Video Workshop back in the 70,s and one of video products were Sony Tv,s along with thorens, Marantz Etc Etc,
I don't smoke or drink but audio and video gear is my hobby and enjoyment.
have to run talk to you later.
LOL
Norm L
post #6239 of 11845 Old 03-26-2014, 05:15 AM
flinchn's Avatar
Quoted: 134 Post(s)
Liked: 199
Well I smoke and when i do miraculously everything sounds and looks better. Cheap upgrade.
flinchn is offline
post #6240 of 11845 Old 03-26-2014, 05:16 AM
LeeSoFl's Avatar
Quoted: 89 Post(s)
Liked: 191
Worked in the recording industry and as a sound engineer at network TV in NY for my entire career, since age 22.
Speakers bigger than a refrigerator, consoles 15' long, amps that rumble the building to the ground.
Home theater system from 1975 (my first apartment) made every neighbor miserable.
Bought the 900, removed the amps, the speakers, (annexed somewhere else) and am fine and dandy with the less is best approach.
Lee
#SuperUserbySony
--- Sony has provided me with complementary products for evaluation. Participation in this program does not affect my posted comments, concerns or criticisms. ---
Reply LCD Flat Panel Displays
Sony Xbr 65x900a 65 Inch 1080p 120hz 3d Led 4k Ultra Hdtv , Sony Xbr 55x900a 55 Inch 4k Ultra Hd 3d Led Tv
