Official Sony [X9] XBR-55X900A / XBR-65X900A Owner's Thread - Page 382 - AVS Forum | Home Theater Discussions And Reviews
 909Likes
post #11431 of 13636 Old 07-30-2014, 10:09 AM
luism2008's Avatar
Quoted: 46 Post(s)
Originally Posted by Mattopotamus View Post
B.c it is a bravia TV....
That is sonys line of TVs.
Cool..but what functional use is there to it?
luism2008 is offline
post #11432 of 13636 Old 07-30-2014, 10:51 AM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
Originally Posted by aoktulsa View Post
Thank you for the prompt response, however, the reason we all want hdmi 2.0 is to have the ability to stream 60fps. Since you can stream 30fps using hdmi 1.4, will it make that much difference if you have the ability to stream at the higher frames per second rate from a picture quality standpoint. Any thoughts are appreciated...,,
We'll let you know whenever some 60fps content to stream actually exists..
RiED27880 and Rodymx like this.
wase4711 is offline
post #11433 of 13636 Old 07-30-2014, 10:53 AM
Mattopotamus's Avatar
Quoted: 1777 Post(s)
Liked: 1533
oh haha, it can mirror your tablet/android phone.
wase4711 likes this.
Mattopotamus is offline
post #11434 of 13636 Old 07-30-2014, 11:39 AM
Rodymx's Avatar
Quoted: 14 Post(s)
Yes this is correct... No 60fps content avaliable sniff...
Rodymx is offline
post #11435 of 13636 Old 07-30-2014, 12:52 PM
nuke's Avatar
Quoted: 244 Post(s)
Liked: 140
Originally Posted by ggw2000 View Post
Nuke, did you try Austin Jerry's settings? They look fantastic on my 65. Only diff is that I just cannot get use to Warm2 and use Warm1. I know it's technically not correct but it's more pleasing to me and that's what counts in the end .
Gerry
I did, but to my eye balls, the white balance on my particular panel needs a different setup than his.
I agree that Warm1 appears better out of the box. Warm2 seems really green to me, which is odd, since I've been watching another pretty decent set for years that does a good job in warm. (a sammy).
On the 900A, I can't seem to hit a grayscale that present the NTSC color bars with yellow and cyan in the right way. If I adjust hue to get cyan the same as my calibrated computer monitor, then the yellow bar is clearly too orange. When I get yellow right, then cyan is too blue.
I think if I can just get the white point of the greyscale established properly at D65, the rest will fall into place.
nuke
nuke is offline
post #11436 of 13636 Old 07-30-2014, 01:12 PM
ggw2000's Avatar
Quoted: 549 Post(s)
Liked: 219
I have been using AJs settings. Last night I decided to look at the Motionflow stuff. AJs settings has it set to "off". I flipped through them all and couldn't believe how dark the pic gets when you get to "clear plus" and beyond. Clear doesn't seem to have any affect on brightness. I have been running clear since yesterday but not sure that there is any diff between it and off? Anyone have any idea what the diff is or are using "clear"?
Thanks, Gerry
ggw2000 is offline
post #11437 of 13636 Old 07-30-2014, 02:01 PM
Liked: 1533
Thanks, Gerry
Mostly everything looks good with clear, but some shows/movies will get a really bad SOE.
Instead of toggling it on and off it is easier to leave off. I think sports look better on clear though.
post #11438 of 13636 Old 07-30-2014, 02:27 PM
ggw2000's Avatar
Quoted: 549 Post(s)
Liked: 219
Thanks for the reply. Now I understand- the old SOE thingy! I have not seen it yet but now I will understand the problem if it crops up.
Thanks again, Gerry
ggw2000 is offline
post #11439 of 13636 Old 07-30-2014, 04:43 PM
DiscoSmoke's Avatar
Thanks, Gerry
I was playing an Xbox 360 game, Dust: An Elysian Tail, which is a 2D smooth scrolling exploration/beat-em-up. In Game Scene, there was some smearing of detail when scrolling. In Custom Scene, with any Motionflow setting, this cleared right up, especially with Impulse, Clear Plus, and Clear. Clear was my favorite. I thought I saw a little jitter with Clear Plus. Impulse is great, but dark. I need to grab my HDMI splitter and another LCD display for a real comparison.
I also want to check the effect of Super Bit Mapping on scrolling.
DiscoSmoke is offline
post #11440 of 13636 Old 07-30-2014, 06:11 PM
Liked: 0
I will have to try that out. I just picked up Last of us PS4 and with game mode on it has crazy motion blur. Of course when nothing was moving fast the picture looked unreal. I switched to just regular cinema mode with AJ's settings and it was better.
The real question......when switching out of game mode what the input lag is Game Mode vs Any other mode.
Mayor77 is offline
post #11441 of 13636 Old 07-30-2014, 07:56 PM
ws6whiteshark's Avatar
I ended up pulling the trigger tonight on an "open box" display model of the XBR65X900A at BB for $2,174.99. I used $105 in rewards money for a total of $2,069.99 plus sales tax. Should receive it in a couple days. It was between the 900A and a Samsung 65" F8000. My wife likes the 900A looks over the Samsung's F8000. I didn't care either way, just wanted a good deal... I think I got it.
ws6whiteshark is offline
post #11442 of 13636 Old 07-30-2014, 08:45 PM
Shanndogg's Avatar
Just returned a defective Sharp 70SQ for the 65X900a. Glad I did as the picture is amazing.. but, I have light from the screen leaking through the left edge of the bottom-right speaker. Just trying to see if this is a common occurrence or if I should swap this one out.
Shanndogg is offline
post #11443 of 13636 Old 07-30-2014, 09:09 PM
TweakerInWA's Avatar
Quoted: 443 Post(s)
Liked: 212
Not common, swap it out....
Sent from my SM-N900T using Xparent BlueTapatalk 2
TweakerInWA is offline
post #11444 of 13636 Old 07-30-2014, 11:31 PM
zephyrzone's Avatar
Quoted: 26 Post(s)
Hi Everyone!
This is my first post in years. I joined AVS back when I bought my first HDTV, a Sony 50" SXRD RP 1080p. [EDIT: Actually I joined a while after I bought the TV] I loved it when I bought it, my how times have changed! I've been a HT hobbyist since 1996 when my Dad and I put together our first HT with a 32" JVC and a Pro Logic surround system with BIC Venturi speakers.
Nearly 20 years and many, many components later I just received my Sony 65x900a! Got a new job, moved across the country (Silicon Valley FTW) and decided to treat myself. I spent an inordinate amount of time researching before I settled on the 900a. My previous set was a Sony 55" HX-800. I seem to have a (bad?) habit of upgrading monitors every 4 years. I hope that's not the case with this new set, because it seems extraordinary in every way.
After using the much beloved "AustinJerry" settings and seeing this TV in action, I feel like all of my HT dreams have come true. It's absolutely that good. I haven't read all of the 382 pages in this forum, but probably over 70%. I feel like I know some of you already, it's weird. Flinchn and AJ have been quite helpful, not to mention so many other regular posters.
I got a very fair price on the TV (just below the ceiling I had set for myself) and had it shipped across the country. I was very worried about the "panel lottery". My old HX had awful blooming and pooling and it always drove me mad. I haven't done a full calibration on the x9 yet, and I may not. Using AJs settings everything looks spectacular and I'm not a color accuracy perfectionist so the delta errors aren't bothering me at the moment. I'm also a little concerned that once I see where the panel is having trouble, I won't be able to UNSEE it. Ignorance is bliss after all.
My first impression is that I have very little light pooling and generally very good uniformity. No DSE that I can detect yet or other imperfections that aren't inherent to an edge lit display. Of course, coming from that HX, anything was bound to look good. Still, I have sensitive eyes (or a crazy brain, or both) and nothing is jumping out at me.
The MAIN reason I wanted this model, which may sound crazy to many, was the passive 3D. I'm a huge 3D fan and know the 4k upscaling with the passive glasses is a match made in heaven. I popped in Hugo tonight for about 30 minutes and still haven't picked up my jaw.
All of my stuff gets moved in on Saturday, then I can install my Marantz receiver and AR 5.1 setup. Instead of unpacking on Sunday I'm going to play PS4 until my eyes bleed (much to my girlfriends chagrin, of course).
The HX had horrible motion blue which was cleared up by setting motionflow to smooth, but that introduced artifacts around fast moving objects and some judder. I'm hoping this panel resolves all of that in a much more reasonable fashion. I'm not a twitch gamer so hoping I don't need to use game mode. Guess I'll just see what works best. My hopes are high though that I can use my Cinema settings for gaming.
Anyway, thanks for taking the time to read this long post. I've been lurking for so long I couldn't wait to jump in once my set arrived. Thanks to all of you for helping me make this decision and answering all of my questions (before I even asked).
ZZ
Traylorc, bruceames and RiED27880 like this.
zephyrzone is offline
post #11445 of 13636 Old 07-31-2014, 02:36 AM
Liked: 1533
Take a picture if you can
Originally Posted by zephyrzone View Post
Hi Everyone!
ZZ
Congrats on the new set. This set had made a lot of people 3D fans, so that is not crazy at all!
post #11446 of 13636 Old 07-31-2014, 05:52 AM
Quoted: 443 Post(s)
Liked: 212
Hi Everyone!
ZZ
Welcome,
And thanks for sharing ! I think you're going to love 3D movie night with your new display. As for gaming, if it's online multi-player, you're going to want to use the game mode. I play tons of gears of war (ranked 89th in the world, lol, ) and that reduces the input lag to a very acceptable level. But on cinema, it's a no go, for me anyway playing Gears. I really haven't tried tweaking it in cinema for gaming, but give it a shot and let me know if you come up with something acceptable. I'm always up for trying different modes. I know someone was saying that using "impulse" was fantastic, but it's not an option in game mode. ... Anyway, welcome again and it's always nice to get new folks with a fresh set of eyes in here...:beer:
post #11447 of 13636 Old 07-31-2014, 06:56 AM
whatleydude's Avatar
FWIW: I updated my PS4 last night and FINALLY watched my first 3D Blu-Ray (Avatar) on the 55'900A.
HOLY HELL IT WAS AMAZING.
A.M.A.Z.I.N.G.
I honestly thought I'd never buy hard-discs ever again but this new 3D awesomeness has made start prowling the DVD shops again for awesome 3D bargains.
What's your favourite 3D Blu-Ray? I've seen a couple of people mention Jurassic Park. Any others?
RiED27880 likes this.
whatleydude is offline
post #11448 of 13636 Old 07-31-2014, 07:13 AM
Liked: 1533
A.M.A.Z.I.N.G.
Jurassic Park is decent. There are quite a few scenes that look really bad (mostly just the begining of the movie), but overall it is great. Pacific Rim is probably my favorite right now, and How to Train your Dragon looks amazing.
post #11449 of 13636 Old 07-31-2014, 08:03 AM
Traylorc's Avatar
Liked: 25
A.M.A.Z.I.N.G.
Just watched Rise of the Guardians and the Croods last night....both looked amazing. My wife, who is not a fan of 3D, was really impressed by Rise of the Guardians. While I was not a fan of Pacific Rim when it was in the theaters, I must admit the 3D blu ray was very impressive.
Traylorc is offline
post #11450 of 13636 Old 07-31-2014, 10:49 AM
Shanndogg's Avatar
Here are two photos of the light leaking through the speaker I mentioned. I have already begun the process to get it swapped out with another one.
I also have to agree with the sentiments above that this TV is ridiculously good- 2D, 3D, color, everything. Now if I can just get a non-defective one...
Edit- just noticed I didn't turn the first photo correctly- the light should be on the left, but you get the idea.
ID:	190194   Click image for larger version
post #11451 of 13636 Old 07-31-2014, 10:59 AM
Liked: 1533
definitely bad and you did the right thing exchanging it.
post #11452 of 13636 Old 07-31-2014, 12:52 PM
RiED27880's Avatar
Quoted: 154 Post(s)
Liked: 186
Hi Everyone!
ZZ
congrats on your purchase! you have in your hands one of Sony's best tvs EVER made, and i turely believe that after being WOWed myself everytime i turn on this set the 3D alone beats anything out there including 2014 models. ENJOY!
RiED27880 is offline
post #11453 of 13636 Old 07-31-2014, 01:00 PM
RiED27880's Avatar
Quoted: 154 Post(s)
Liked: 186
A.M.A.Z.I.N.G.
Jurassic park was awesome indeed! I like the Avengers 3D, The Hobbit 1,2, and Madagascar 3 are all spectacular IMO
post #11454 of 13636 Old 07-31-2014, 01:38 PM
Geoff D's Avatar
Quoted: 311 Post(s)
Liked: 341
Pacific Rim's 3D is the balls, it's superb. I highly recommend Titanic, and Top Gun is another one of my favourites.
Geoff D is offline
post #11455 of 13636 Old 07-31-2014, 04:25 PM
Faceless Rebel's Avatar
Quoted: 83 Post(s)
Liked: 44
The input lag when not in Game Mode is >120ms. If you don't notice that, then you are incredibly insensitive to input lag. For any game which requires even a small amount of reaction time, all Scene Settings which aren't Game Mode are unplayable.
I'm glad other people are noticing the amount of ghosting this TV has when there isn't any Motionflow around.
Faceless Rebel is offline
post #11456 of 13636 Old 07-31-2014, 04:57 PM
Adamd's Avatar
Quoted: 741 Post(s)
Liked: 428
Well it feels great to be back. I first had an x900a with bad hdmi so sony sent me a new one. That set had bad banding, next set had terrible clouding. Sony ran out of x900a and offered me a x900b, I instead paid the extra 2800 and moved to to the 950b. The 950b picture is amazing! BUT that expensive of a tv to have crap behind the lcd panel that can be seen 10 feet back. Went through two sets and both had it. Sony is refunding my money. And I must say sony canada is really good. I could not find a x900a anywhere in canada, four days of searching and calling and nothing. Then I found one sony store that had one returned because the owner wanted the 4k netflix on the b. tv was less then a week old and a May 2014 build. I check out the panel in store and it looked great. The whole reason I wanted this set was for the passive 3d. No other tv compares in 3d mode. Plus having the simuview glasses is awesome .Im loving life again, no more sleepless nights.
Adamd is offline
post #11457 of 13636 Old 07-31-2014, 07:12 PM
zephyrzone's Avatar
Quoted: 26 Post(s)
Thanks to everyone for the warm welcome! I'm super excited to get my HT fully setup. It might be a few weeks while I unpack. Thankfully the x9 speakers are really good. I'm really surprised with how well they perform, they're beyond what I was expecting.
I'm SO happy Sony updated the PS4 with 3D, that's a really big deal for me. Ug, I can't wait until Sunday when I can sit down in front of the screen and get my game on.
After reading some posts I'm pretty concerned that the Game mode is going to cause more motion blur than I want, but I guess you can't have it all. Who knows, maybe 120ms latency with my Cinema settings won't be so bad for me since I'm not a competitive gamer. I missed Gran Tourismo 5 when it came out on PS3 so I picked it up today used. Fingers crossed for a great 3D racing experience. So nice to have passive glasses at full HD! Unbelievable.
Do you guys think that passive 3D on 4k sets will breathe some new life into 3D? I have my doubts, but I really, really hope so.
ZZ
post #11458 of 13636 Old 07-31-2014, 09:23 PM
bruceames's Avatar
Quoted: 524 Post(s)
Liked: 358
I'd like to think so, but I believe it's too little too late. Seems most 4k TVs coming out actually have active, which is either being stupid, or a sign that they don't give a damn (more likely).
Besides, I think it's the whole glasses thing that's leading to 3D's decline, and not the fact that passive on 1080p sets is only half res (most people won't notice because they sit too far away, or they won't mind even if they do).
But we can still hope and dream.
bruceames is offline
post #11459 of 13636 Old 07-31-2014, 11:00 PM
damsesenior's Avatar
A.M.A.Z.I.N.G.
Life of Pi and A Christmas Carol, are two of my fav.
damsesenior is offline
post #11460 of 13636 Old 07-31-2014, 11:15 PM
halon's Avatar
Quoted: 48 Post(s)
Liked: 52
I'm not sure why I'm seeing all these posts about motion blur when gaming? I have not had a problem with that.
halon is offline
Reply LCD Flat Panel Displays
Sony Xbr 65x900a 65 Inch 1080p 120hz 3d Led 4k Ultra Hdtv , Sony Xbr 55x900a 55 Inch 4k Ultra Hd 3d Led Tv
