Official Sony [X9] XBR-55X900A / XBR-65X900A Owner's Thread - Page 400 - AVS Forum | Home Theater Discussions And Reviews
 904Likes
Old 09-01-2014, 06:01 PM
Geoff D's Avatar
Quoted: 303 Post(s)
Liked: 335
Originally Posted by AustinJerry View Post
It could be placebo effect, but I swear my PQ is even better now that I changed the screen setting to +1. Thanks, Geoff!
Yeah, the improvement could well be all in your head! But what you've done is remove another layer of processing, as the TV was essentially cropping the image (even if it was only a few pixels) and rescaling it to the native resolution of the screen. It still has to upscale a "+1" 1080p image of course, but now you're getting the cleanest possible upscale from HD to UHD because 1920x1080 to 3840x2160 is directly proportional.
Geoff D is offline
Old 09-01-2014, 06:26 PM
Geoff D's Avatar
Quoted: 303 Post(s)
Liked: 335
For reference when viewing a 1080p image:
+1 gives you no overscan, you're getting every pixel of the 1920x1080 source.
Normal crops approximately 20 pixels from top and bottom, 30p from side to side, so you're looking at a 1860x1040 resolution image.
-1 crops approx. 40p top/bottom and 65p from side to side, so you're essentially getting 1790x1000. Not good.
Both of the latter modes make for a trickier, non-linear upscale. You can see the effect on fine detail by pulling up a test pattern with single-pixel patterns and changing the display setting on the fly, you'll see weird patterns appear in the fine single-pixel mesh which disappear with +1. I recommend the S&M 'Framing' pattern, it's got a donut-shaped ring in the middle which shows up the scaling artefacts very well.
TweakerInWA likes this.
Geoff D is offline
Old 09-01-2014, 07:19 PM
TweakerInWA's Avatar
Quoted: 442 Post(s)
Liked: 212
Not sure if there are any ManU fans in here, but I don't have any friends to talk futbol with, so just a couple of names.
Falcoa
Blind
Man, let's hope these transfers get the offense going.
DiMaria-Rooney-Falcoa--Van Persie up front. Freaking awesome!
Sent from my SM-N900T using Xparent BlueTapatalk 2
TweakerInWA is offline
Old 09-01-2014, 07:33 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6688 Post(s)
Liked: 3688
Confirmed, the Framing pattern is an excellent way to show the effects of changing the Display Area setting. The center ring clearly shows moire and streaks at any setting other than +1. As I mentioned earlier, knowing which test pattern to pull up on the S&M disk can be invaluable. Nice tip, Geoff!
Geoff D likes this.
AustinJerry is online now
Old 09-01-2014, 07:51 PM
Faceless Rebel's Avatar
Quoted: 80 Post(s)
Liked: 39
Originally Posted by bodean View Post
Your direct TV has an option to upscale to 1080p? I know my Denon Receiver has the option (i/p scaler) but for Resolution (HDMI) I have it set to Auto. Wondering if I should set it to 1080p or 1080p:24Hz.
I have Denon receiver as well and I always disable the internal video scaler. It's better to let the TV upscale directly to 4K, rather than add an extra upscale step from whatever -> 1080p -> 4K. You're just adding processing on top of processing which is not good.
Faceless Rebel is offline
Old 09-01-2014, 10:04 PM
Quoted: 362 Post(s)
Liked: 77
Watch some cable tv, then poped in karate kid "mastered in 4k" and I have to say I was disappointed with the picture quality, the pictures look much better at best buy I dont understand, why cant mine look like what I saw at the store
I havent viewed any content on the fmp-10 yet to be fair
Question
Is there anything I can do improve the picture quality to get better resolution?
I tried hooking up a subwolfer to my 65 inch 900a but it failed, has anyone hooked up a subwolfer directly to the xbr-900a with success?
Last question is, how do I connect the 900a to wifi, where do I go link them up so I can ger updates
I posted pics of my hdmi port, my cable and blu-ray are hooked up to port 2 and 1 with fmp-x10 hooked up to port 4 (port 4 is off to the right by itself.
On my model is port 4 the only port capable of hdmi 2.0 and 4k display, perhapse thats why my blue-ray player and cable tv is not displayin the way it should like in the store
Basically......HELP!!..LOL
ID:	241818   Click image for larger version
ID:	241826   Click image for larger version
ultraflexed is offline
Old 09-01-2014, 10:10 PM
waqasjamal's Avatar
Hey guys. So I played a 3d movie for the first time on my 65". My tv is above my fireplace so it's not really at eye level but not too high. It seemed to me the 3d wasn't rally working right. I could still see double images. When I had the 55" in the same spot at same height I didn't have this issue even when I was sitting on the floor and watching a 3d movie. With the 65" I am seeing double images while sitting on my couch but when I stand and my eye level is somewhat in the lower 1/3 level of the tv, then I see the picture properly in the 3d. Is this normal ? Do I need to lower the tv to watch 3d movies. And this happened in all the 3d movies I have.
waqasjamal is offline
Old 09-01-2014, 10:14 PM
Liked: 3688
@ultraflexed
You should have a stunning picture with up-converted 1080p from the Blu-ray. Have you customized your settings yet? There are several thread participants that have posted custom picture settings that will improve your PQ. And remember to turn off the Eco settings!
I don't think the 900a will support a sub connection.
Regarding the WiFi connection, not sure where your issue is. Click the Home button, and scroll to the network settings icon. It should be intuitive from that point.
RiED27880 likes this.
Old 09-01-2014, 10:19 PM
Liked: 3688
3D is very sensitive to the vertical viewing angle. You should have a wall mount that allows you to tilt the panel downwards so it points directly at you. Or stop watching 3D.
Old 09-01-2014, 10:35 PM
Quoted: 362 Post(s)
Liked: 77
How do I turn off the eco settings ?
About to read the through the link in your sig about setting ir up
Old 09-01-2014, 10:57 PM
Quoted: 362 Post(s)
Liked: 77
Just read through your settings, will try it tomarrow , I have a couple questions.
Why did you turn mastered in 4k off in your settings?
What are my options if I cant direct connect a subwolfer?
And how do you turn off the eco settings?
The settings you recommend, is that just for 4k pictures or would that work when viewing 3d as well?
Old 09-02-2014, 02:16 AM
zephyrzone's Avatar
Quoted: 26 Post(s)
Forgot to quote, this message is in response to AJ's question...
The higher frame rate in gaming is essential when panning quickly around the environment, usually to shoot something before it shoots you. It's difficult to resolve all the action with only 30fps. WRT the post already answering your question, I can attest to the higher frame rate mitigating some of an LCD panel's weaknesses like latency and motion resolution. On our TV a 30fps game doesn't look so hot; motion "looses resolution" and everything gets a bit flickery and blurry. On a game that runs at 60fps, however, those issues go away to a very large extent. It's night and day.
I'm playing infamous on ps4 fight right now and even with interpolation on it's a bit messy (30 fps). Call of Duty and Metro look pretty great (60 fps, game mode on, interpolation off); the motion blur is pretty minimal.
AJ, do you have a Darblet connected? I got one response when I asked a few pages ago and was hoping some others would weigh in. The PQ on this set is among the best I've seen. I'm wondering if the Darblet really does make a difference, and in what way is it noticeable? Being a gamer I'm also curious how much latency the extra processing adds.
My phone magically started working with the tv today. It wouldn't synch before. I threw a 4k video clip from YouTube onto the set and watched it: some nature footage. It looked incredible, but very well could have been just full hd. The display button didn't show me the resolution and the Android phone app didn't list it either. I suspect it wasn't 4k, but my God, some shots were jaw dropping nonetheless.
zephyrzone is offline
Old 09-02-2014, 05:20 AM
Liked: 3688
Thanks for the informative response. It is always nice to see when someone takes the time to explain something clearly.
Yes, I do have a Darblet. Darbee processing provides a subtle, though IMO pleasant, clarity improvement to the PQ. If you want to get other people's impressions, there is a quite lengthy thread here on AVS. The same improvements that I was getting with my 1080p set, I get with the X900a.
Unfortunately, since I am not a gamer, I cannot comment on whether the Darbee processing adds any latency.
Old 09-02-2014, 05:26 AM
Liked: 3688
If you do a search on the MI4K setting here, you will see that the opinion is that leaving it off, like many of the other unnecessary processing options, results in a slightly better PQ.
In my case, the display is hooked to a full home theater system, including subwoofers.
You access the Eco settings by pressing the Home button, and then selecting Preferences. Turn them all off.
The settings are for 2D viewing. For 3D viewing, increase Backlight to Max, and raise the Picture setting to provide adequate brightness.
Old 09-02-2014, 06:17 AM
brenthenry's Avatar
Quoted: 18 Post(s)
I spoke to Sony Canada's Technical Customer Service last week... Following up on their promise to upgrade my HDMI #4 board to HDCP 2.2 and HDMI 2.0 support as well as delivering an X10 for reduced price of $199(CDN).
They said that they would in fact do this upgrade and provide the X10 for that price, however not until the 2nd week of September. So another couple of weeks and I will call back to set up an appointment.
They also offered an X5 option with only a firmware update? I didn't ask how much, as I really wanted the 1Tb HDD in the X10.
brenthenry is offline
Old 09-02-2014, 08:34 AM
Quoted: 24 Post(s)
Liked: 1
brenthenry. Your comment caught my attention. I have an 850A and was very interesting in buying the X10. In July I spoke with Sony Support and they told me my only option was to buy an X5 for $400 the second week in Sept. Hmmm. Getting an X10 for $199 seems like a better solution to me.
baba Louey is offline
Old 09-02-2014, 08:35 AM
Quoted: 24 Post(s)
Liked: 1
I'm in Canada by the way.
Old 09-02-2014, 09:27 AM
waqasjamal's Avatar
But I didn't have this issue with the 55". It was mounted on the same mount and both are tilted at the same angle.
Old 09-02-2014, 10:59 AM
bodean's Avatar
Quoted: 173 Post(s)
Liked: 43
Interesting point........maybe ill disable the i/p scaler then
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is offline
Old 09-02-2014, 11:09 AM
Quoted: 442 Post(s)
Liked: 212
Just my .02, don't think it's a good idea to mount a TV above the fireplace and expect decent 3D performance. Not sure which exact model you have, but the passive 3D performance of this set has been touted as being amongst the best. So as difficult as it may be too hear, probably something you're going to have to adjust to a point that's tolerable, or rethink it's mounting position.
Old 09-02-2014, 11:14 AM
waqasjamal's Avatar
I have the 65900a. I guess I will play with the mount first. I hope there is nothing wrong with the TV.
thanks.
Old 09-02-2014, 11:20 AM
Quoted: 442 Post(s)
Liked: 212
thanks.
Unlikely the TV, but you never know. I've just heard/seen issues related to poor 3D performance (not specifically this tv, just in general) due to the limited and or difficult mounting options some folks have to deal with. Probably a pain, but to rule out problems with the display, take her down and do some 3D viewing at recommended angles.
Old 09-02-2014, 01:08 PM
wk1947's Avatar
Quoted: 12 Post(s)
Was your 55 active or passive? I had a 55 active that was mounted flat. I had the 65 mounted on the same mount and checked out the 3D while standing and was blown away. Then I watched it while sitting on the couch and saw the same thing that you did. So , down came the tv. New tilting mount went on the wall and rehung the tv. Tilted the tv slightly and eureka an un beatable 3D picture.
wk1947 is offline
Old 09-02-2014, 01:15 PM
waqasjamal's Avatar
my 55" was passive as well. 55-900a. So i think we both had the same issue. So how much lower did you move the TV ? I have like 4-6" above the fireplace. Otherwise I have to find a new location for the TV which I don't know where right now.
Old 09-02-2014, 01:34 PM
wk1947's Avatar
Quoted: 12 Post(s)
My mount is at the same height as the previous one. By tilting the tv I am now looking at the center of the set straight on rather than just the bottom of the screen. I believe that you would have to lower it to where you are looking at the center of the screen. Someone who has theirs mounted flat could give you better advise.
wk1947 is offline
Old 09-02-2014, 02:30 PM
ggw2000's Avatar
Quoted: 526 Post(s)
Liked: 202
Austinjerry, back when I got my set I used your settings that were updated 7/4. I checked your settings today that are dated 8/31. I see that you made some minor changes to the picture/brightness settings but what appears to be bigger changes in the white balance section?
We're these a result of recalibrating your set?
Thanks, Gerry
ggw2000 is offline
Old 09-02-2014, 02:52 PM
brenthenry's Avatar
Quoted: 18 Post(s)
Yes that is interesting! Strangely enough they were really trying to push the X5 option... But they had already offered me the X10 with board swap option way back in May. It was commented in my account, so I guess they had to stand behind it.
I would recommend that you ask for that same option.
Old 09-02-2014, 03:30 PM
Liked: 3688
Thanks, Gerry
Nice catch. I am always making minor changes to the settings PDF. For example, I just added the tip for the Display Area setting, based on our recent conversations here in the thread.
As far as the White Balance values, they have indeed changed, but I didn't realize they had changed dramatically. I don't always go back and look at previous versions of the PDF. What changed for me recently is I am using a different disk for the test patterns. Previously, I had been using a disk called AVS HD709 (a free download here on AVS). Since I am such a big fan of the Spears&Munsil version 2 Blu-ray calibration disk, I started using the test patterns from that disk, which I am sure account for some of the changes. I also recently posted a new method for establishing the level of the Color setting, which has gone down on my set from a value of 55 to its current value of 51. I am sure this change impacted the White Balance settings as well.
So, bottom line is that White Balance settings are usually display-specific, and require test gear to set them properly. In my Settings PDF, I clearly state "use at your own risk" . While I think they should result in reasonably close grayscale on your display, the only real way to check is to learn how to do a DIY calibration yourself. Try it--it is a lot of fun!
zephyrzone likes this.
Old 09-02-2014, 03:47 PM
ggw2000's Avatar
Quoted: 526 Post(s)
Liked: 202
Thanks for the reply! Figured you were probably doing some additional research and tweaking . The settings look great on my TV with my old eyes!
Gerry
ggw2000 is offline
Old 09-02-2014, 04:03 PM
Geoff D's Avatar
Quoted: 303 Post(s)
Liked: 335
The 55A has a different 3D FPR than the 65A, it allows for a better vertical viewing angle at the expense of 1080p 3D.
Geoff D is offline
Sony Xbr 65x900a 65 Inch 1080p 120hz 3d Led 4k Ultra Hdtv , Sony Xbr 55x900a 55 Inch 4k Ultra Hd 3d Led Tv
