Official Sony [X9] XBR-55X900A / XBR-65X900A Owner's Thread - Page 413 - AVS Forum
post #12361 of 12388 Old 10-18-2014, 03:37 PM
Geoff D's Avatar
Quoted: 166 Post(s)
Liked: 222
Originally Posted by nuke View Post
True - there's really not much difference. In spite of number of available adjustments and gizmos, nearly all of them should be turned off.
The one I struggled with is the white balance. I found that the colorimeter (I1D3) was just not able agree with my eyes. This is not uncommon actually.
I have a spectroradiometer coming to do more detailed measures.
I will say though, that I'm really happy with the color settings now. This display is capable of greater color range and subtlety than any LCD I've ever seen.
Any chance of getting the skinny on the service menu trickery? I know how to get in to the menu and have poked around here and there but I've never found any built-in test cards. If you don't want to post it here (in case peoples **** up their TVs) then I understand, but a PM would be appreciated.
Geoff D is offline
post #12362 of 12388 Old 10-19-2014, 05:46 AM
Liked: 0
was so excited to buying 9005a with a big discount today, and then very disappointed that i actually cant play any 4k videos from usb
look like now i need some kind of media player?
Znomed is offline
post #12363 of 12388 Old 10-19-2014, 06:23 AM
Liked: 0
if i connect my pc with 7950 videocard to tv via hdmi, i be able to play 4k vids on tv?
Znomed is offline
post #12364 of 12388 Old 10-19-2014, 06:34 AM
TweakerInWA's Avatar
Quoted: 191 Post(s)
Liked: 95
I know folks have successfully played 4K files via USB and PC. The trouble you're having probably has something to do with the format your files are in (if I remember correctly). I have not tried, so I can't tell you myself, but the answers are located somewhere in the last couple months of posts.
Sent from my SM-N900T using Xparent BlueTapatalk 2
TweakerInWA is offline
post #12365 of 12388 Old 10-19-2014, 10:53 AM
Liked: 0
can someone explain why i cant run full hd 3d on my 55" x9005a? seems like its not issue for 65", whats the difference? can be fixed?
Znomed is offline
post #12366 of 12388 Old 10-19-2014, 11:05 AM
AustinJerry's Avatar
Quoted: 763 Post(s)
Liked: 793
AustinJerry is offline
post #12367 of 12388 Old 10-19-2014, 11:31 AM
Liked: 0
i mean full 1080p for each "eye"
Znomed is offline
post #12368 of 12388 Old 10-19-2014, 11:37 AM
Mdjones9137's Avatar
Quoted: 157 Post(s)
Liked: 106
This is a limitation of the 55 panel and can not be changed. Sony marketed it as full HD for each eye but then removed that statement from the 55 marketing months after it was discovered by owners.
The 55 does not display full HD (1920x1080p) to each eye when in 3D mode like the 65 does. The 55 displays 1920x540p to each eye.
You should find posts on this in this thread.
Mdjones9137 is offline
post #12369 of 12388 Old 10-19-2014, 12:26 PM
everunman's Avatar
Quoted: 23 Post(s)
Liked: 40
If the video cards resolution can be changed to 3840 x 2160, then yes, vlc player is the best option IMO
everunman is offline
post #12370 of 12388 Old 10-19-2014, 12:29 PM
everunman's Avatar
Quoted: 23 Post(s)
Liked: 40
You need a PC that can support 3840 x 2160, I beleive the latest mac mini does, there are lots of cheap 4k players around on ebay, choose one and look for youtube reviews, i cant recommend any
post #12371 of 12388 Old 10-19-2014, 03:53 PM
eastside718's Avatar
I had the same issue. There is an automatic iris that adjusts to room light conditions. Turn it off and use the "vivid" setting. Adjust as necessary. I can provide you my settings if necessary. I hope this helps.
eastside718 is offline
post #12372 of 12388 Old 10-19-2014, 06:59 PM
Geoff D's Avatar
Quoted: 166 Post(s)
Liked: 222
No no no, the TV cannot play 4K vids directly from USB.
Geoff D is offline
post #12373 of 12388 Old 10-19-2014, 09:40 PM
nuke's Avatar
Quoted: 70 Post(s)
Liked: 40
There are actually several sets of test patterns built into the set if you explore the service menu. Some are effected by Sony's color settings. There is a set of patterns you can reach by using the options key on the remote, that directly invoke test patterns built into the raw AUO LCD panel itself. They match exactly the patterns that can be brought up by I2C commands to the AUO TCON board. (I found the full AUO data sheet for the raw LCD panel used in the 65X900A).
Using this set of menus, you can actually measure the full native gamut and the native white point of the panel. It is a set of WRGBCMY color bars, but are generated directly by the raw LCD itself. There are other patterns, including greyscale ramps in various directions and some patterns use to setup VCON and some other internal setups. Measuring the color bars in this pattern reveals the entire native gamut of the display.
I used this test pattern set to find a reference white point, which measured quite close to D65. I set that as a custom white point in HCFR and used the white balance user settings to align to that white point. It looks quite right.
The I1D3 says it is wrong, but it appears to be unable to accurately measure the quantum dot spectrum. Without a spectral correction file specific to this technology, a colorimeter is unlikely to give proper results.
Curiously, the Sony W900A, a 1080P which also uses quantum dot backlight, has a different Lcd vendor and exhibits a different white point and gamut.
nuke
nuke is offline
post #12374 of 12388 Old 10-20-2014, 10:47 AM
Geoff D's Avatar
Quoted: 166 Post(s)
Liked: 222
I pressed the options key when in the service menu but it takes me to two new menus, neither of which say anything about test patterns. One has WYVERN and S2_NOISE_TH listed, the other one says DATA_COPY and BU_TRANS. Halp?
EDIT: Don't worry, I found a PDF on the internets. Funny how these things never show up when searching for them with general terms, but put S2_NOISE_TH into a search engine and BINGO! Up it comes.
I'm doing this so I can get a similar idea of what the gamut is on the B series set that I have, checked from the colour bars with HCFR and a ColorMunki display (same hardware as an i1D3). See attached.
Name:	native gamut.jpg
Geoff D is offline
post #12375 of 12388 Old 10-20-2014, 11:22 AM
RiED27880's Avatar
Quoted: 71 Post(s)
Liked: 139
Originally Posted by ZEROpcs View Post
I definitely agree dim is subjective; however, for example, in the sewer scene in Dark Knight Rises when Bane breaks Batmans back it is almost impossible to make out what is going on when they move away from the light, and even in the light its difficult.
I will mess with vivid, thanks for your suggestion.
UPDATE: Vivid doesn't really give many in-depth options for editing... I dont think that is the answer.
try"custom" it looks fantastic and natural as well, it disables every picture enhancer and allows you to set your picture the way you want.
RiED27880 is offline
post #12376 of 12388 Old 10-20-2014, 06:43 PM
ZEROpcs's Avatar
I will try that... Thanks...
ZEROpcs is offline
post #12377 of 12388 Old 10-21-2014, 06:02 PM
Liked: 0
Hi all,
I have recently bought a 55X900A and noticed some sort of screen fault/bleeding? It is mostly visible when the right side of the screen is dark but other sides of the screen are not dark.
I am completely clueless when it comes to TV faults, so I thought I'd ask you guys whether my screen is actually faulty or need some setting adjustments etc.
The attached are two blu-ray shots.
Thank you in anticipation.
Cheers,
Shaun
ID:	323641   Click image for larger version
Shaun- is offline
post #12378 of 12388 Old 10-21-2014, 06:19 PM
Quoted: 157 Post(s)
Liked: 106
Originally Posted by Shaun- View Post
Hi all,
Cheers,
Shaun
The stand on the TV in the second pic looks like a 900B to me - the 900A would have a stand that is in the center and is a circle.
Are you sure the TV is a 900A? There is a different forum for the 900B
post #12379 of 12388 Old 10-21-2014, 09:22 PM
nuke's Avatar
Quoted: 70 Post(s)
Liked: 40
Interesting data. The 900A version has a bigger gamut but your 900B actually covers the 709 gamut more closely.
I'd love to see the spectral characteristics taken by a spectroradiometer.
nuke is offline
post #12380 of 12388 Old 10-22-2014, 01:30 AM
Liked: 0
My mistake, my TV is a 900B. Can you please refer me to the correct forum?
I would nonetheless like to have your idea about my TV screen issue.
Shaun- is offline
post #12381 of 12388 Old 10-22-2014, 03:13 AM
Quoted: 191 Post(s)
Liked: 95
http://www.avsforum.com/showthread.php?t=1522857
I would say that panel needs replaced. Does it look the same for all content?
Sent from my living room where my x10 runs directly through my AVR for both audio and video using one HDMI cable
post #12382 of 12388 Old 10-22-2014, 10:31 AM
Quoted: 157 Post(s)
Liked: 106
Here is a link to the 900b official forum:
"Official" 2014 Sony XBR-55X900B / XBR-65X900B / XBR-79X900B Thread
I would post the same question on that forum and see what they have to say about the panel.
post #12383 of 12388 Old 10-22-2014, 10:33 AM
Vasim Pathan's Avatar
Quoted: 12 Post(s)
shaun, the panel is bad, that isn't normal.
Vasim Pathan is offline
post #12384 of 12388 Old 10-22-2014, 04:50 PM
LeeSoFl's Avatar
Quoted: 146 Post(s)
Liked: 203
Number Only on Netflix
Anyone notice the SD and HD and Super HD are gone from the TV's Netflix application?
LeeSoFl is offline
post #12385 of 12388 Old 10-22-2014, 05:21 PM
Quoted: 157 Post(s)
Liked: 106
Yes - No label for you !!!
Wonder if 4 more dollars a month brings the label back?
post #12386 of 12388 Old 10-22-2014, 05:49 PM
Quoted: 191 Post(s)
Liked: 95
Still there on the X10, just checked watching House of Cards.... 2160 SD
Edit : Maybe this just applies non 2160 streams?
Edit 2: Still there on all content, watching a 1080 Super HD stream.
So I guess the "Display" info generated by the X10, indeed comes from the X10 and not Netflix. So Sony will be able to address this issue on the X10. I know some folks didn't think it was Sony related.
halon likes this.
post #12387 of 12388 Old 10-23-2014, 07:48 AM
halon's Avatar
Quoted: 35 Post(s)
Liked: 45
Any new news on streaming boxes the stream 4K other than the X10, I'm not buying that. The ps4 should be able to do what the X10 does.
halon is offline
post #12388 of 12388 Old Yesterday, 07:12 PM
Virtuo's Avatar
help with 4k playback
Im in canada and still no 4k streamer from sony from us, and no way to watch netflix 4k either, i cant even play 4k content from 4k camera because the 900a wont support usb playback. has anyone had any luck any luck at all? Because im totally fed up
Virtuo is offline
Reply LCD Flat Panel Displays
Sony Xbr 65x900a 65 Inch 1080p 120hz 3d Led 4k Ultra Hdtv , Sony Xbr 55x900a 55 Inch 4k Ultra Hd 3d Led Tv
Gear in this thread - 65x900a by PriceGrabber.com
